Thanks Thanks:  5
Likes Likes:  39
Page 2 of 4 FirstFirst 1234 LastLast
Results 41 to 80 of 131
Thread: Budget LS Factory Five Roadster
    May 2013
    Normandy Park, WA
  2. Likes Qballz liked this post
  3. #42
    May 2013
    Normandy Park, WA
  4. Likes Qballz liked this post
  5. #43
    Aug 2021
    I better get in some YouTube time. New to the forum and getting ready for our build.
  6. #44
    May 2013
    Normandy Park, WA
  7. Likes CaptB liked this post
  8. #45
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
  11. Likes GoDadGo liked this post
  12. #48
    .Looks Like You've Got The Best Build Buddy Ever!
    He'll Always Be A Hot-Rodder From The Dark Side!
  13. #49
    May 2013
    Normandy Park, WA
  14. Likes GoDadGo liked this post
  15. #50
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    The only thing I have left on the POL is door hardware.
    Great work.
    FFR Roadster Delivered 9/16/21
    Forte 427 Fuel Injected with TKX Transmission
    Forte's Axle
  18. #53
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    Senior Member Jim Frahm's Avatar
    Jun 2017
    Cheney, WA
    Based on my limited experience, here's what I would have done differently:
    1st. If using a used motor I would at least replace the oil pump. It's a bit of an effort but not that much money.
    2nd. The LS engines are known for being oil leak free with the exception of the rear oil pan and the area where the front and rear covers meet the engine block/oil pan. I was told by the "experts" that you should install the front and rear covers first, then use ultra grey RTV where those covers meet the block and a very small amount along the sealing surface at the rear of the pan.
    3rd. If you decide not to change the oil pump, make sure you have good oil pressure after you get it running and replace the oil often during the first or second oil change.
    4th. This is the most important step,,,,, continue to have fun.
  22. Thanks mcannon12 thanked for this post
  23. #57
    May 2020
    I hate to tell you, but you should really consider taking it apart and starting over. You need the oil pan to be loose when installing the rear cover, then you use the alignment tool to get the cover centered, use a straight edge to get the bottom corners flat with the block, tighten the cover down, and only then can you bolt up the oil pan. Bolting the pan up first will pretty much guarantee you a leak from the RMS very soon after you start running it. Same goes for the front seal when you decide to take that off and put a big cam in it.
  24. Thanks mcannon12 thanked for this post
  25. #58
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
  31. Likes CaptB liked this post
  32. #64
    May 2013
    Normandy Park, WA
  33. Likes CaptB liked this post
  34. #65
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    Oct 2020
    Albany, NY
    Have you measured the top of your intake manifold cover in relation to the hood? I can’t tell from the video but you might have some clearance issues.
  38. #69
    May 2013
    Normandy Park, WA
  39. Likes Fman liked this post
  40. #70
    Senior Member JB in NOVA's Avatar
    Apr 2020
    Virginia
    Congrats on a big milestone! Just catching up with your videos -- they're very good! In your latest one, praying for lower FFR prices made me laugh out loud. Good luck with your current project, and maybe we'll be seeing you on TV one of these days.
  41. #71
    May 2013
    Normandy Park, WA
    Aug 2022
    Portland, Oregon
    Nice job on the videos, I am a little late to the party but 1 tip when working with the sheet Aluminum-When you have to cut an inside corner, when possible drill the corner to put a nice radius or use a rat tail file to round the corner. A straight corner on Aluminum will create a stress point for cracks to propagate from over time. I was watching the pedal install video when I noticed that.
    Also, I have not seen folks use a de-burring tool on the holes in the panels, just wondering if some of the experts think it is not enough value added for these. The exit hole can be pretty rough sometimes.
    I always do that when I bond a flat panel on my formula car.
  43. #73
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    Way to go! Nice work, I also enjoy watching your videos and progress.... Congratulations you will be on the road before you know it.
  44. #74
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
  46. Likes Barwickad liked this post
  47. #76
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
    Dec 2021
    Flower Mound TX
    Geez that a lot of wires! It has to be $1000 of copper there.
  50. #79
    May 2013
    Normandy Park, WA
    May 2013
    Normandy Park, WA
