Thanks Thanks:  91
Likes Likes:  353
Page 16 of 28 FirstFirst ... 6141516171826 ... LastLast
Results 601 to 640 of 1104
Thread: The race is on - Namrups 65 Daytona Coupe build
  1. #601
    Quote Originally Posted by Namrups View Post
    One for the electrical experts
    The RF electrical installation manual shows cutting the relay wire for the fuel pump if using EFI.
    I have not done this. As seen in my recent first start video the engine started and ran fine. Is cutting this wire a requirement and if I don't cut it what do I risk?
    You only do that if you want to use the RF fuel pump circuit including the relay, inertia switch, and +12V wire back to the fuel pump. If you've already wired directly to the fuel pump from your Holly Sniper EFI system, technically not required to run your fuel pump. Only caution I'll cite is whether you have an inertia switch with your setup. It's a safety function that shuts down the fuel pump in the event of a hard collision or rollover. The RF fuel pump circuit wires that relay to ground through the inertia switch. If the switch opens, ground is broken, and the fuel pump circuit's power is cut off. Something to think about.
  2. #602
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    If I wanted to use the RF circuit with the inertia switch where would I connect the wire from the Sniper to? Right now I have cut the tan wire that ran from the fuse block to the fuel pump and attached the blue wire from the Sniper to the fuel pump. In order for the inertia switch to work should I cut the wire shown in the picture and reattach the tan wire from the fuse block to the Sniper blue/RF tan going to the pump? This has got me somewhat confused.
    Scott Pregont
    My Albums
  3. #603
    If you (1) cut the shorter brown wire from the fuel pump fuse to the relay, (2) attached the Sniper blue wire to the brown wire from the relay (not the one from the fuse), and (3) used the RF fuel pump wire to the back of the car and plugged onto the in-tank fuel pump, the RF inertia switch is functional. It means the actual +12V to run the fuel pump is coming from your Sniper harness but routed through the RF wire to the back. With +12V on the red wire to the RF relay from the panel, and the relay ground going through the inertia switch, as long as the inertia switch is closed the relay will be energized (e.g. closed) and complete the circuit to the fuel pump. Easy enough to test. Shake or bump the inertia switch so that the button pops up. Your fuel pump shouldn't run with the key on until you push the button back down. Assuming it works properly, the inertia switch needs to be mounted where you can reasonably access it with the button up.
    BTW, I'm a little breaking my own rules here. I haven't installed a Holley Sniper system. So giving this response only by looking at the Holly instructions. Seems straightforward, but no hands-on experience. The Sniper system is popular enough that hopefully others will chime in and either confirm or correct what I'm saying.
  4. #604
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    This makes sense to me now. I was confusing myself as I was looking at the PDF version of the RF harness installation instructions that shows a different picture and trying to match that to the actual RF manual and the Sniper diagram. As always, Thank You Sir!
    Scott Pregont
    My Albums
  5. #605
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Working towards first go-kart. Would still like to complete that before there is snow to contend with. It did snow here Tues. night but it all melted Thurs.
    Fixed the wiring issue noted above.
    I was using the kit supplied ignition switch for first start and have switched that over to the Digital Guard Dawg push button system. All wired and tested. Good to go!
    Also spent some time cleaning up the wiring behind the dash. Not as pretty as some. Still a ways to go.
    Ordered 1/8" Landau foam for the dash. That should be in early next week. Don't need that for go-kart but will be nice to complete. Mike Forte has told me the throttle linkage is complete and I should be seeing that soon also. Need that for go-karting!
    Biggest issue right now is heat for the garage. I had been using a kerosene heater but it is in very short supply here and prices have gone crazy. Lowes has a 2 1/2 gal plastic container for $36.00! Do the math ... that's over $14.00 a gal! Given that, I have recently switched over to propane. I have purchased two 2 - headed propane heaters and 30 pound tanks. Works as well as the kerosene heater, portable - I can move them around the garage easier and quieter. Works for me.
    Now that the weather has gotten colder I still plan on continuing to work on the car every day. Just not as long each session.
    Scott Pregont
    My Albums
  6. Likes slarson liked this post
  7. #606
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Things don't always go as planned!
    There have been numerous posts and threads about the challenges of building these cars. They are not "Leggo" kits. At times it takes creativity to find a solution to a problem. There is no more truth in that statement then when "things don't always go a planned".
