Thanks Thanks:  15
Likes Likes:  216
Page 7 of 7 FirstFirst ... 567
Results 241 to 275 of 275
Thread: SS383 Build - 33 Hot Rod #1134
  1. #241
    Senior Member Blade's Avatar
    Apr 2019
    Dunlap Tenn
    I'm #1158. that would be great. San Jose is a bit far, but hey I love a good road trip....
    arrived July 18th 2019, first cart in Feb. 2020
    BluePrint Engines 383CI TKO600 GM Street&Strip
    Ridler wheels 17x 8 front 20 x 10 rear
    Toyo Proxes 245/35-17 front
    285/25-20 rear
    0mm offset finished Jan 2022
  2. #242
    May 2018
    Pinckney, MI
    Going back to move forward
    Been working on several areas that have been problem spots.
    After visiting Factory Five and talking about the build I got a set of the Ram Horns and new front pipes. Much better fit overall. The bolt kits provided with the Sanderson’s don’t fit. This version of the Ram Horn uses 2 short bolts and 4 long bolts. However, all of the bolt kits for Ram Horns have 4 & 4. So, I got to order a special set of bolts. Just weird that the bolts are wrong for their own header. I’ll replace with socket head cap screws and it will be good. 5/16-18 x 2.25 and 3 will work.
    Other projects was putting in the default bucket seats. I tried the Kirby (comfortable but not good for gettin in and out while touring). So next I tried PRP seats and they had promise, but were too narrow for my mature figure. So, while at factory five, we sat in the originals and ordered a set of those. I will be adding some kind of head rest as that is what got us on this path in the first place.
    The other change is to try some quieter mufflers. The sound would be great on the track but a bit too much for a closed car on the street. I’m gonna set it up so I can easily switch back and forth if desired. I’m trying Dynomax Super Turbo #17731.
    Next was to get the front end setup corrected. Factory Five updated the rear lower mount so you and use the lower holes to get some ride height. So they sent me the update and i redid the suspension mounts and worked to get the alignment close.
    A6AC561E-EA87-4A9F-8675-BF19BEE32605.jpeg F8047C9A-E074-44DC-BF9E-834CC0F65472.jpeg
    Next, I have been working out how to make the Gen 2 top look good on the inside. This is ABS with some wood reinforcement and hidden fasteners to hold it in place. The dome light mount will be covered in black vinyl. I’ll cover all of the inside with Raptor before it’s done.
    7216ED2F-DFB1-4761-A69F-AE74F42296C5.jpeg 9E8202D0-6C54-4B65-8FFB-2F4E1F96F829.jpeg
    I found a spring that I can mount to the latch that will open the hood enough to grab it but not enough to distort the hood.
    The gap between the cowl and the top has been another frustration. When I tighten the middle screw down, it twists the frame and pulls it away from the windshield. I squished some Tiger Hair between the frame and the cowl and we’ll see how that works.
    Lots more to do before paint this summer, but at least making progress.
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
  3. #243
    Senior Member Tampa33Build's Avatar
    Feb 2017
    Lutz, Florida
    Peter,
    Interested in how much quieter the Dynomax Performance 1773 are vs. the FFR ones. I installed Hedman Hedders 17104 - Hedman Hot Tips Chrome Exhaust Tips and it helped some however still a little too loud for long trips.
  4. Likes narly1 liked this post
  5. #244
    May 2018
    Pinckney, MI
    Hood support rod
    One of the little things. Used the trunk bracket and a bent piece of metal for the front clip. The 3D printed a receptacle to glue into the hood for the end of the rod.
    F91A98A9-47DF-4E33-939E-9475837B26AD.jpeg 8EAADDEB-42EA-4046-9CAA-8D67B0874BFA.jpeg A656C965-7F74-4779-B71A-E33642B92F9C.jpeg
    - Peterh226
    05 F-150
  6. Likes FF33rod, Straversi, 33fromSD, e36m3 liked this post
  7. #245
    May 2018
    Pinckney, MI
    Progress update
    Working on a lot of things to get closer to paint and reassembly. Facebook group is good for quick chats but not as a longer term record.
    Got the body back off the chassis and on my home page stand..
    Next, I’ve been addressing lots of little tasks (reroute brake line for running board support clearance for example). Been sanding and filling in holes as well as adding some metal plates for attaching covers.
    In order to finish up the wiring, I needed to complete some of the upholstery on the center console so went that way for a bit.
