Starter Solenoid
Need some assistance with the start wire connection please? I connected the solenoid start wire to the Y/B wire from the main engine harness and was able to start the engine but the starter continues to run when the key is off. I'm obviously connecting to the wrong circuit. Any advice on how top locate the correct wire to splice into? The Subaru wire diagram identifies a Y wire but that circuit does not work.
Thanks.
Mike Hemstreet
818s in Northern VA