    It's no secret that I have modeled my build after Paul's (EdwardB's) coupe build. I have used a number of the same upgrades and custom parts that he used. One such item was the Corbeau Evolution X seats. One of the first items I ordered after ordering the coupe was the seats. I received them before the coupe and had them put away.
    The plan was to mount them the identical way that Paul mounted his including the 1" high slider that he used so that I could eventually teach my daughter how to drive the car. She is shorter than I am and will need to move the seat closer to the pedals. Knowing I ordered the identical part numbers I didn't bother double checking anything earlier in the build. Why would I? It's the same stuff!
    Well things don't always go as planned!!!
    Getting ready to go-kart, in the near future, I decided to see if I could install the seats temporarily. I made up a pattern of the floor so that I could mark the locations for the mounting bolts. I attached a slider to one of the seats and worked it onto the car. Once in the car something just didn't seem right. I played around with it for a while and then decided to refresh my memory by looking back over Paul's installation.
    What I found was my seats do not fit the coupe the same way they fit Paul's coupe. Corbeau has either redesigned the sliders or has switched suppliers. The new design raises the seat almost 1 3/4" above the floor. Paul's sliders are only 1". This puts the top of the seat 3/4" higher. Paul noted in his thread that the seat top rests against the rollbar. Given this extra height, mine really do. That area of the seat is highly padded and it should not effect anything other than rubbing if the seat is moved back or forth. The bigger issue is the fact that the seat itself does not fit between the seatbelt tabs. In Paul's build he mentioned that the seats fit between the tabs and he was able to slide the seat back towards the back panel. I can not do that. Either FF moved the location of the tabs or Corbeau widened the seat.
    I still think I will be able to mount the seats with the sliders but it will be a tighter fit than I was expecting. I will post my solution as I figure it out.
    My reason for this post was threefold.
    First I wanted to point out that same part numbers may not mean the same parts. I have talked with Paul and verified we used the same part numbers.
    Second was the fact that I made a first time builders mistake and took for granted that my parts were going to fit the same way as others posted. I should have verified my seats fit much earlier. I would have had other solutions such as moving the tabs.
    Thirdly I wanted to point out that even the best plans sometimes go south. That is all part of these builds. It's our ability and the help of forum members and friends that can take something that is just not right and make "adjustments" to correct the issue and make it work.
    Thanks to all of the forum members and my local friends that have helped my in my build!
    Scott Pregont
    My Albums
  8. Thanks Windsor thanked for this post
    Likes rhk118, JimStone liked this post
  9. #607
    Member slarson's Avatar
    Apr 2021
    Indian Harbour Beach, FL
    Scott, thanks for the heads up. I have the same seats and sliders. I have not test fit them in the car yet.
    I will see how they fit in mine this weekend, that is just about next on the to do list anyway.
    Scott
    Type 65 Daytona Coupe Complete Kit ordered 11/2021, delivered 7/25/2022....the fun has begun! Build Thread
  10. #608
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by slarson View Post
    Scott
    Let me know what you find!
    Scott Pregont
    My Albums
  11. #609
    Apr 2021
    Scott, I didn't have a lot of time today. I'm having to replace a fence that Hurricane Nicole decided to knock down a few weeks ago (still not sure why she didn't like my fence).
    The first thing I noticed on the slides is the two washers and the large cap screw that is holding the slides to the mount. So I removed the washers and replaced the cap screws with some pan head screws I had lying around. That got the slide height down to 1 5/16. My thought is to use a flat head screw that is countersunk into the base and that will get the height down to about 1 3/16"
    I also flipped the slide release handle over so it's slightly angled up instead of down.
    It seems like my seat is hitting the inside seat belt mount, the outside diagonal bar and the head rest hits the roll bar.
    And the seat also seems to be angled to the outside.
    I don't like how the inner seat belt mount is behind the seat so the first thing I am going to try is to remove it. I will move it to the trans tunnel side of the aluminum panel.
  12. #610
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Keep me in the loop. I've already fastened my panels in here so moving the tabs is not going to happen.
    Scott Pregont
    My Albums
  13. #611
    Scottsdale, Arizona
    Here's some photos of my Gen 3 Coupe and mounting of the same Corbeau seats that you're mounting.
