Likes Likes:  3
Results 1 to 11 of 11
Thread: Removing rear spinners
    Aug 2019
    After a couple seasons of not removing the rear FF5 spinners, I can’t seem to be able to remove them. I have removed the Allen key retainer, however every time I try to hit the spinner with a rubber mallet, the thread adapter or hub just spins with it. Tried tightening, loosing it, back and forth but it seems the spinner and hub don’t want to separate. The fronts came off with ease. Any suggestions?
    Dublin, OH
    worst case scenario is to drill/tap a hole through the center threaded adapter to have something to hold on to while spinning the spinner
  3. Likes speedfreak1211 liked this post
    Jun 2017
    Norway
    How about drilling two holes that the tool to loosen grinder discs with will fit in? Never tried it myself, just a suggestion for a possible fix.
  5. Likes SJDave liked this post
  6. #4
    Jul 2020
    Central Indiana
    Have you tried apply some heat to the spinner and or some penetrating oil in the set screw holes and behind the knock off.
    Mk IV 9968 complete kit, 3 Link, PS, 15” Halibrand, Wilwood Brakes
    Blue Print 347, TKO600
    https://thefactoryfiveforum.com/show...358#post446358
  7. #5
    Senior Member JIMOCO's Avatar
    Aug 2013
    Camp Hill, PA
    I used oil filter pliers with a pad of firm rubber duct taped to the jaws. I was able to grab the threaded adapter enough to be able break grip of the spinner.
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
  8. #6
    Falmouth, MA
    Just a reminder, some of these I believe have a left hand thread.
  9. Likes Caddy Dad liked this post
  10. #7
    Senior Member Caddy Dad's Avatar
    Jun 2019
    Scaggsville MD
    Once you do get the spinners off, a small application of spinner eaze works great to keep them from seizing up again.
    http://performanceunlimited.com/cobr...innereaze.html
    Cheers!
    Mk IV Roadster #9749, Kit received Jan 2, 2020, Blueprint SBF 347 TKO600 Holley Sniper EFI, Dual roll bars, IRS, 17" Halibrand, Nitto 555 G2 245, 315 Road legal Oct 20, 2020
  11. #8
    Dublin, OH
    If installed correctly, you should be loosening by turning the spinners towards the front of the car, regardless of the side you’re on. Just remember “tight ***” and you’ll always tighten towards the rear. You might get enough grip with a strap wrench around the center hub if there’s enough room to grip
  12. #9
    Aug 2019
    Thanks all. Ended up drilling a small hole enough to get a punch through. That with a bit of oil and finally got it off.
  13. #10
    Senior Member Nigel Allen's Avatar
    South Australia
    Nice tip. Thanks!
    Gen1 Coyote / TKO600 / IRS
  14. #11
    A size 329 silicone o-ring will hold the hub piece and prevent it from spinning on you.
    Another trick is to cut a piece of a foam pool noodle that is about the diameter of the hub to a length a bit longer than the length of the rotor to the spinner hub. Stick it into the wheel as you install it and the noodle will compress and will hold the spinner hub in place.
    Finally, if you want to go high-end, contact Dave from:
    He will make you a set of these at a very fair price:
    They slide in after placing the spinner hub in the wheel. The pointed set screws then get tightened until they bite into the wheel. Next, tighten the flat set screws against the spinner hub to hold it firmly in place.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  15. Thanks SJDave thanked for this post
