Likes Likes:  8
Results 1 to 16 of 16
Thread: Under Dash ideas
    Member ADI's Avatar
    Mar 2021
    Under Dash ideas
    I want to place the Fueltech controller and battery main disconnect under the dash at the transmission tunnel.
    I searched the forum but could not find any thread about it.
    Does someone have any mods / builds about this? (basically adding a second dash at the tunnel to create a base for instruments / switches
    Mk4 IRS Coyote Gen3 6 speed, FuelTech control,
    Build progress:https://thefactoryfiveforum.com/show...s-Build-Thread
    Senior Member SJDave's Avatar
    Santa Clara, CA
    Here's an example of what I did, fabricated a sheet metal box, cut the tunnel aluminum off so I could remove the shifter area back without removing the new console. The console screws on to tabs welded to the frame rails. I can send you drawing of the console sheet metal to give you an idea how big and angles, but a starting point for you. PM with you Email and I'll send the drawing files.
    I added 3/4" thick marine plywood on the shifter section to add cup holders and clear the TKO; used the original aluminum on the bottom surface for fire protection.
    Love that dash!!
    Mk 3.1 #6616 Complete Kit, July 2008 Start, Gromm Racing 347, TKO 500, IRS, Carmine Red / Wimbleton White
    Mk 3.1 #6756 Complete Kit, May 2016 kit completion, Smeding Alum. 427 Stack Injection, TKO600, Custom Silver/Blue (SOLD)
  3. Likes Fman, BlueSilver liked this post
    Member ADI's Avatar
    Mar 2021
    PM sent! tks Dave, exactly what I was looking for!
    RJD's Avatar
    Northern Virginia
    While I didn't add switches or gauges, I made a console to house the radio and a cubby for sunglasses or phone. On the PS, there is a USB and cigarette lighter power port. On the DS, there is a latching door to access the battery main disconnect.
    ...and here it is right side up.
    Jul 2021
    So Cal
    Here’s what I did , added charger ports and a couple of switches.
    Brent Otee453's Avatar
    Mar 2020
    Topeka, KS
  8. Likes SJDave liked this post
  9. #7
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Are there any aftermarket vendors that are selling any fabricated under dash consoles?
    Forte's Axle
  10. #8
    I built a "Do Dad" to hold my stereo and most of my switches and it turned out pretty well...The only problem is my car is so freaking loud that I don't use the stereo unless we parked...It also hides where most of my wires enter the engine bay so it's pretty busy to say the least.
    https://thefactoryfiveforum.com/albu...chmentid=51774
    You can see how it turned out around 1:51 into my graduation video:
    https://youtu.be/9WEe6-wdNtA
  11. Likes nucjd19 liked this post
  12. #9
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    I made mine form some .040 and a basic harbor freight bender. I had just enough room to mount my master battery disconnect switch on it. I also used the vintage toggle switch bezel for accessories.
  13. Likes SJDave, nucjd19 liked this post
  14. #10
    Member ADI's Avatar
    Mar 2021
    Thanks guys.. very helpful!!!
  15. #11
    Oct 2020
    Albany, NY
    Quote Originally Posted by CaptB View Post
    Yes, Whitby makes one. Check it out on their site. If you like it PM me. I purchased one and never used it. I’ll sell it for half price + shipping
    MK4 #10008 - Ordered 10/06/20, Delivered 03/03/21, First Start 7/22/21, First Go Kart 7/24/21, Graduated 7/20/22 - Sold 6/6/24
    Build Thread https://thefactoryfiveforum.com/show...been-delivered
    MK4 - Ordered 6/5/24
  16. #12
    Folsom, CA
    adding my lower dash ideas to the mix
    knob in driver side is subwoofer gain
    usb chargers both sides
    seat heater buttons
    footbox fan buttons
    keyless start driver side
    Wilwood Electric Parking Brake on passenger side
    Alpine ilx-W650 touchscreen stereo
    Kenwood KAC-M3004 amp behind it all to power the 4 speakers in the car
    Todd
  17. Likes SuperFlyBriBri liked this post
  18. #13
    cv2065's Avatar
    Dec 2017
    Quote Originally Posted by toadster View Post
    seat heater buttons
    footbox fan buttons
    Toadster - What did you use to cut your dash holes?
  19. #14
    Raleigh NC, OIB NC
    Mine is pretty basic. Uses a Whitby consol kit. Easy to make with a Harbor break, but I did not have one at the time. Three versions using the same parts. Original with a radio, next the original with the AVH-4200-NEX. The third version is with custom gauges replacing the original FFR set. The vent pulls were also eliminated. Pretty much never used.
    Original version with radio.
    Second Version with the Pioneer receiver
    Third & current version also has custom gauges replacing the original FFR set. Vent pulls eliminated. Twin dual USB ports were added to the console.
    FWIW I used velcro on the under dash tray to hold the garage door opener, 4200 controller & Nano I-pods
    All versions have the main speakers in them.
    Tools were a step drill for small holes . An air powered nibbler to make the big holes.
    The kill switch is on the U-Joint cover. Easy to reach. I added a 10amp fuse to the switch to keep my ECU & 4200 alive when the switch is in the off position. Rubber shift boot was replaced by soft leather. Will not pull shifter out of gear.
    Kevin
    MKIV #8234
  20. Likes toadster liked this post
  21. #15
    Folsom, CA
    I used hole saws for the bigger gauges, and regular drill bits, step bits, and even small hole saws for the buttons
    high speed - light pressure, use a hepa vacuum and wear a mask - easy peasy
    Todd
  22. #16
    Jun 2021
    Sudbury, MA
    Switch source?
    The vintage style switches are great. Where did you source them from? Thanks! Joel
    Quote Originally Posted by Fman View Post
    Ordered Aug 2023; Delivery Dec 2023.
    MK IV Complete Kit w/ IRS, Forte SBF 427W w/Edelbrock ProFlo 4, TKX, Wilwood 12.88, Willwood EPB.
    Power steering, manual clutch
