Question to the Hive Mind. I have seen a few videos on catch cans for separating the moisture from the oil that occurs. I am running a SBF ( 347 stroker ). Would this benefit the engine regarding wear and tear or is this overkill on a vehicle that does not get a lot of miles? My rig is 90% street and 10%track/autox. Thank you in advance.
FFR MK4 Roadster (9945) complete kit, delivered 12/4/2020, First start and go kart 5/7/2021. Legal 8/14/2021, Paint finished 7/18/2022 (Viking Blue). 347BPE CI, TKO600, Moser 8.8 3link 3.55, Halibrand 17x9 17x10.5, power steering. Carbon Fiber Dash. Carbon Fiber trans tunnel, adjustable Kirkey Lowback Vintage seats, Vintage gauges, RT drop trunk mod, FFmetal drop battery mod and trans tunnel, Forte front sway bar. Forte mechanical throttle linkage, RT gas pedal. www.covespringsfarm.com
I've always vented at the valve covers. Effective but a bit messy as some oil does drain from the catch filters. A separate catch should work just as well and if plumbed well will be a lot cleaner. Engines need some form of venting; many assign this task to the PCV valve which works but has its own issues.
Jim
A good oil separator/catch can will reduce carbon buildup on the intake tract and back side of the intake valves. That nasty stuff in blow-by gasses that gets sucked into the intake is not good for your engine. Where legal, I route these gasses overboard like the olden days. But on emission controlled vehicles the legal option is typically an oil separator with an integral catch can. The muck that gets caught in the catch can is usually drained and properly disposed of at each oil change. It takes more than just a catch can -- the separation of gasses and vapor/liquids is the key to keeping this corrosive waste products out of the intake. I use a mishimoto system on my twin turbo Raptor that is well designed. Here's another product and there are many others: https://www.summitracing.com/parts/sda-555-3716
I have a small one on my firewall between my PCV and manifold vacuum source. Seems to remove some blow by vapor that you don’t want gumming up your valves.
I added this Moroso oil catch can to my PCV system when I installed my freshly rebuilt 347.
Thoughts on this one? While using break-in oil during the first 500 miles it’s separated some thing just under a 1/4 quart of oil. https://www.summitracing.com/parts/mor-85474
Mark
Gone but not forgotten. Mk1, Frame #1929 Complete restoration/upgrade.
Hey Mark,
Are you happy with the Moroso separator?
Also, glad we got to do dinner last week with you guys.
Hey Steve,
So far, at least for its first 500 miles it’s doing what it should be doing. I was a little surprised at how much oil was in the can. I would much rather have it in the can to be drained then have all that oil dumped into the intake. I likely am sucking way too much oil through the PCV then I should be. I’ll need to check the baffles as well as distance between the valve and baffles.
Also, off-topic but I have the Porsche information I couldn’t remember at dinner for your friend Mark. I’ll message it to you to pass on if you don’t mind?
Mark
Appreciate the info. I might head on over to summit and grab one.
Once again thanks for the excellent info and link. I appreciate it!
I've used JLT Performance oil separators on my Coyote builds and have been very happy with them. They make all different varieties including for SBF. Now J&L but the same products. https://www.jlosc.com/j-l-oil-separa...stang-5-0-302/.
Build 1: Mk3 Roadster #5125. Sold 11/08/2014. Build 2: Mk4 Roadster #7750. Sold 04/10/2017. Build Thread Build 3: Mk4 Roadster 20th Anniversary #8674. Sold 09/07/2020. Build Thread and Video. Build 4: Gen 3 Type 65 Coupe #59. Gen 3 Coyote. Legal 03/04/2020. Build Thread and Video Build 5: 35 Hot Rod Truck #138. LS3 and 4L65E auto. Rcvd 01/05/2021. Legal 04/20/2023. Build Thread. Sold 11/9/2023.
Basically an open system is better for your engine / worse for the environment. And always a little residue under the hood.
Closed system is worse for your engine / better for the trees.
I went with open as I had enough crankcase pressure to push my dipstick out at high RPMs. Terrifying when it looked like the engine blew. I also have a locking dipstick now. My 347 is a little on the radical end of the spectrum.
Truly, thank you fellas for your awesome responses. Looks like I am going to add this to the engine bay to improve engine life.
Mark, do you happen to have any pics of where you mounted it? I think I am going to also order one up, seems like it can only help.
Here's my Moroso mounting. I made a bracket to mount on the X frame member. I tried to keep it lower than the valve cover and intake to help the residue oil in the hoses, drain in to the can, and not back into the intake or head. This was all done on a completed car.
I've only done one oil change since adding the unit, (and I think it was on for only a few hundred miles), but there was no oil in the can, or at least not enough to drain down the drain tube. So either my engine has little blow-by, I didn't have enough miles on it to capture enough of the blow-by, or it's (hopefully not) not doing it's job.
If Brute Force doesn't work, you're not using enough of it. Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands. Extra Stuff: Stainless brake and fuel lines, Breeze cooling, Battery mount, SS Roll Bar. Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch. Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi. Graduation Thread
I have 3 vehicles with catch cans on them. One would fill the can, more than a few times between oil changes. The o=ring seal on the catch can forms a good seal. Even with lube on the o-ring, it takes a strap wrench to remove. I drilled, tapped and installed a quarter turn, ball valve in the bottom. It has a clear hose and feeds a water bottle hidden near the radiator.
My reason for posting this info, consider the kit with drain. Of course there is the option I used.
Travis, sorry these pictures are so huge and turned but I’m on my iPhone and just took the photos now.
Sorry it took so long to post these. The catch can is mounted directly to the passenger foot box at the top.
Mark
