Results 1 to 6 of 6
Thread: IRS Diff offset?
    Kingsland, TX
    IRS Diff offset?
    I've got a Gen1.5 chassis with the 2015 IRS. Does anyone else see the potential issue here?
    I don't have a driveshaft yet, and my trans is in pieces on the workbench right now, but this looks like a problem to me. Is the pinion supposed to be this far offset to the passenger side? It almost looks to me like there's going to be interference between the driveshaft and the "driveshaft loops" on the chassis.
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    The transmission and diff need to be offset so the needle bearings in the u-joints spin properly. Unless the driveshaft contacts something when it's installed, I don't see a problem.
    Jun 2020
    SoDak
    Keep in mind the drive shaft itself that will go through the driveshaft loop in the frame is only 3" in diameter and not the same diameter as the mating surface on the differential. I think you'll be fine.
    Jim
    Jul 2020
    Spencer, MA
    Yes! Offset is required for proper u-joint operation. All OEM factory vehicles with a driveshaft are offset.
    Jun 2018
    North Vancouver, BC, Canada
    Same configuration (Gen 1.5 chassis and IRS), no issue. Yes it ends up tighter on one side but still lots of clearance.
    Gen 1 '33 Hot Rod #1104
  6. Thanks TxMike64 thanked for this post
    Kingsland, TX
    Thanks Steve! This is the response I was hoping for.
