Thread: AC / Heater / Defroster
    Jul 2020
    I am considering the install of AC / Heater in my Gen 3 Coupe. Besides the unit FFR sells what other brands will fit under the dash?
    Thank You,
    Edward
    May 2021
    Fort Worth, Texas
    Quote Originally Posted by Fasteddie41458 View Post
    Thank You,
    Edward
    Just to let you know. I tried out the Vintage Air Gen IV Magnum mock up box and it is a no-go for under the dash without major surgery to the dash.
    I studied this pretty thoroughly when I did mine. I didn't find a single example that fit other than the Factory Five setup with the Siroco evaporator they use. Because of the frame design, the space is very limited. It's a basic system and works OK. Won't freeze you out like most DD's. But makes the interior comfortable. Heater works great.
    Jul 2020
    Thank you, good information.
    I want to echo what Paul said, I looked pretty extensively to try and find a setup that would fit a gen 3 and had absolutely no luck. space is very limited behind the dash. I wound up just ordering the kit from FFR.
    Port Charlotte, FL
    Erik Treves designed a system that goes behind the drivers wheel. Contact him for details,
    Henry