    I'll give due credit to Edwardb / Paul Borror who also mounted these Corbeau seats in his Gen 3 Coupe and provided many insights in his Coupe's build thread. Paul provided exceedingly helpful directly overhead photos of his seat mounts laying in their final place on the chassis. I used and verified those with my own seats and mounts and then took my own photos of the seat mounts in their final placement in my car. I created (and inserted below) a 4-photo collage of the seat mounts in the car both with the sheet metal laying in place and without the sheet metal. One key aspect is determining how/where to bolt the seat mount to the chassis. I've used 4 bolts with three mounted to the under-seat steel floor and a 4th thru one of the chassis frame tubes. The bolt heads face towards the ground and they feed up thru floating nutserts that are mounted in the seat mount. that 4th nut must be drilled and mounted yourself. the others are OK as is in the seat mount.
    Luckily, I was able to mount the driver's seat fairly straight in the chassis, with all aspects clearing the structure of the car. The top outside corner of the driver's seat headrest does make slight contact with the closest roll cage tube, but I affixed a small piece of Velcro (the fuzzy piece) to the tube with the fuzzy side against the seat vinyl. That should prevent wear and any squeaking. Regarding the passenger seat, it had to deal with a slightly different cabin structure and had to be mounted at a slight angle, but that shouldn't be too objectionable. Of course, I had to determine the thread size and lengths of the SS button head mounting bolts to be used. I also used a few hardened steel washers between the floor and seat mount to account for any gaps.
    Look very closely for positioning and alignments, as well as Edwardb's helpful photos inside the seat mounts;
    I believe that I did have to bend the outer seat belt attachment tab slightly outward to fully clear the seat.
    My Coupe is at the painter right now, so I can't make any further checks or new photos.
    I hope that helps.
  14. Likes rhk118 liked this post
  15. #612
    Quote Originally Posted by Bob Brandle View Post
    I hope that helps.
    Nice write-up Bob. And good job with the graphics. Clearly Corbeau significantly changed the slider brackets part number C22059 I purchased and installed in 2018. The same exact part number today has locks on both sliders (versus only one side before), a different handle, larger frame, and is slightly taller. I'm glad to see you could still make them work since several have chosen them based on my build thread.
    I'm still not clear if the seats themselves have changed. I'd be surprised if they did since Corbeau markets them for the C5 and C6 Corvette. But anything's possible. Mine fit between the seat belt tabs with just enough room to attach the seat belts. Tight but workable. And yes they contact the roll bar cage (which I noted in my build thread) but hasn't been a problem for us. We rarely if ever slide the seats and with three seasons of driving haven't heard any sounds or shown any wear.
  16. #613
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I hope that helps.
    X2 Great write up! Between Paul's excellent thread and your pics I am sure I can get these mounted. My only concern right now is the seat width and how far back I can position it. In the end I don't feel it will be a major issue because I'm only 5'-8".
    Scott Pregont
    My Albums
  17. #614
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Continuing to work on mounting seats while I wait for my throttle linkage.
    The best I can figure out is the following:
    PS outside rear at harness tab. Can't bring the seat closer to the tab because it is hitting the roll bar.
    PS outside front. Still slight space.
    PS inside front. Still slight space. Not a lot of room to slide forward.
    PS inside rear at harness tab.
    Second angle.
    Scott Pregont
    My Albums
  18. #615
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Third angle.
    Room on the side for the body to fit.
    Double checked to make sure the seat nor my head was higher than the roll bars. Check!
    Given the high temperatures in the 30's the past couple of days I switched to covering my dash. I live alone so I had no issue with doing this work on my kitchen table.
    1/8" Landau foam glued on with 3M Hi-Strength 90 contact adhesive.
    Marine vinyl over the top using the same adhesive.
    This is my first try at putting vinyl over foam padding. Is it perfect? No. Will it pass my inspection? Yes. What looks like a big bubble in the middle is actually a hole that will be cut out for the A/C controls. I'll leave it sit for a day or two to make sure it doesn't delaminate.
    Supposed to warm up a little so back outside tomorrow.
