Likes Likes:  8
Thread: Heater location
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Heater location
    I am getting ready to set up my FFR supplied heater. The heater is supplied by Vintage Air and looks like pretty good quality. My question is, has anyone changed the location of the heater? I am considering moving it closer to the passenger side; FFR suggests that it should be 6 5/16" away from the edge of the standard firewall. I have a Breeze Forward Firewall and I think I can move it about 3 or even 4 inches closer to the passenger door. Thoughts?
    My reason for this is I am trying to have the engine bay as bare a possible, but I really want a heater. Has anyone done this? I've seen boxes made to push the unit outward, but I don't think I need that, even with a glove box.
    Thanks for your info and pictures would be great too!
    Ted
    #10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
    • Order Date: September 11, 2021 - 20th Anniversary of 9/11
    • Delivery Day: April 1, 2022 - April Fool's Day
    • First Start and Go-Kart: January 20th, 2023
    • Graduation Date: July 4th, 2023 - Independence Day!!
    • Legal Registration Date: October 4, 2023 - My Birthday!!
    Visit my MKIV Build Thread (#10333)
  2. Likes Mike.Bray liked this post
    Lilburn, GA
    Are you installing wipers? The wipers can be pushed out until they are almost touching the 3/4" frame rail. Can't move it much. Without wipers, think about the heater venting tubes under the dash. How mush room do you need?
    Heater & Wipers - https://thefactoryfiveforum.com/albu...hmentid=105416
    I made a box to extend the heater into the engine bay. Note: The inside (under the dash) part of the heater is larger than the engine compartment part. The opening shown is approx. size of the dash side heater component, so you won't be able to move much more outboard. I moved it outward as far as possible.
    https://thefactoryfiveforum.com/albu...chmentid=65774
    Leave enough room to install the bulb seal at the top, to seal to the body.
  4. Likes Ted G liked this post
  5. #3
    Ted G's Avatar
    Aug 2021
    El Dorado Hills, CA
    Quote Originally Posted by Ducky2009 View Post
    Thanks David.... no wipers for me. And yes, after working on a mock up, I really can't move it due to the top of the inside part rising up about 1" and likely rubbing against the body. I guess, it goes where it goes. I like your bump-out mod, I don't think I'll need that with the forward firewall. I just may need to make my glove box a tad smaller.
    Ted
  6. #4
    Senior Member Fixit's Avatar
    Aug 2017
    Minneapolis 'Burbs
    Word of warning... double check/verify that the supplied hole template is accurate. In my case the larger holes for the coolant tubes were wrong on the template. Measure twice, cut once!
    John D. - Minneapolis 'Burbs
  7. Likes Ted G liked this post
  8. #5
    Jan 2022
    Seven Hills, OH
    I have a slightly different heater unit but you can check out my vids to see what I did. It is on the passenger side, out of the way as much as possible.
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  9. Likes Ted G liked this post
  10. #6
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Quote Originally Posted by Fixit View Post
    AGREE WITH THIS. The screw holes were off when I checked them before drilling. What I didn't do was check the round heater hose connects. It worked because the grommet covered the off center so whew! But, any cut or drill needs to be verified with the actual unit first.
    Forte's Axle
  11. Likes Ted G liked this post
  12. #7
    Lilburn, GA
    Quote Originally Posted by Ted G View Post
    Ted
    Ted,
    I didn't know about forward firewalls when I built mine, so I made the bump out so I could have a glovebox too. Had to make the glovebox myself. Only 4" deep, but enough to hold a little.
  13. Likes Ted G liked this post
  14. #8
    BadAsp427's Avatar
    Greeneville, TN
    I did the heater as well as the glove box. I have the FFR vinyl dash. This LINK to my build thread shows how I modified the glove box. I do not have the firewall forward option.
  15. Likes Ted G, toadster liked this post
