Thanks Thanks:  4
Thread: gauge visor too wide - wrong piece provided?
    Aug 2019
    Anyone else have this problem? It looks like the aluminum gauge visor provided by FFR is the wrong size - easily 2" too wide. could they have provided the visor for another kit model?
    That looks just like the one that came with my Coupe kit a few years ago. I didn't use it and don't have it around any more. But took some pictures when I was mocking things up and deciding how I was going to configure my instrument panel. Keep in mind the FF instructions don't have the HVAC duct on the front of the panel. They have them pointing down underneath. Which was one of several reasons why I didn't use it.
  3. Thanks BigShooter thanked for this post
    Junior Member MetalManiac's Avatar
    Oct 2022
    My visor was also wider than the cutout so I just made my own from aluminum. I made the new one so it re-uses the same holes as the cluster so I only will have 1 set of rivets
  5. Thanks BigShooter thanked for this post
  6. #4
    Aug 2019
    Paul,
    Have you noticed any glare issues with your gauges while driving without the visor piece? Are they still readable in bright sunlight? I like your idea of leaving it off since I'm doing my AC vents the way you did.
    Craig
  7. #5
    Quote Originally Posted by BigShooter View Post
    Paul,
    Craig
    I was going to mention that in my post but didn't. In three year of driving, I've never regretted not having the visor. There's never been a time where glare was an issue without the visor. The angle of the dash, the roof overhead, etc. make glare a non-issue in my experience. My opinion is the visor piece is mainly cosmetic and somewhat like the originals. No downside to not having it other than appearance IMO.
  8. Thanks BigShooter thanked for this post
  9. #6
    Edmonton Alberta
    Initially I thought the space between steering wheel and the visor was too tight for my hands so i did not install it. Then I put the adaptor in to make the wheel removable and there is more clearance but I still don't see any reason to install the visor.
    David W
    Mkll 4874 built in 2004
  10. Thanks BigShooter thanked for this post
  11. #7
    Mar 2021
    I too had issues with the depth of the visor, and needed to install the NRG quick release for an extra ~ 1" of clearance for my knuckles.
    To the post topic, that visor is the wrong visor - obviously too wide.
    I have some glare issues. Not with the gauges (which enjoy the benefit of the kit visor), but with the Holley Terminator X handheld that is mounted on the top of the tranny tunnel, and on my Alpine deck, which is mounted on the dash about dead center. I originally prototyped a smaller but proportionally equivalent visor to place over the head unit. I made a decision way back to upholster the dash with foam and leather. Wrapping the visor is a bit of a challenge. Wrapping an even smaller visor for the deck is a total non-starter (for me anyway), so I dropped the idea of that second visor. Oh well. If I were to do this again, I would build my own dash. FWIW