    Scott Pregont
    My Albums
  19. #616
    Jan 2022
    Referencing the TKX shifter placement issue a few pages back in your build thread, I'm also building a SBF Gen 3 Coupe, and was thinking of going with a TKX, but I'm not excited about cutting that crossmember if I dont' have to. Would the White Lighting shifter from American Powertrain have solved the issue? https://youtu.be/TiMYBghXnC0 It certainly looks like it would fix the shift lever placement with a 3" extension, but I'm wondering if there is enough vertical clearance between the shift mount pad and the bottom of the crossmember you had to cut for it to work? Just curious what your thoughts are for this as possible solution. Otherwise I might stick with a T-56.
  20. #617
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Not sure there will be room. It still looks too high and will hit the crossmember.
    The only way I can see would be to use the forward "midshift" kit but it might be too close to the dash then.
    Scott Pregont
    My Albums
  21. #618
    Jul 2021
    Quote Originally Posted by DesertSn8ke View Post
    I am also building a SBF Gen3 Coupe. I used a front shift kit from Silver Sport Transmissions. It clears everything, no cutting required, and with a straight 6" shift lever, position is good. I will get a picture up on my build thread in the next could days.
  22. #619
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Too late for me but I am interested in your pics. Might be an upgrade in the future and I'm sure others are interested!
    Scott Pregont
    My Albums
  23. #620
    May 2021
    Fort Worth, Texas
    Quote Originally Posted by GT_Rich View Post
    It is a pricey option, but I am going with it as well. Would love to see some pictures of where the shifter handle is located in the car.
    Namrups, just a thought. Looking at how close the seat(s) are to the bare floor. Are you going to have room to add insulation and/or carpeting? Assuming you are going to do that.
  24. #621
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Quote Originally Posted by Skuzzy View Post
    Very good question. I don't see room to use any type of heat and sound "mat" and carpet. Using the spray on heat and sound material (same as EdwardB's) and carpet should work. It will be tight.
    Scott Pregont
    My Albums
  25. #622
    Jan 2022
    Good info on possible shifter solutions. Curious to see pictures of the Silver Sport option. I'm very early in the build yet. Finished inventory, marking and pulling panels off. Haven't ordered an engine and trans yet so I have options. Just waiting on some quotes to come in.
  26. #623
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    GT_Rich has recently posted a video of his build with that shift kit. (427 SBF Coupe R Build) That looks like the way to go if you don't want to cut the cross brace.
    Scott Pregont
    My Albums
  27. #624
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Continuing to work towards go-karting.
    Mounted dash and fabbed a temp shifter.
    Also mounted both seats in their final location.
    Hopefully we can get the go-kart in before any major snow. Accelerator linkage is the last item needed.
    Scott Pregont
    My Albums
  28. #625
    Senior Member rhk118's Avatar
    Nov 2021
    Portland, Maine
    Looks great Scott! You did not waste any time! I can see into my future with the seating issue you had as am going the same way and noticed my seat mounts look different than Paul's as well, so will be tackling the very same issue you brought up, appreciate everyone's input there, will be adding my own once I get to that point . Can't wait to see what you do with the rest of the cockpit, I assume carpet? FYI those tires look bad *** to me....must be the zig-zags...
  29. #626
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I made the rookie mistake of not double checking. If I had, I might have been able to do something different. Moving the seat harness tabs out wider is the first thing that comes to mind. It might let the seats sit farther back. By the time I realized something was different I had already had all the panels installed. Not going to pull them back out. I'm only 5'-8" so even though the seats are closer to the wheel it is ok for me. With the sliders it will move it close enough for my daughter also. I did trim the RT directional mount as much as I could to move the wheel as close to the dash as possible.
    My plan is to use the Lizard Skin products covered by carpet. In the footbox areas I have used Duraliner and Dynaliner. I'm thinking about using felt on the roof instead of the FF liner.
    If I had it to do over again I might use 1/16" foam on the dash instead of the 1/8". I'm not sure I really like the way the switches and mounting screws bury themselves in the foam the way they do. At this point I'm just snugging them up enough to hold in place. Not tightening them down completely. I had thought about just using two layers of vinyl but I was afraid that any imperfection might show thru. The foam hides them.
    The tires are Falken RT615's. The Falken RT660's were highly recommended but IMO they are more of a track tire with less tread. I believe the 615's are more of a street tire and they were a little less expensive.
