Great fit on the doors!
I really like this truck… very cool!
Jeremie
Can you see me?
Yes, We Can See You!
Outstanding!
Day 41 - long night!
Day 42 - I am gonna call it ALL DONE...... still have to glue in the front and rear window and wax it and vacuum.... but..... we are DONE.... Will be standing by for the call from Scotty and we are off to SEMA!!! Here are some pics as I left it this morning - still dusty from all the buffing so as nice as it looks it is pretty dirty....
You did in 42 days what would have easily taken me 42 weeks; heck, more likely 42 months.
I'm sure the truck will be well received at SEMA, hopefully as well received as the Black Mamba.
Congratulations & Well Done Once Again!
Challenge accepted, challenge overcome!
Outstanding
Jeremie
Mission Complete
Well done - congratulations Erik!
Mk III 4880: 3:55 - 3 link, T-5, 347, Holley Sniper/dual sync distributor, Comp Cams XE274HR, Edelbrock RPM Heads
Hey all - just wanted to provide feedback that we did get a 6'6" 320 lbs gentleman into the truck and he fit!
Somethings that we (I) could have done to make the truck bigger on the inside -
1) put an automatic in it
2) I had the pedals up off the front firewall a little too much (mainly so I could drive it) -
a. could have just adjusted them with the mater cylinder rod to lower them
b. goning to larger master cylinder size to reduce pedal throw (would increase effort but they are pretty soft now) - and the larger folks will have "more" mass pushing anyway... I believe the stock pieces are 3/4 bore
All in all everybody who tried to get in the truck was able to get in it.... most said the seat was too low and too far back - all goodness!
Mission Success from a design perspective I think!
Would it be possible to stuff a 6R80 transmission in it (without modifications), behind a Coyote? Wife wants this truck, but for the sake of her own safety, I need to put in an automatic.
Not really relevant to the question, but my 2nd Gen Coyote and 6R80 did not fit in my 70 Mustang without tunnel surgery. The bellhousing area is very wide on the 6R80.
If you want, I can give you dimensions and pictures as my engine and transmission are currently out of the car.
If you can weld, you can make it fit.
Of course go for it if that's what you want to do. Anything's possible. My main caution is the foot space on the truck is already narrow. Widening the transmission tunnel, especially at the front by the bell housing, is going to make it even tighter. For driver with the pedals and also for the passenger.
I think it would "fit" - the issue of width on the 6R80 is only one aspect of the box - the 6R80 is also taller than the other boxes and wider in the hips... I don't think the foot box would be the issue rather the hour glass shape of the tunnel..... anything possible - and we can probably speculate some - but somebody has to be first- I think I was the first to put it in the coupe? I think even factory 5 said it was "probably" too big.... until you stuff it in there you won't know.... in my case I already had one to try.... and to say it "FITS" - well it does .... but just... and it takes a few modifications to get it in there so it's usable.... Paul is correct about the need to more than likely widen the tunnel - but I don't think that will effect the relationship between the gas pedal and your foot since that point is already the widest point of bellhousing mounts to the motor and if the transmission was any wider it wouldn't bolt to the engine.
I do have a 6R80 in the garage ready to go. I was going to use it in another project but have since decided to retire from building cars. I agree Erik. I do not think it will shrink the foot box, at the pedals, as that should already be wide enough to handle the engine.
What size is the tubing in the tunnel? I assume it is square. Depending on how much more space is needed, it might be possible to unitize the tunnel by splitting the tubing and reinforcing it with 1/16" plate. That description may be a bit vague. Basically, split the tubing in the tunnel and then take a sheet of 1/16" plate and weld it the length of the tunnel to restore the strength lost. If the tubing is 1.5" square, then that could gain 1.375" in the width of the tunnel with zero change to the interior.
About 12" from the bellhousing mounting face the tunnel to be 11" wide/high. How far off is that? That first 12" is a linear taper from the width of the engine to about 10.25".
In this thread there is a link to the dimensions of the 6R80 from Power by the Hour. PBH has some great Coyote and 6R80 swap parts as I have used a few.
https://thefactoryfiveforum.com/show...highlight=6R80
Hey Erik! I just sent you a PM about checking out the truck in person? I'm the guy in Huntsville that was originally interested in the '33 Hot Rod, back in September, but was told by many, that I was too tall for it...
