Thanks Thanks:  3
Results 1 to 5 of 5
Thread: Where do you route rear harness out of footbox?
    Senior Member mmklaxer's Avatar
    Kennebunk, ME
    Before I turn these beautiful panels into swiss cheese, I'm checking in here to see where you route the rear harness out of footbox and down the tranny tunnel. I'm thinking the route highlighted in yellow will stay out of the way of the Coyote and power wiring. Planning to layout the Coyote PDB harness similar to EdwardB's well documented and clean layout. no need to reinvent the wheel..
    The typical routing of the harnesses is through the firewall. You need two or three holes per the harness instructions. I used three.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    The way you plan to do it is exactly how I did mine. You can see it in this photo.
  4. Thanks Moniz thanked for this post
    Kennebunk, ME
    Thanks both!
    JohnK, how did you mount your 250A fuze box to the panel? Can't tell if those are bolt heads or not. I'm trying to keep the cabin side of that panel as smooth as possible
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I mounted it on a small bracket that I fabricated:
  7. Thanks mmklaxer, toadster thanked for this post
    Likes toadster liked this post
