Thanks Thanks:  91
Likes Likes:  353
Page 10 of 28 FirstFirst ... 8910111220 ... LastLast
Results 361 to 400 of 1104
Thread: The race is on - Namrups 65 Daytona Coupe build
  1. #361
    Mar 2021
    Ohio
    Quote Originally Posted by Namrups View Post
    Like many others I have never attempted a project like this and am grateful to to other builders that have detailed their builds. I am paying it forward by detailing my build as well in the hopes it will help anyone else.
    I am also very grateful for the amount of time everyone in this community takes to detail things out for others to learn and plan to pay it forward as well, once I recieve my coupe in Octoberish time frame.
    On an unrelated note, what is everyone's thoughts on Mustang style gas tank vs something like a Fuel Safe fuel cell?
  2. Likes cgundermann liked this post
  3. #362
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Using a fuel cell never crossed my mind. I am going with the kit supplied tank and possibly a drop trunk. Haven't decided on that one yet. This might be a good question to start a fresh link on.
    Scott Pregont
    My Albums
  4. #363
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    Quote Originally Posted by burchfieldb View Post
    My understanding on fuel cells is they need bladder replacement every X number of years and are $$$, and if you're tracking then great do it, but if not tracking then nothing better then old reliable gas tank.
  5. Likes cgundermann liked this post
  6. #364
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Weekend build update
    Had a busy weekend. On Saturday I met with the Upstate Cobra Club in Lake George NY. There were a dozen or more roadsters (not just FF) and the one FF coupe. (you can see it way in the back) I was lucky enough to be able to ride shotgun in the coupe! We spent 4 hours driving the backroads in the Adirondack mountains. What a blast.
    Sunday was a local Mopar show put on by a local Dodge dealer that I also attended with the Challenger.
    I was able to get some work done on the coupe. I completed fitting and drilling the panels for the interior.
    Still waiting on a lot of the suspension parts so the next step in the book is the gas tank. I installed the in-tank fuel pump, (upgraded unit as described earlier in the thread) the fuel level indicator and the upgraded Breeze big vent kit. I did have to snip a little of the opening to get the in-tank fuel pump installed. Everything else went as described in the book and with the Breeze instruction manual.
    Scott Pregont
    My Albums
  7. Likes rhk118 liked this post
  8. #365
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Also installed the genuine Ford fill tube gasket. I also cut the fill tube as described in the manual and set it aside for installation later in the build.
    With the help of some friends we mocked up the tank in the chassis. AS shown below I did not have to use longer bolts as other have had to do.
    I was also able to mock up the location of the Trick Flow fuel filter before calling it quits for the night.
    Scott Pregont
    My Albums
  9. Likes rhk118 liked this post
  10. #366
    Nov 2021
    Portland, Maine
    Looking great Scott! Like your method of "fitting" the trick flow there. Did you need to flatten the seams/tabs on the gas tank to install (I think they are in the back?)?
  11. #367
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by rhk118 View Post
    Yes I did have to flatten the edges. Two in the back and one in the front. I also agree with what Paul did and ordered some 1/8" foam to put between the tank and the frame to keep it from possibly rattling or scraping. I will apply that when I put the tank in for good.
    Scott Pregont
    My Albums
  12. Thanks rhk118 thanked for this post
  13. #368
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    One step forward, two steps back
    Day 20
    One step forward
    During the last couple of days, missing most of the suspension parts, I decided to move ahead and start working on the pedal box. I painted the upper mount and the two switch clips and installed the genuine GM switches, not the FF ones.
    I mocked up the pedal box in the car and found that the cross brace might be off a little.
    My solution is to use a washer to fill the void so that I don't put undue stress on the bracket of the pedal box. If anyone see's an issue with this solution please speak up.
    One step back
    Decided to take a step back and work on the top panels of the foot boxes. I wanted to be able to get into both side so I decided to make them removable. (Thanks Paul)
    The full panel as supplied by FF.
