Thanks Thanks:  7
Likes Likes:  8
Page 1 of 3 123 LastLast
Results 1 to 40 of 108
Thread: Jamminj's type 65R cnc cut parts
    Aug 2019
    Paradise/Magalia Ca
    updated(I have purchased my type65r)
    here's the parts I have purchase
    Built coyote(317in) in build process
    Darton sleeved
    custom Manely extreme pistons
    Boostline rods
    Winberg billet crank
    Billet main caps
    gt500 oil pump kit with boundry billet gears
    Comp custom designed blower cams By Billy Godbold
    Ported heads by Tim Eichhorn NPR racing engines
    Whipple 3.8 supercharger (New design 2k+hp Completely reengineered not out till may/June 2021)
    super 8.8irs with 3.73 Torsen
    GForce performance outlaw half shafts
    liberty gear built t56 magnum
    Browell bell housing
    black magic defiant slipper clutch
    s197 spindles front
    6 piston Brembo (s550) 15" rotors front (2013 gt 500)
    4 piston Brembo (camaro/ctsv) on 11.88 (s197) rotors rear
    Forgeline GA1R 18" wheels with Toyo r888r tires for road racing
    weld wheels 15X12 double bead lock for drag strip and skinnies up front
    Girodisc full floating rotors
    AEM engine management system
    building my own chromoly upper and lower control arms and pushrod/bell crank adjustable spring and damper system
    Images below were of my original build that has since then been torn apart to remove Boostline rods to be used in my big power build.
    now I have 2 engines one is Edelbrock 2650 supercharged and the other is the big Whipple build.
    Aug 2019
    Paradise/Magalia Ca
    The 2 gen1 coyote intake ports side by side are left ported by MPR racing and right stock no porting quite a difference
    Feb 2018
    Half Moon Bay California
    This should be an amazing build! How much HP are you looking to achieve?
    Feb 2018
    I am in the process of building mine and in California as well. Not too far from you.
    Aug 2019
    Paradise/Magalia Ca
    2k+ on One Ethanol R or methanol
    But I'll be running a pump gas tune and a chocked throttle body on the street at about 700hp.
    and a road track tune with e85 in the neighborhood of 900
    Aug 2019
    Paradise/Magalia Ca
    Will Roland at RPG racing in Fresno is helping me with my build
    Senior Member q4stix's Avatar
    Seattle, WA
    Should be a monster!
    I take it you're using the Gen 1 timing setup and phasers because of the Infinity?
    And welcome!
    Gen 3 Type 65 Coupe builder
    Feb 2018
    That will be scary fast at those HP levels.
    My build is on YouTube at cobra Daytona build.
    Welcome to the factory five family.
    I am looking forward to seeing your build.
    Aug 2019
    Paradise/Magalia Ca
    yes I'm using gen 1 hope I dont have to lock the phasers
    my intake is 240 duration and 570 lift
    my exhaust are 246 duration and 576 lift
    the rate of lift is aggressive also reaching full lift quicker than street cams
    using the 2020 gt500 oil pump (20%)more volume and Travis at boundary pumps
    ported oil pump gears
    hoping to be able to control the cams.
    I'm waiting my heads actual cfm's tested
    but ive been quoted intake cfm [email protected] lift and exhaust cfm [email protected] lift
    so these cams will make good use of these ports
    Aug 2019
    Paradise/Magalia Ca
    cool just glanced at your YouTube I'll check it out more later
    Aug 2019
    Paradise/Magalia Ca
    boundary ported 2020 GT 500 billet pump gears
    ports reduce oil cavitation
    difference between factory coyote gear and 2020 GT 500 gears
    20% more volume
    2020 GT 500 pump fits all coyote years
    Jan 2021
    Jammin,
    I have a coupe 65 r coming in a few weeks and didn't order wheels from FFR. For some reason, I can't get a straight answer out of anyone on their aftermarket setups for wheels and tires. Have seen lots out there that 17/18x10's upfront and 18x12" in the back is possible on these cars. Can you tell me if you have confirmed any of this with your Forgeline GA1R 18" wheels that you are looking at?
    Aug 2019
    Paradise/Magalia Ca
    i have the wheels but not the car yet
    they came off my mustang the offsets are wrong but I'm going to be making my own a-arms front and rear
    but my friend is building a type 65 now and i was going to take mine wheels over there and mock them up
    it will be a few weeks
    i can let you know after that if you haven't figured it out by then
    Aug 2019
    Paradise/Magalia Ca
    by the way 18X12 should work if the offsets are right
    ffr should be able to help with that
    I'm assuming your running Toyo r888r 335 30r 18
    also check this post out
    https://thefactoryfiveforum.com/show...444#post453444
    Aug 2019
    Paradise/Magalia Ca
    I ordered my type 65r kit today
    have most of what I need to build the rest of the car
    May 2021
    Fort Worth, Texas
    Congratulations!
    Aug 2019
    Paradise/Magalia Ca
    thanks won't see my kit until march
    adjustable 11" clutch pro stock style(slipper) from black magic came last week (American made)
    liberty built Tremic t56 magnum showed up Monday
    Browell sfi 6.1 bell house with bottom clearance for low vehicles and inspection cover(needed for adjustable clutches) came Tuesday (American made)
    QuickTime bottom hangs too low and if you modify it you will lose you sfi rating for most people that isn't an issue
    Girodisc rotors came Thursday factory 15" weigh 34lbs these are full floating and weigh 22.3lbs (American made)
    I'll load pics later when i have time
    Aug 2019
    Paradise/Magalia Ca
    Black Magic adjustable clutch
    Liberty fully built t56 magnum
    6 piston Brembo's (s550 mustang)
    2013 gt500 15" full floating rotors from Girodisc
    s197 mustang spindles
    (Will not fit ffr a-arms or spindles)
    May 2021
    Fort Worth, Texas
    All the attachments seem to be invalid. Seven months! Dang. I have been figuring 18 months as a minimum.
