05-02-2022, 04:41 PM
#521
Well #9365 (Otto) survived the winter OK.
Mother Nature actually got back on her meds and allowed us a reasonable Saturday a week or so back, and the cover came off.
A check of tire pressures, fluid levels, and turn the key. Went for a 60 mile run to visit a buddy and check on his C10 Chev Pickup build.
John D. - Minneapolis 'Burbs
06-18-2022, 09:40 PM
#522
New Addition to the 40 Watt Garage
A huge Thank You to my Chevelle Club buddies Chris S, Chris P, Bryan, and Mitch for giving up the better part of a Saturday to help me out.
Another Thank You to my wife for putting together some chow & cold drinks for us when we got home.
I scored a killer deal on a 4-post, but had to move it about 25 miles to my shop. Luckily both garages had 8' doors, but we did have to do some disassembly.
The lift move went off (really) without a hitch. We did eventually wind up on "Plan Revision 4.5", after exploring/trying the options. Maybe a pinched finger, but no-one got hurt, and no damage to the lift or either garage. Success!
What it came down to was removing the "Ladder Lock" nuts, the Cable retention nuts, and removing the top-plates of the posts. With this done we could Squeeeeek the posts (lifting just a touch/taking the weight) with a floor jack) under the overhead door frame/weatherstrip on plastic sheet sliders. Then a careful slow-dance up the ramps and onto the trailer. Rinse & Repeat on the other end at the 40 Watt Garage.
After the crew got it reassembled in the 40 Watt and "close" they hit the road, and I spent the next several hours doing the setup leveling and cable adjustments.
This has been a long overdue addition to the shop, and it couldn't have happened without the help of the my Northstar Chevelle Club family.
Post Thanks / Like - 0 Thanks, 4 Likes
06-19-2022, 08:49 AM
#523
Not a waxer
Nice John! Best of all you just made room for another project! Allow me to suggest an LS powered ‘35 Pickup. Your Chevelle club friends gave you a free pass on the Coyote Cobra but if you don’t get back into the bow tie fold they may be blackballing you 😉
06-19-2022, 02:01 PM
#524
Nice! I have the identical post to put on my build thread. I found a four post recently and my son and I picked it up with a uhaul trailer. It really wasn’t that bad to break down and set up. I did though have a bunch modifications I had to do to my door tracks and roof support. It’s really nice to get the roadster/El Camino up and safely out of the way, isn’t it?
Bradley
06-20-2022, 06:48 AM
#525
We didn't have to really "break it down"... just get it down to 94-1/2" to clear the door gaskets!
I hauled it on a flatbed car trailer. With the caster kit on the lift, we just used the onboard winch to gently bump it up. The legs didn't clear the trailer tires, so a floor jack under the crossbeam, up a few inches, over the tires, then back on the casters.
My ceiling is just under 10', and when I had the door replaced a few years ago I had them install the tracks as tight to the ceiling as practical (with a traditional opener). If I'd gone with a sidewinder/shaft drive opener the door might have gone up a few more inches.
06-20-2022, 06:50 AM
#526
Quit stirring the pot!!!
(I really don't need another hot rod with zero cargo space and tight quarters inside... although A/C would be nice... hmmmmmmm.)
06-20-2022, 07:21 AM
#527
Not a waxer
Originally Posted by
Fixit
The tight quarters excuse won’t fly anymore…the cab is being stretched about 5 inches so even the big and tall will fit!
Just stirring
06-20-2022, 09:50 AM
#528
I’ve seen them hauled that way, I didn’t have that big a trailer or the adequately sized cojones to try it. I’m hoping to get some swing out (carriage) doors as my overhead can’t be used when the car is at full height. I’ll post pictures later but you should see the ramp bolts that are nearly cut in half on mine. Apparently, the “professional installation” was none to concerned with safety as the the lift cables ran on top of them. Didn’t hurt the cables but the previous owner had no idea what was happening inside the mechanism until we took it apart.
I think you should take the truck, aren’t you running out if things to do anyway? My neighbor has a 1961 Lincoln Continental for sale. Suicide doors and unrestored with low miles and in very good shape - I can’t help but think, hmm…I do have more space now…
Bradley
09-12-2022, 03:01 PM
#529
40 Watt Garage is relocating
Well sheit!!
Lots been happening at the "40 Watt"... as in it's pretty much gone! The last few months have been selling a "up north" lake home, buying a "in town" lake home, selling the primary house (40 Watt Garage location), and MOVING 27 YEARS WORTH OF CRAP!!
The new house pushes all the buttons except having a crappy garage.
It is literally for parking cars, nothing else... no room for a bench - nothing. Caviat on purchase with the wife was "I get to build a shop to my specs"... "Agreed".
I have got all my tools, supplies, whatever in boxes and totes. The lift is sold to a buddy, the compressor is on a pallet, and I'm tripping over boxes and trying to find stuff.
Meeting with a builder tomorrow to finalize some details on a 32 x 36 shop.
09-12-2022, 04:19 PM
#530
Fixit
Well sheit!!
Wow, that's a big deal ... and a lot of work. I'm sure I could drive your car for you while you're so busy Seriously, good luck with all the disruption, drop me a PM when there's time ... intrigued by the 'in town' lake location.
Meandering, leisurely build thread is
here
03-20-2023, 06:23 AM
#531
The "New" 40 Watt Garage
I am so terrible about checking in over here on FFR...
Last November we broke ground on my new shop. Even with MN winter weather, progress has been steady (we have some tough tradesmen up here).
It's 32' wide, 36' deep, with 10'6" ceilings. I had to go around & 'round with the City on the final structure height, due to "sight-lines from the street" and height of the house rules, but we got it settled. The pictures take you from ground breaking to last weekend.