    I only wanted to make part of it removable because some of it is under the body cowl. The ruler shows the location of my cut.
    Scott Pregont
    My Albums
  14. #369
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I cut the panel with a Dremel cut off wheel.
    The plan was to add a brace that will be attached to the fixed piece and support the removable piece. I picked up a strip of 1/16" x 1 1/2" x 36"aluminum at the local hardware store and cut it to fit.
    Drilled the pop rivet holes in both the fixed piece and the support strip.
    Painted the support strip.
    Panels finished. Very pleased with the outcome.
    Scott Pregont
    My Albums
  15. #370
    South Australia
    Neat job!
    Gen1 Coyote / TKO600 / IRS
  16. Thanks jbs72697 thanked for this post
  17. #371
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Second step back
    Was notified yesterday that FF was sending 4 boxes totaling 210 pounds! Arrived this morning.
    Steering rack!
    Front spindles.
    Rear spindles and hubs
    And the rear diff!
    And yes, most of the fluid had leaked out of the diff. What a mess.
    I also received 3/8" and 3/16" SS tubing from Summit.
    Now I can go all the way back to the beginning of the build manual and start all over. Can't say I don't have anything to do now.
    Scott Pregont
    My Albums
  18. #372
    Oct 2020
    Albany, NY
    I love receiving parts
  19. #373
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    After a very long wait I received my harness today!
    Spending the next ten days on a staycation with my daughter. Not sure what kind of progress I'll have.
    Scott Pregont
    My Albums
  20. #374
    Chino Valley, Arizona
    You are trucking along Scott! You go - looking fantastic!
  21. #375
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by cgundermann View Post
    Thanks Chris!
    Scott Pregont
    My Albums
  22. #376
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    The staycation with my daughter is going great. As she is a night owl and likes to sleep till noon, it has given me time to work on a few items. The painting of the suspension parts is going good and pics will follow soon. I have ground down the mold seams on the rear spindles and will have those pics after painting also. I cut off the piece per the manual and need to go buy a 5/8" drill to drill out the hole.
    I fabricated a piece to use to press out the existing studs in the rear hubs. Same idea as edwardb. Made from a 1" pipe nipple.
    Used my vice to press the existing studs out.
    The existing studs had a flat side to clear the hub edge.
    The replacement studs do not so I had to grind a flat edge for that clearance.
    I had purchased a wheel stud installer to use with a washer and lug nut. It worked great.
    Scott Pregont
    My Albums
  23. Likes Chopper liked this post
  24. #377
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Lug installer setup.
    I am using 1" spacers on the rear. The replacement studs are to long and need to be cut down after being installed.
    Spacer set in place shows clearance of the replacement studs.
    I have also started to print the alignment spacers for the NRG removable steering wheel unit.
    As a side note ..... to pay it forward for anyone that does not have access to a 3d printer, I can print the alignment spacers for you. I ask that, as a minimum, you cover the cost of shipping via USPS. PM me your address and I will check with the post office to get a cost. My printer takes about 5 hours to print the two pieces. I am not putting a price on these. Just send me what you think they are worth to you.
    Scott Pregont
    My Albums
  25. Likes Chopper liked this post
  26. #378
    Salt Lake City, UT
    Looking very clean and tidy. As an old friend liked to say, "that's the kind of leadership we're looking for."
  27. Thanks Namrups thanked for this post
  28. #379
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    First major screw-up!
    I was sitting in the garage in 90 degree heat painting my rear hubs and spindles when all of a sudden that light in my head lit up and almost blinded me! I had gone thru the process of changing the studs in the hubs and cutting them down to fit the 1" spacer. Measuring multiple times and picturing everything in my head because I was missing brake parts so I couldn't actually mock it up. Thought I was good to go. Wrong! Because I didn't have the Wilwood brakes I totally forgot that they would be between the hub and the spacer. I cut the studs too short!!! Will have to order new studs and repeat that process again.