    E4FBD815-A5EF-43FE-9808-31F1776CEE1B.jpeg 5BD5EF56-1330-4A9D-A272-4E6DF8C999A5.jpeg BDCCBDE6-9D26-45BA-9C15-EC19C9B528A9.jpeg 8D0CB8B7-9AE1-4A58-9871-1DE6EB9E707B.jpeg
    All of the wiring seems good now as well.
    I switched from the mechanical speedo to electric sensor to the built in one on the side of the TREMEC.
    Started it up for the first time in 8 or 9 months. I really like the Dynomax Turbo Mufflers. Have to see when I can go for a drive what they sound like, but up on jack stands in the garage, they seem like they will be a good way to cruise…
    Now the bad news. My heater core failed. I had drained the water so I don’t know if some was locked in the core or if something else caused the failure. At least it happened now before I had finished the interior and painted body. So now i have another problem to solve.
    Never a dull moment in hot rod land!
    - Peterh226
    05 F-150
  8. Likes FF33rod, 33fromSD liked this post
  9. #246
    May 2018
    Pinckney, MI
    Quote Originally Posted by Tampa33Build View Post
    Peter,
    Just started it up with the Dynomax and they are gonna be MUCH better for a cruiser. Haven’t gone for a drive yet, but I’m very happy so far. I’m young at heart, but still have neighbors!
    - Peterh226
    05 F-150
  10. #247
    May 2018
    Pinckney, MI
    Addressing some of the million little things
    One thing that is really cool with this project is that you get to learn about all of the subsystems as well. Been working on a all sorts of little things.
    - switched to screw on electrical end for the magnum shooters for clearance and positive connections.
    - got the a/c working and charged. Thanks FFR for the help!
    - powder coated misc brackets (horn mounts, side panel/fender reinforcements.
    - prepped and painted the insides of several panels with Rhino liner
    - upholstered most of the interior panel and adapted to use hidden fasteners
    - designed, printed, and mounted the support for the front camera behind the grill
    8A9C653E-F742-4915-9EDA-7C950C619364.jpeg 6DA3A7A7-E886-4208-B02A-1A2A84176712.jpeg FE7B812C-4756-4931-8C64-08027A24C3E2.jpeg
    - Peterh226
    05 F-150
  11. #248
    Sep 2019
    Hi Peter,
    What length shaft did you order for the Mighty Wiper?
    Andy
    33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
  12. #249
    May 2018
    Pinckney, MI
    Mighty Wipers
    Quote Originally Posted by e36m3 View Post
    Hi Peter,
    Andy
    Hi Andy
    Here's what is on the order sheet:
    2 MWT158 1.5" taper shaft Mighty Wiper with short arm and blade
    2 XLong5 5 foot longer wire
    1 XSetCam set cam for opposite park position
    I'm very happy how they worked out even though I don't expect to use much.
    - Peterh226
    05 F-150
  13. Thanks e36m3 thanked for this post
  14. #250
    May 2018
    Pinckney, MI
    Body preparation
    Well, I’m learning some things not to do with painting…
    - the paint container systems are great if you shake it up with all of the pieces.
    - high build paint has a lot more stuff in it than you think. Shake and stir until you think you have it mixed and the start over!
    - a paint stir stick will make a hole easily in the paint liner.
    Here’s some images of the progression for the trunk lid.
    Here’s sanded down based on the guidecoat. 6A9CD61E-A7A0-4564-B3D8-5DA92F6C69D3.jpg
    Next, another coat of primer with guidecoat 091D5343-00F5-4DBA-95DA-58AB55706B6B.jpg
    I have at least one coat on all of these and some have since been sanded and are ready for another coat
    I’m getting better at laying down this paint, but may get some help with the color and clear so I can assemble this winter. I was hoping to do it all myself, but may settle on getting it ready for final paint!
    - Peterh226
    05 F-150
  15. Likes 33fromSD, Jeff33Ford, FF33rod, e36m3 liked this post
  16. #251
    Nov 2015
    Elverta, CA
    Peter, it looks like you are doing just fine with your prep. It's a real project to get it done to your satisfaction but i think you should continue to at least try and go all the way with the paint. I will remind you that I found that not a single painter in my area was willing to let me do the "prep" work and just have them spray the base and clear. They all base their reputation on the finished job and as we all know, if the prep is wrong, the finished paint will not work. They cannot guarantee the job unless they know it was done correctly which is code for they done it! It was either do it all yourself or hand it all off to a pro and write a big check that in my case was well overy $15k for a routine paint job. I chose to do it myself and although it was a major effort with lots of screwups, i was very happy with the final job and it was a great learning experience. Keep after it, practice a lot and you'll get 'er done. good luck/
  17. Likes Jeff33Ford, e36m3 liked this post
  18. #252
    May 2018
    Pinckney, MI
    Quote Originally Posted by Brave Salmon View Post
    My local guy stopped by to review my prep and see what the project looked like. He was pleasantly surprised with what I was doing and I'm going to get it all smoothed to at least 320 and then take it up to him to finish. Tape, seal, color, clear. Once it's done I'll fill in the details.
