Thread: 33 Hot Rod Gas Cap Leaking
    Apr 2019
    My gas cap started leaking seems like not sealing well, is there a way to fix the fitment or any gasket it needs on gap? Or anyone know where u could get a new cap completely.
    Jun 2020
    SoDak
    It this a Gen1 or Gen2 33 HR? Is the "gas cap" leaking or the housing the gas caps screws into?
    My Gen2 has an O-Ring on the cap itself which is change able and then the housing has a gasket between the housing and the tank?
    If it's Gen1, I know its a different setup so I cannot help with that.
    Jim
    Jun 2018
    North Vancouver, BC, Canada
    A pic of the exact setup would be helpful as Jim infers.... there's been a few different ways/revisions of the years...
    Gen 1 '33 Hot Rod #1104
    Apr 2019
    Gen 1, and leaking through cap not the housing, can see a line of fuel running from it down the body
    Jun 2018
    Same location that I have mine installed, gen 1 with a Boyd tank.
    Question: I don't understand how can it be leaking, the fuel level doesn't sit that high.
    Apr 2019
    That’s what I was thinking. Seems like it driving hard the fuel spills out. With not even 3/4 or 1/2 tank still spills it thought the cap
    Jun 2018
    Maybe it's your 5G starts off the line
    The newest gas cap from FFR looks a little different but I don't know if it seals any better for your situation. Have you tried contacting them to let them know it isn't sealing, they may send out another....
    wallace18's Avatar
    Trenton, Florida
    Those 1st gen caps were glued together. You could try to use JB weld on the underside.
    16+ FFR kits and counting!
