Factory five daytona
complete kit purchased
SVO 302a block (4 bolt main block)
3.4” forged crank
5.4” forged h-beam rods
4.060 forged pistons (racetech custom)
internal balanced motor
crane solid roller cam (in .658 / ex .680)
C3 yates heads
jack roush intake (part # m-9424-b302) good luck finding one
jesel 1.7 shaft mount rocker arms
dry sump engine
3 gallon oil tank
demon 750 carb
mds ignition
power steering
tremec 6 speed
8.8’’ 3 link rear end
373 rear gear.
Wilwood brakes
halibrand vn427 wheels (these are not knock offs)
315 rear tire
295 front tire
aluminum panels are powder coated jet black.
the rims are true VN427, they are NOT knock offs.
tires are nitto 555. 315 rear 295 front. 17" all the way around
differential is a ford racing 8.8" with 3:73 gear, complete differential was purchased from ford racing brand new. nothing in the car was used.