    Aug 2019
    Paradise/Magalia Ca
    Completed
    Edson Myers car 82 years young
    built by himself in 7 months
    including paint
  21. Thanks WIS89 thanked for this post
    Likes WIS89, Jabs1542 liked this post
  22. #21
    May 2021
    Fort Worth, Texas
    Quote Originally Posted by jamminj View Post
    Completed
    including paint
    Incredible! Just incredible.
  23. #22
    Aug 2019
    Paradise/Magalia Ca
    Finally on Monday the 27th I get to drop my engines off at RPG racing to be built
    last march I put my name on Will's long waiting list and now the day has come for me to drop off my blocks and all my parts to be built
  24. #23
    Aug 2019
    Paradise/Magalia Ca
    GEN 1 coyote block ready for interference water jacket spacers for big boost from 3.8l Whipple
    spacers are press fit into cnc receiver on block. Then the block can be decked, o-ringed
    and drilled for water jacket holes to match head gaskets
  25. #24
    Seattle, WA
    Is the closed deck something that is done regularly or something new for this build?
    It looks like the first pictures you posted are with sleeves but they don't look like they're there in the most recent block images (but maybe that's the lighting). I do see the counterbore for them in the CAD images though.
    Thanks for sharing more pictures, it's fun to see!
  26. #25
    Aug 2019
    Paradise/Magalia Ca
    first pic was my original build I was going to be running 1300 hp with Edelbrock 2650
    but that all change when I ordered a Whipple 3.8l and I started another build, and these are the new pics
    I'm going to end up with 2 complete engines when I'm done so I guess I'll need to build another car later
    Back to your question the spacer adds more uniform support to the Darton sleeves for more than 2000 hp
    And no, it's not done regularly just for high boost
  27. #26
    Aug 2019
    Paradise/Magalia Ca
    Seattle, WA
    Thanks for the explanation and the video. Totally makes sense now and I figured I missed a step in between haha.
    I'm familiar with Subarus and the EJ engine when they machine it similarly for a closed deck setup but I've never seen it on the Coyote platform. Should be a monster!
  29. #28
    Aug 2019
    Paradise/Magalia Ca
    Yes, I think all of these closed deck design started with either Subaru or Toyota don't know who was first
    we will be running MLS gaskets with the O-ring cut right behind the fire ring in the block around .008 above deck without receiver
    I've seen 2js with 80+LBs of boost at over 2000 WHP
    we have good flow so we will probably only need to see 38-40Lbs to meet our goals
    copper gaskets (that like to weep) need a much taller O-ring and receiver
  30. #29
    Aug 2019
    Paradise/Magalia Ca
    This engine is similar to mine but mine is being built stronger
    my interference water-jacket supports won't fall in the engine like those in the video did
    and we are using a billet Winberg crank which will keep the crank from walking the main caps
  31. Likes WIS89, James Morse liked this post
  32. #30
    Aug 2019
    Paradise/Magalia Ca
    very good coyote build video
  33. Thanks WIS89 thanked for this post
    Likes WIS89 liked this post
  34. #31
    Aug 2019
    Paradise/Magalia Ca
    Woohoo
    get my car in 7 or 8 weeks
    My for real 2100hp+ coyote engine is past all machining and structural phases
    everything is balanced with pressure plate and flywheel
    and now is in assembly
    then off to Whipple for testing with c25 race gas and one ethanal r
    we are taking this engine to the limitations of the Whipple 3.8l race version
    My frame builder is ready to help me with my spec 25.1 chromoly frame
    pics and vids coming soon
  35. #32
    Aug 2019
    Paradise/Magalia Ca
    Stewart Transport has me tentatively scheduled for delivery end of march
  36. #33
    Aug 2019
    Paradise/Magalia Ca
    Around 4 weeks and sanity ends and the fun begins
  37. #34
    May 2019
    Oh, hell, sanity ended when you placed your order.
    If you're like most other car guys, sanity actually ended a very long time ago, as evidenced by the crazy engine you're planning...
  38. Likes cgundermann liked this post
  39. #35
    May 2021
    Fort Worth, Texas
    Quote Originally Posted by Ltngdrvr View Post
    If you're like most other car guys, sanity ended a very long time ago...
    Quoted for truth.
  40. #36
    Aug 2019
    Paradise/Magalia Ca
    There is an actual reason for my madness
    originally, I was looking for 1000+ whp
    but then I saw this and decided that's what i needed to do
    and I called my engine builder (Will) when he informed me, he was friends with Kevin at m2k motor sports
    and was all over trying to help me do 300mph
    so off to the races
    and turn a club of 1 into a club of 2
  41. #37
    Aug 2019
    Paradise/Magalia Ca
    in car vid
  42. #38
    May 2019
    So, what aero enhancements will you be adding to get you close to that number???
    It'll take some major aero help to get you anywhere close.
  43. #39
    Aug 2019
    Paradise/Magalia Ca
    too much aero is bad at that speed the down force is so great you could literally push your car into the ground
    with the big wing that you see on joe's car 1700lb's at 160 i assume at 300 it would be roughly around 6000lbs of down force
  44. Thanks mmklaxer thanked for this post
  45. #40
    May 2019
    Without some added downforce, it'll lift and become unstable way before you reach your desired speed.