    Scott Pregont
    My Albums
  29. #380
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Worked on getting the steering rack installed. Got it bolted into the frame without issue. Did not use offset bushings as others have used. Turned rack all the way to the right and marked the location. Turned it all the way to the left counting the turns and marked that location. two and one half turns lock to lock. Turning the rack back one and one quarter turns and marking the location marks the center of the rack.
    Now that the rack was centered I wanted to verify that the rack was centered in the chassis. I mounted a straightedge to the frame in the same location on each side.
    I verified that the rack was straight and level and measured to the start of the threads. The measurement was the same on both sides verifying the rack was also centered in the chassis.
    Set the overall measurement from tie rod to tie rod, based on the manual, keeping the same number of threads on each side.
    The front spindles and hubs are next.
    Scott Pregont
    My Albums
  30. Likes Chopper liked this post
  31. #381
    You're doing good Scott!
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Jeff. Moral support is always welcome.
    Scott Pregont
    My Albums
  33. #383
    Oct 2020
    Albany, NY
    I did that kind of thing so many times
    Good news is the second time you will really be great at it.
  34. #384
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Simple screw up. I know I will probably make more. Hopefully nothing too costly.
    Scott Pregont
    My Albums
  35. #385
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Day 30
    Ready to continue on the front end. Latest update on brakes is October so this will then go on the "to be completed" list.
    Scott Pregont
    My Albums
  36. Likes Wishfull liked this post
  37. #386
    Nov 2021
    I love the red.
  38. Thanks Namrups thanked for this post
    Likes Namrups liked this post
  39. #387
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Wishfull View Post
    I love the red.
    More to come .....
    Scott Pregont
    My Albums
  40. #388
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Before and after teaser
    Rear spindles and hubs before prep.
    And after.
    PS front suspension almost complete.
    Sharp eyes will notice that the tie rod is not fastened. I have misplaced (lost!) the castle nut. Also noticeable is the hub nut is loose. I do not have a socket that big. Back to the store!
    Scott Pregont
    My Albums
  41. #389
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    My neighbor stopped by on his way home from work today to check things out. Took advantage of it and between him, some ratchet straps and the engine hoist we installed the diff! It was challenging but not as bad as I thought it was going to be. Need to be nice to his wife the next time I see her.
    Scott Pregont
    My Albums
  42. #390
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Day 33
    Now that the diff is in and torqued I wanted to lay out and prep the rest of the rear suspension.
    Most everything is there except on the upper control arms. I'm missing the 1 1/4" lock nuts and the 4 1/2" mounting bolts that attach the UCA to the spindle. Also waiting on the CV axles.
    Scott Pregont
    My Albums
  43. #391
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Day 35
    During the prep stage I tried to fit the pieces together and found that they wouldn't.
    I measured the spindle at 45mm.
    The bar measured 43mm.
    Using the threaded rod process I spread the ears to 47mm.
    When the threaded rod was removed the ears relaxed to the required 45mm and slid into place without force.
    Mocked up the passengers side today. Look good. Tomorrow I will build the shocks and mock up the drivers side.
    Scott Pregont
    My Albums
  44. #392
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    It looks more like a car every day.
    Couldn't resist ....
    Scott Pregont
    My Albums
  45. #393
    Member slarson's Avatar
    Apr 2021
    Indian Harbour Beach, FL
    Wow! Tremendous progress Scott, nice work!
    Type 65 Daytona Coupe Complete Kit ordered 11/2021, delivered 7/25/2022....the fun has begun! Build Thread
  46. Thanks Namrups thanked for this post
  47. #394
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Received my wheels today.
    Scott Pregont
    My Albums
  48. #395
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Day 38
    Finished installing the rear suspension including the sway bar. Had issues with the sway bar that I will explain later. Still missing a few parts so it's not all torqued down yet.
    Next up is fuel and brake lines.
