Results 1 to 5 of 5
Thread: 35 truck rearend what make an model 8.8
    Sep 2021
    I'm need information about what year rearend to use in a ffr 35 truck
    wallace18's Avatar
    Trenton, Florida
    2005-2014 Mustang V-8 rear end and rear brakes. 2011 -2014 V-6 rear end can be used but input flange must be changed. All this info is in 35 manual.
    16+ FFR kits and counting!
    The Factory Five website also explains an S197 (2005-2014 Mustang) rear axle is required. Has the proper width plus the proper upper connector for the third link. I got mine from Moser. Don't know about OE brakes because I chose the optional Wilwoods. Fit perfectly.
    Jul 2022
    Wellsboro, PA
    One other note for others on salvage yard rears for the years specified above : V6 cars and V8 cars with automatics usually had 3.31 gears. V8 cars with stick had 3.55 gears.
    Sep 2019
    Houston, TX
    If you go the salvage yard route, give the wheel flange a spin and count input shaft revolutions. It’s not unusual for a mustang to have been re-geared before it was totaled.
