Results 1 to 2 of 2
Thread: Exhaust Header Gasket Misaligned. Throw it out or re-use it?
    facultyofmusic's Avatar
    Feb 2021
    Sunnyvale, CA
    The gasket is misaligned with the header with about an 3mm offset.
    Can I loosen the bolts, align it, and re-tighten the bolts? Or must I get a new one because this one has already been "crushed"?
    Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
    I would loosen all the bolts and realign it. It will be fine