    Scott Pregont
    My Albums
  49. #396
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    A BIG HEADS UP!!
    I'm am not sure if this is a heads up for the roadster as well but if you are building the coupe with IRS and rear sway bar pay attention!!
    What I did..... on page 134 of the manual is the installation of the Toe Adjustment Bar commonly referred to as the toe link. The manual states that "If using the sway bar option, pass the bolt through the frame mount bracket when installing the toe arms". The picture shows the bracket in place. I am using the sway bar so I dug out the brackets and installed them as shown. I was not planning on removing the toe link so I torqued it to spec. After I had completed installing the rest of the suspension I decided to also install the sway bars even though I was missing the rod ends for both front and rear. Those are out in the open and can be added later. The manual does not have the install instructions for the sway bars but I was able to find them on the FF site listed under the roadster section. After pulling everything out of the sway bar box I noticed that in the bag of hardware for the rear sway bar there were 5/8" bolts. When I installed the toe link I did notice that because of the added sway bar bracket the bolt looked a little short but not having read any issues about it nor seeing anything in the manual I accepted it as ok. Lesson learned. The new bolts are longer and allow the nut to seat as it should so they had to be replaced. As you can see, by the following 2 pics of the replaced bolt, there is very little room with the rest of the suspension installed! It was a bear getting the original bolts out and the new ones in and torqued. One to two clicks on the ratchet was the max.
    Looking from the bottom
    Looking from the top
    WHEN ADDING A SWAY BAR TO IRS, MOUNT THE SWAY BAR BRACKET WITH THE NEW LONGER BOLTS WHEN INSTALLING THE TOE LINK! Don't do what I did....not fun.
    Scott Pregont
    My Albums
  50. Thanks rhk118 thanked for this post
  51. #397
    A BIG HEADS UP!!
    Good caution. Agree, easy to miss. The Factory Five instructions website (https://www.factoryfiveparts.com/instructions/) is a good source and should always be checked. Especially for options not typically shown in the build manual. I've frequently found what I needed there. Although to be fair, the IRS sway bar instructions you found on the website, in addition to showing the longer bolts on the exploded diagram, does say "Use the new included 5/8 ”x 2.50” bolt for the Toe link." Hate to point it out, and not being critical. We've all missed things. And paid frequently with extra work. Part of the experience, right? Your build is looking great. The red suspension is cool.
  52. #398
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Good caution. Agree, easy to miss. The Factory Five instructions website (https://www.factoryfiveparts.com/instructions/) is a good source and should always be checked. Especially for options not typically shown in the build manual. I've frequently found what I needed there. Although to be fair, the IRS sway bar instructions you found on the website, in addition to showing the longer bolts on the exploded diagram, does say "Use the new included 5/8 ”x 2.50” bolt for the Toe link." Hate to point it out, and not being critical. We've all missed things. And paid frequently with extra work. Part of the experience, right? You're build is looking great. The red suspension is cool.
    Thanks for the encouragement Paul. I really appreciate it. The red has come out even better than I had envisioned. Building these is like a chess match. You always need to be thinking moves ahead trying not to miss things like this. Even after reading your thread along with many others multiple times it's still easy for a first time builder, like myself, to miss stuff.
    Scott Pregont
    My Albums
  53. #399
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Played around with the brake and clutch reservoirs today.
    Option 1
    Option 2
    I'm leaning towards option 2. If anyone sees any issues with either option or has an option 3 please speak up!
    Scott Pregont
    My Albums
  54. #400
    Option 1
    Option 2
    Even with your SBF 427 (as opposed to the Coyote in mine, where neither option would work) anything on the outside of that frame rail will probably need to be moved out of the way to get the engine in and out. Plus (maybe) kind of in the way for maintenance, e.g. headers, spark plugs, etc. You wouldn't regret having them all inside the two frame rails and out of the engine compartment. But probably not possible with those individual mounts. Hopefully other non-Coyote builders can provide some feedback.