    So, next step is to get everything looking as good as I can.
    - Peterh226
    05 F-150
  19. Likes FF33rod, e36m3 liked this post
  20. #253
    May 2018
    Pinckney, MI
    Prime and blocking continue
    I’m getting better at all of this. Sprayed a couple of primer cups without incident, so that is an improvement.
    The fro nt nose cone was not as good as I thought. Blocking does not lie.
    92E03532-318C-4FC4-9779-4B653F7DF52C.jpeg B80D33F6-D0DD-4539-B042-DBB1D71DF34A.jpeg. D172E2C8-451C-4D40-8A6C-A7350B8E6087.jpeg
    Tomorrow get another coat on several pieces and then I guess take the doors apart! Maybe sanding later in the day. I like to make sure it dries.
    - Peterh226
    05 F-150
  21. #254
    Sep 2019
    Quote Originally Posted by peterh226 View Post
    The front nose cone was not as good as I thought. Blocking does not lie.
    Attachment 171658 Attachment 171659 Attachment 171660 Attachment 171661
    Hi Peter,
    The prep work looks really good. When I click on the attachments in your latest post I get the error invalid attachment.
    Andy
  22. #255
    May 2018
    Pinckney, MI
    Sand, fill, sand
    Got some more primer and the sanded and filled some low areas. Slow, but improving.
    CD584C85-29FF-49F8-8B7B-C33C2997B040.jpeg 30BC0605-D59C-4B2C-B70C-78D74719337E.jpeg B835CC9B-3486-4C06-9192-05CEF79D1C94.jpeg 884B8976-C8AB-4DDE-9704-E5B43B558DD5.jpeg 2E3E1CA8-D07B-4A65-9D81-7ECBE2A3851C.jpeg
    These are before my hours of sanding today. All smooth now anyway!
    - Peterh226
    05 F-150
  23. Likes svassh, 33fromSD, Jeff33Ford, e36m3 liked this post
  24. #256
    May 2018
    Pinckney, MI
    Doors. Everyone’s friends
    Doors continue to be one of the challenges of the build. I fit the door panels and added some rivnuts so they would be ok after paint. One of the panels (of course the dreaded drivers door) had some different spacing so I had to add some extra filler to adjust. Sanding inside corners is really hard to get them smooth. The aluminum to pieces for the windows also set some requirements for the top of the door to get it all smooth. Fill and sand and fill and sand. Starting to get the hang of this. More primer tomorrow the they will be done after the final sanding. It’s hard to see if it’s smooth when it is several colors.
    A3B074BD-00E5-430F-AC89-7F6A5066C257.jpeg 1E673A81-55F6-4C2F-94B0-8DC742F36727.jpeg
    Makes you appreciate what it takes to do a real pro job. Also, provides some real world experience to help decide which you-tube personality you want to pay attention to.
    Biggest hint so far: start to sand as soon as the filler will allow you to. It is so much easier before it turns to rock!
    - Peterh226
    05 F-150
  25. #257
    Jun 2020
    SoDak
    Looks good Peter. Get some Evercoat Rage Extreme body filler, it's the easiest stuff I ever worked with. I started using this stuff a few cars before the 33 (found out it also worked good on fiberglass) and am using it once again on my 55 F100 I'm currently doing.
    It's spendy, but as the saying goes, you get what you pay for.
    Jim
    https://www.amazon.com/Evercoat-120-...s%2C130&sr=8-5
  26. #258
    May 2018
    Pinckney, MI
    Jim
    I used that in several places. I agree it works great - especially if you sand it quickly. I'm using some glaze type filler now to get the pin holes. Doors have another cost of primer and now back to sanding that down. The end is in sight on the doors...
    - Peterh226
    05 F-150
  27. #259
    Jun 2020
    SoDak
    Your progress is looking good Peter.
    If interested Evercoat makes a good finishing / blending putty too which sands very easy.
    Jim
    https://www.amazon.com/Fibreglass-Ev...s%2C186&sr=8-5
  28. #260
    May 2018
    Pinckney, MI
    Ignition upgrade
    While I’m waiting for my finish painter, I’m working on lots of other details.
