Results 1 to 2 of 2
Thread: WTB - 5 lug fox length axles
    Senior Member Todd Baumann's Avatar
    Howell Michigan
    Title says it all.
    Any condition, just need for mock up of a rear on my Falcon.
    Thanks in advance,
    Todd
    Todd Baumann
    FFR Build School Instructor 16+ Years Mott Community College
    FFR 2086 MKI, 22+ years on the road
    FFR 300 MKI Coupe
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Drivers side axles from an old Ford Ranger will work. Head to your local "Pick-n-Pull" yard.
    "To keep the stock rear wheel offset, the '83-'92 Ranger/Bronco II Left (driver) side axle (29-5/32") from a 4cyl or 3.0L V-6 with the 7.5" rear end, or '86-'97 Aerostar RIGHT side axles (29-5/32")"
    Ray
