Results 1 to 8 of 8
Thread: Gen 2 Waterfall install and vinyl
    Mar 2018
    Hello guys,
    I have the gen 2 waterfall. My kit is from 2018 and my car is a hybrid between gen 1 and gen 2. 😂 Right now I am in the process of attaching the waterfall to the body. The waterfall is already trimmed and ready to go. Where did you guys attach the waterfall to the body and what did you use. I am thinking rivnuts but wanted to make sure.
    Also, I will be installing the supplied vinyl to the waterfall shortly. I am using the Super77 adhesive. Is this hard to do? Any pictures of yours would help me a lot. Thanks
    Jun 2020
    SoDak
    I just used self tapping trim screws to attach mine. Drill a 1/8" hole and then let the trim screw self tap the hole. Worked great.
    Regarding Supper77 Adhesive, I'm not sure it's strong enough or if it will last. There is a lot of stretching installing vinyl on the waterfall and I recovered a door panel once on a mustang convertible that saw a lot of sun and the Super77 kept letting loose and bubbling due to the direct sun on it. Upholster shop told me the sun reactivates most spray can adhesives, he suggested I use Landau (made by Weldwood), great stuff, can be brushed on or sprayed on (gets applied to both surfaces), once stuck it's never coming off so be sure your material is where you want it to start. Been using now for 10 years, I'll never use anything else again.
    20201220_181243.jpg 20210508_112315.jpg 20210511_085251.jpg 20210512_073647.jpg
    Jim
    Jun 2018
    North Vancouver, BC, Canada
    I used Rivnuts along the top edge to attach to the body. Also attached the lower corners (by the door opening) to secure the bottom...
    You can consider not covering the waterfall and just painting it, that's what I ended up doing.
    Gen 1 '33 Hot Rod #1104
    Falmouth, MA
    I used the rivnuts along the top/rear wall and a couple more down low near the floor in front, then covered the waterfall with carbon fiber look vinyl.
    Ottawa Ontario
    Jim
    Nice! Is the top pad part of the waterfall or is it a custom piece? Thanks. Scott
    FFR #3870 MK II, Spectra Blue/Arctic White, 1974 414W, 10:1, Eagle 4340 crank and rods, KB Pistons, Ported Performer RPM 2.02 heads & intake, QFT SS-650, Comp XR282HR, Quality Roadsters pan, Crane ignition, TKO600, 3.55 gears, 3 link, SA QA1's, Breeze LCA's, Heim joints & VPM F/R bars, Power steering with Hiedts valve, Power brakes, Fortes bump steer kit, 5 bolt axels, SSBC rear brakes, Oil cooler, Pusher fans, Halibrand Cobra III's with Nitto NT555 G2 245/285/17
    Jun 2020
    SoDak
    Quote Originally Posted by johnnybgoode View Post
    Not sure about Gen1 but for Gen2 the top pad comes in the interior kit with the door panels, door handles & center pad between the seats.
    Jim
    Jun 2018
    Jim
    Yup, same with Gen 1
    Mar 2018
    Thank you guys. Much appreciated