    I decided to upgrade to a hyperspark to complement the sniper. Also, since I changed to the Ram horns, the plug wires were not working so I took care of that as well.
    2169D37B-99EC-42C5-A62B-BAA27EBCC1C3.jpeg 56CF1800-05E7-426A-86CD-D3EEB2A189F7.jpeg 33D0F928-60AB-421A-AC78-450367A495FA.jpeg 192E925A-42C6-41BD-960C-C284291D40AA.jpeg
    - Peterh226
    05 F-150
  29. #261
    Jun 2020
    SoDak
    You'll love the Holley Hyperspark, I have it on my 70 challenger with the Sniper. It's been flawless for several years now.
    Jim
  30. #262
    Feb 2017
    Lutz, Florida
    I did the same with my Blueprint 400. Cannot understand why they sell an engine with EFI and a non EFI controllable distributor. Should at least be an upgrade option.
  31. #263
    May 2018
    Pinckney, MI
    Trunk Prep
    Got a good start on mounting the battery. That meant putting down some sound deadened and carpet where the battery is mounted. Figured that anything I can do around the trunk now will help. I still need to be able to bend the side pieces to get the body on easily.
    5E618965-8112-4EA1-B3EA-DDCAF40B0A01.jpeg 3762A218-38B1-452F-8C3C-D7D367900F2B.jpg 955F8246-F6C8-4F48-AB5A-921347634182.jpg B6D7C330-4648-4300-815A-6D93D940CA12.jpeg A2B91EAA-CA53-429C-84B2-ED7258EF30D3.jpeg
    Glued the. Center section of carpet to some quiet mat. Then poked the holes for the mounting bolts using a hot bolt to make good holes. Got most of the rest of the quiet mat installed. Progress!
    - Peterh226
    05 F-150
  32. Likes Just 1 More liked this post
  33. #264
    May 2018
    Pinckney, MI
    Front end redo again.
    Now that I’ve seen the instructions for the Gen 2 front end, I decided to rear down the front end and get it set up as designed. I’m also going to take advantage of this to get the parts powder coated. The provider used for some other parts a couple of years ago did want to parts with ball joints, so I’m looking for another one. The paint did not last on these parts so nothing to lose.
    Next spring should be good to go!
    - Peterh226
    05 F-150
  34. Likes Just 1 More liked this post
  35. #265
    May 2018
    Pinckney, MI
    Boots for Ball Joints
    Hi Folks
    While I make some adjustments, I'm looking at the boots on the front end.
    Upper Ball Joint
    The upper ball joint appears to be some manufactured version of a Moog K772 that was used on Chryslers from the 60' into the 80's. The boot below looks like the right replacement for the blue boot from FFR.
    UCA2.jpg Also, one of the ball joints is not really seated. That will not matter for function, but leaves less area for the boot to seat. UCA1.jpg
    Lower Ball Joint
    My best guess is that this is variation of Moog K8259 or K8749 that was used on a lot of Fords in the 70's into the 90's.
    I had some Energy boots, but they did not really fit. With the groove at the bottom, it looks like this boot might use a retainer wire as well. I had a reference for Energy 9.13130 and tried that boot (It has 13009 molded into it). But, I think there is probably a better fit out there.
    Do my ball joints look like yours? (That seems like a strange question to ask...) Any suggestions for the Lower Ball joint 'real' number? Any idea about boots?
    - Peterh226
    05 F-150
  36. #266
    May 2018
    Pinckney, MI
    Progress
    I’ve spent a lot of weekends traveling to watch my daughter play ice hockey and now into playoffs. Great family time, but not good for progress.
    Got the front end pieces all powder coated and reassembled to the latest specifications. Still need to complete the ride height and alignment again.
    Looks a lot better than they did with my scratched paint.
    The painter (Body by Mark) did just what it needed. Coat of sealer, color, and clear. Waterborne PPG. Red Velvet and Black. I’m happy with the prep work and I’m glad I spent all the time last summer.
    536786F7-F709-4963-B8E7-98F4D83ECE84.jpg 493BF256-9D58-4570-9EE0-D4C1A4DA153B.jpg
    Now all of the parts have been brought home and are all ready to begin assembly. If I need to wait until NCAA is over, it will be worth the wait.
    - Peterh226
    05 F-150
  37. Likes FF33rod, 33fromSD, Just 1 More, TxMike64 liked this post
  38. #267
    May 2018
    Pinckney, MI
    Final assembly - mating season
    The winch on the ceiling let’s me do this alone! I’ll add video at some point.
