Results 1 to 4 of 4
Thread: Gen 3 Side curtain to quarter window seal????
    Dec 2018
    I am really struggling here. The gap between the quarter window and the side curtain is my problem. With out making parts, which I am not only willing but fully capable of doing, I am unsuccessful i piecing togeter a seal. The Rob Thompson set up does not work on a Gen 3. Any one got a solution? Pictures of said solution. I have found some seals on Steele Rubber Products website that might work but I hope the brilliance of the hive mind will spew forth the solution to me magically here. Anyone?
    Not completely sure where you're asking about. Maybe what I described in my build thread and yes I did fabricate some parts. https://thefactoryfiveforum.com/show...l=1#post375735.
    If not, maybe post a picture.
  3. Thanks rhk118 thanked for this post
    Dec 2018
    I have a similar idea. My problem is that the gap at the top is a little over an inch while the gap at the bottom is virtually zero. I will compare your photo with my reality and work from there. The "channel" pieces may be the key. Thanks for the in sight. Back to working on it now.
    Dec 2018
    20221015_214729.jpg Finally done.