Post Thanks / Like - 1 Thanks, 2 Likes
03-20-2023, 06:27 AM
#532
The "New" 40 Watt Garage... pt. 2
The builders did an overall prime on the walls & ceiling, then paint on only the ceiling. Over the last week
Mrs. Fixit and I did the wall painting, and trim out on the electrical.
03-20-2023, 08:24 AM
#533
Just beautiful, John. Looks like a fantastic space! Congratulations on having all that work behind you - and lots of room for a new project!
here
03-20-2023, 08:46 AM
#534
Not a waxer
I've seen some of your updates on Facebook also John. It's looking fantastic and I'm really happy for you! Great call going with the floor heat; I considered doing that as well and have serious regrets for not doing so. One piece of advice...DO NOT START SANDING FIBERGLASS IN THERE! You'll never get rid of all the dust
04-18-2023, 05:48 AM
#535
#9365 survived another MN winter.
After a "fluids check", tire pressure check, and a dusting, I disconnected the battery tender, hopped in, turned the key, and VROOOM.
(I love that sound!! After all winter with no hydrocarbon therapy it is just fabulous)
Went for a 60 or so mile shake-down/warm up/smiles per gallon run, topped off the tank, and wound up at our local Drive-in restaurant. Every Thursday they host an informal "Cruise-In" for HotRods. All makes, models, era's, run whatcha brung.
That was last Thursday... 85 degrees outside!... Come Saturday we're at 31 degrees and it's SNOWING again! AAARRRRGGGGG
11-07-2023, 08:43 AM
#536
Fixit, I’ve got the same situation as with buying a complete IRS out of a 2022 mustang. Looking to reuse the cables and reading your solution. The one question I have is what did you use on the new end going into the hand brake? The piece you cut off can’t be reused, can it? Thanks, this is exactly what I’ve been needing.
This is what you wrote.
Mustang.
(I purchased a complete rotor-to-rotor rear axle assembly - a zero mile "take-out" unit - that included the springs, shocks, ABS sensors, and E-Brake cables).
Step 1 - using a lineman's pliers or big sidecutters, nip off the handle-end swedged knob on the end of the inner cable (NOT the end pictured above!) Slide the inner cable out of the sheath and set aside for later.
This should leave you with two outer cable sheaths something like this... Attachment 91141
Step 2 - Removing the un-needed mounting brackets. The only bracket you need to save is the one about 6" from the caliper - everything else can go.
Attachment 91142 Mark the bracket, and cut off the ear for the ABS sensor cable Click image for larger version.
ID: 91143Click image for larger version.
The brackets are very easy to remove from the sheath. Clamp the bracket in the vise, and use a BIG straight-blade screwdriver to coax the rolled area open
ID: 91145Click image for larger version.
ID: 91146Click image for larger version.
ID: 91147 When you're done, you should have a pile of brackets...Click image for larger version.
Step 3 - Shortening the cable sheaths
The chassis end "fitting" (grey plastic) of the cable sheath is not glued/swedged/whatever on the end of the sheath.
It is threaded onto the outer jacket, and is removeable (!). It is however Left-Hand thread. A really good grip on the sheath and a twist to the right will spin the fitting off the sheath (sorry, no detail pic of them off the cable).
- Remove the ends and test fit the cable ends in the holes on the frame mounting tab. (I needed to file the holes a bit for them to snap in)
- Remount the cables on the caliper end(s), and snake them cables through the frame, and through the mounting tab on the chassis.
- In my instance, the DS side went through the bottom hole, PS through the top.
Play around with this a bit, think about routing, clearance, smooth bends/radii, and potential hazards from suspension parts. Also consider locations on frame tubes for mounting a retainer clip or two for the cables.
- When you've determined your routing, mark the cable sheaths at the point where they go through the frame tab holes, and remove.
My cables wound up being 42" on the Driver's side, 36" on the Passenger
Measured from here (caliper end): Click image for larger version.
ID: 91150 to here Click image for larger version.
ID: 91151Click image for larger version.
I recommend using a hacksaw with a 32 tpi blade to cut the cable sheaths. There's the outer jacket, the metal core, then the inner sleeve. Go easy on it and they cut through very cleanly.
Re-install the grey end fittings on your newly shortened sheaths, and slide the inner cables back in. Install them on the car.
12-18-2023, 02:56 PM
#537
For the ebrake cable the bracket in picture 1 mounted to the spindle/knuckle top-did you tap the spindle hole or use a self tapping flange bolt in the existing hole? My spindle hole is not threaded. Thanks.
BUDFIVE
Complete kit order 8/28/2023
347 Ford Dyno 10/12/2023
Kit Delivery 11/28/2023
12-22-2023, 06:38 PM
#538
I was lucky to have a local hardware store (one of the old good ones... that has everything but space) that has an entire aisle with those pull out bins of "stuff". They had what I think were called "cable end stops" (Hillman). Basically a round slug of rod, hole through it, and a cross-drilled Allen set screw to pinch/grab the cable. A couple dollars.
All brackets used were OEM/as-received in their original locations from/on the Mustang cables, and secured to their OEM/original mounting locations. If yours aren't threaded, I'd probably use a a self-tapper hex-head flange bolt.
12-22-2023, 07:04 PM
#539
As you can see in my sig there's a question mark after "done"...
I scrounged these switch bezels from a couple of '65/66 Galaxie's wayyy back in the infancy of my build. Never got around to doing anything with them until now.
I had to do a bit of machining (lathe) on them to knock off the locating pin and centering "taper" on the back. I also had to do a little work on the retaining nuts for the switches, but I like the results.
A little "retro" to the dash.
01-22-2024, 03:37 PM
#540
John,
I like your frame dolly very much! Do you have plans for it? Would you do anything different?
Thanks!!
Craig M.
