Likes Likes:  2
Results 1 to 4 of 4
Thread: Hot Rod Column Connector
    rank amateur Shades's Avatar
    Sep 2019
    Southeast PA
    Just getting started on wiring, and as I look at each circuit, I'm reviewing all diagrams vs what I see on my wires and connectors, to get as much understanding as possible and avoid mistakes.
    While the manual says to simply plug the steering column into the chassis harness plug, I did a comparison of the wire labels and descriptions between the harness manual and the IDIDIT instructions. The attached diagram shows what I found. Three of them seem to conflict (J, K & L). Might these have been pinned wrong?
    I also put together this diagram based on what I found on IDIDIT's site. The diagram there had too many crossing wires to really visualize easily. This helped me to understand a little better.
    Jun 2018
    North Vancouver, BC, Canada
    It's difficult to understand what goes on inside the column, tried for awhile and didn't come up with a meaningful diagram. What I can tell you is that if you follow the directions in BOTH the wiring harness manual and the hot rod manual you'll come out with a working system - in particular make sure you cut the wires that are detailed in the hot rod manual.
    Gen 1 '33 Hot Rod #1104
    I agree with Steve. It's almost for sure correct as you received. I had some of the same questions with the Ididit column and RF harness with my truck build. It worked as received. Agree also about either dieting or capping the wires in the harness per the manual. The Hot Rod connector is a duplicate of other wires in the harness used for other models. So they're live and need to be out of the picture.
  4. Likes FF33rod liked this post
    Sep 2019
    Southeast PA
    Thanks to both of you. I did see how the manual says to cut and cap the pink and gray wires at the dash harness, probably because the column takes care of those functions, and that the column removes the need for horn and hazard switches that are shown in the harness schematic. I'll leave it alone and follow the manual. The one that looked really odd was the mismatch on the right front signal. I guess if that light doesn't work I have one place I know to check.
  6. Likes FF33rod liked this post