    Scott Pregont
    My Albums
  30. Likes rhk118 liked this post
  31. #627
    Oct 2020
    Albany, NY
    Dash looks fantastic Scott. It was my favorite part of the build. Starting to look like a real boy.
  32. #628
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Jesse!
    Scott Pregont
    My Albums
  33. #629
    Huntsville, Al
    Looking really good~!
  34. #630
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Thanks Eric!
    Scott Pregont
    My Albums
  35. #631
    I agree with Erik!
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I agree with Erik!
    Thanks Jeff! Appreciate the support!
    Scott Pregont
    My Albums
  37. #633
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    While waiting for my throttle linkage to arrive I started on the AC/Heat.
    Located and mounted the AC/Heater unit. If you look close you can see that I had to heat and bend the drain connection. No matter what I did I couldn't get the unit to clear both that drain and the AC fitting against the frame. The drain was plastic and with the heat gun was the easiest solution.
    Also mounted the condenser. This is not the kit supplied condenser. Following Paul's lead I went with the Vintage Air A/C Condenser part# VTA-03263-VUC from Summit Racing. A little pricy but it fits the radiator better. I used the kit supplied mounting hardware without issue.
    Scott Pregont
    My Albums
  38. Likes rhk118 liked this post
  39. #634
    Senior Member JimStone's Avatar
    Nov 2022
    Niles, MI
    Thank you for documenting your progress and providing insight into your build. I'm in the planning phase and this has been very helpful. Your car looks great! - Jim
  40. Thanks Namrups thanked for this post
  41. #635
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Received my throttle linkage from Forte today. Hopefully I can get it installed and maybe have my go-kart by next weekend if the weather holds!
    Scott Pregont
    My Albums
  42. Likes rhk118 liked this post
  43. #636
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Custom throttle install day 1
    After digging myself out after the 5" snowfall last night .....
    I started the throttle install. I laid everything out to take a good look at everything and so I could get a good picture of how this was going to get installed in my mind.
    I was very impressed with the quality of the parts. The kit comes with all the required rods and fittings, throttle pedal and thruwall mounting bracket. Unlike the Forte roadster system, this setup has all of the connecting rods outside of the pedal box. This required special milling of the thruwall mounting bracket.
    Throttle pedal
    Throttle actuating arm
    Thruwall mounting bracket. You can see how it has been milled.
    Scott Pregont
    My Albums
  44. #637
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    The throttle and actuating arm are both splined to eliminate slippage.
    The first thing I noticed was that the actuator arm has three adjustment holes. The problem was that they were too small to accept the 1/4" rod bolts to attach. Drilled them out using 1/4" drill. Problem solved.
    I decided to start the install from the Sniper and work back to the throttle pedal. Don't know if this was the right way to approach this but it worked for me. The second issue I ran into was that my fuel pressure gauge was in the way. I had installed it just to verify fuel pressure during first start with the idea of removing it anyway. Problem 2 solved.
    Scott Pregont
    My Albums
  45. #638
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    I have read others have added clips to the back side of the firewall to stiffen it up. I kept my mounting location as low as possible so that I didn't have to do that and it cleared the wiring I had already installed. I will be removing everything to drill for the thru pins and to make sure everything is tightened down so on this connection I did not add the large washer.
    Because I kept the crossbar mounting low I had to mill out the top of the footbox for the washer on the other connection seen here. You will also note in a later pic that I flipped the rod connection over for better alignment.
    In this pic you can see where the throttle pedal will come thru the side wall.
    And how it will look in the pedal box. IMO it is a very clean simple setup.
    At this point my arthritis started to lock my hands up due to the 27 degree cold outside. The garage heaters warm the garage into the 40's but everything you touch is still cold. Tomorrow I will mount the pedal/actuator, heat and sound barrier to the aluminum side panel. The cross bar will have to be removed so that I can drill for the guide pins. Once pressed in they will keep the arms from coming loose and spinning on the shaft. The shaft itself can also be cut down. After that it all can be permanently installed and I can go-kart!
    Scott Pregont
    My Albums
  46. Likes rhk118 liked this post
  47. #639
    Jul 2021
    I have to ask, what is the point of all that over just using the cable and pedal FFR supplies?
  48. #640
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Rear the following link: https://thefactoryfiveforum.com/show...anical-linkage
    Scott Pregont
    My Albums