    607BE617-850B-4575-AB67-A73263608A1A.jpeg 53872685-B4AF-401D-A3FB-D31341D13CE9.jpeg 0B10B8A0-B859-4C1E-979B-09DA4698B4F6.jpeg
    - Peterh226
    05 F-150
  39. Likes 33fromSD, RoadRacer liked this post
  40. #268
    May 2018
    Pinckney, MI
    Details for assembly
    - Peterh226
    05 F-150
  41. Likes 33fromSD liked this post
  42. #269
    May 2018
    Pinckney, MI
    More final assembly
    Been doing a lot in the final assembly. Doors are still an issue. Parts don’t fit together quite like when I last had it apart not quite sure why there is a difference, but I’m committed now.
    I’ve had issues with the 3 link for quite a while. Finally determined that there are two problems. The lower control arms are too long (by about 2 inches) and that the frame does not have room for the driveshaft when the suspension drops. So I have ordered custom lower control arms (Gordon Levy) and cut on the frame. I added a 1/4 plate to the bottom to add reinforcement - bolted and bonded in place. Now the wheels are in the right place.
    - Peterh226
    05 F-150
  43. #270
    May 2018
    Pinckney, MI
    Show time and Sniper challenges.
    Finally solved several issues. I need to write a good summary of experiences.
    Solved the steering binding issue. Got the new lower control arms. Made it to Baker’s for a Sunday show and got an award! It’s neat to have people appreciate the efforts.
    On the drive home I could barely keep it running. Just made it home, but it would not restart. After new plugs and some discussion on the Holley forum, figured out one injector is operating all open or all closed. Not sure if electronic or injector but it’s off the car and back at its birthplace in Bowling Green. So no driving for a while. Drives easy and pulls like crazy from any speed in any gear. The Dynomax turbos are a great sound and volume. Still some tweaks to do, but now I’m looking for my next project!
    - Peterh226
    05 F-150
  44. #271
    Jun 2020
    SoDak
    Nice looking ride Peter.
    On the issue with keeping it running, have you thought about insulating your fuel lines with DEI vapor block fuel line sleeves and maybe header blankets to keep the heat down? Fuel Injection is definitely less susceptible to a fuel boiling / vapor lock because the fuel is moving at a faster rate, but under the right conditions it could exist. Wondering if some of your issue is heat related.
    DEI Fuel line sleeves = https://www.summitracing.com/parts/dei-010671
    DEI Form-a-shield heat barrier = https://www.summitracing.com/parts/dei-050519
    Jim
  45. #272
    May 2018
    Pinckney, MI
    Finally graduated?! links to videos
    Hi Folks
    I now have about 1400 miles on the car. Lots if stuff has made it hard to get many miles in the last year to two (Sniper and steering issues mainly). Took it to NSRA in Kalamazoo and it drove and ran well. Part of the way home was raining so I got to test the defroster and windshield wipers as well. Car is stable at highway speeds - anything between 70 and 80 was fine. I also was very glad that I switched to Turbo mufflers as the noise was OK for a couple of hour trip. I did end up using EarPods as I still could not hear the radio.
    It has been very interesting to get peoples reaction. The color combination and general appearance always get attention. Some purists only like steel cars. May people do not really appreciate the details, but that's OK. What I really have learned is that you need to build the car to satisfy your vision and desire. Going to some shows, driving the car, and the whole experience has made me appreciate the chance for me to learn and create something I'm happy with. I'm happy when others like what I've created, but that is just a nice extra.
    I have created some videos that are a tour of the car. Please let me know if you have any questions
    - Peterh226
    05 F-150
  46. Likes Salty Chief 35, FF33rod, JimLev, Ltfracing liked this post
  47. #273
    Sep 2022
    Huntington, IN
    Glad to see someone doing youtube videos of their 33 and pointing out the little things that make each one unique. Thanks for posting them. Maybe one day i'll do the same
  48. #274
    May 2018
    Pinckney, MI
    NSRA North
    I attended the and that experience (and Dave's 2024 sale) led me to start on the 35 Truck!
    I took part in the parade around town. That was neat for people of Kalamazoo to see a sampling of the cars that were at the event.
    I got to talk to a lot of people about the car and was pleased with the response.
    Gotta Drive them! It rained most of the way home (~100Mi) but that is part of the adventure!
    - Peterh226
    05 F-150
  49. Likes RoadRacer liked this post
  50. #275
    Simi Valley, CA
    Loved the videos - a nice summary of your build thread. I did lose audio in the middle segment of the Part 2 video. Still picked up a few useful nuggets, even without the commentary.
    Thanks for posting these! Keith HR #894
