Results 1 to 5 of 5
Thread: FS: 2004 WRX Parts for 818R Build in PA
    Jun 2021
    I have most of the parts for an 818R build already removed from a car. The plan was to build an 818R and I had owned a 2004 WRX MT since new. I stripped the WRX at 136k miles down over the summer of 2019 and then life changed substantially and it looks like I'll never have time to build an 818R. The WRX ran great when I took it apart, the chassis was getting pretty rusty and I had the time so I pulled the trigger. Anyway, all parts have been stored in my garage or climate controlled basement since then.
    Here is a rough list of what I have:
    Complete EJ205 engine that always had the oil changed regularly since new, never any issues with it
    Transmission w/ stock clutch and flywheel, shifted well when pulled from the car
    All brake calipers
    All axles
    All spindles
    Steering column
    Steering rack
    Rear lower forward arms
    Instrument cluster
    Pedal assembly
    Brake and clutch master cylinders
    Radiator with fans and overflow tank
    Complete wiring harness, everything labeled
    Fuel pump
    Things I definitely don't have:
    Front control arms
    Rear lower trailing arms
    Rear toe links
    Rear sway bar
    Downpipe
    Seats
    Seat belts, interior bits
    Windshield wipers
    I'm looking to sell everything as a package and it would have to be picked up from 19090. $1000 takes everything, this stuff needs to go.
    Jun 2021
    Bump, still available.
    Jun 2021
    All still available. Sorry to those that have messaged me, I thought I would get emails about the PMs but I don't have enough posts to access my settings. I'll be checking my PMs regularly.
    I really need these parts gone as I'm moving soon and I'd prefer these parts go to someone on these forums rather than Craigslist/Facebook marketplace people.
    Senior Member mistasherm's Avatar
    East Central PA
    Sent you PM
    220,221 whatever it takes....
    Jun 2021
    $1000 takes everything, I need to get rid of this stuff.
