Results 1 to 11 of 11
Thread: FR 500 wheels MK2 Roadster
    Feb 2014
    I saw a great Black Friday deal on lmr. However, am I correct that on mk2 only 17x9s will fit on all 4 corners? That the 17x10.5 will not fit in back? Also, their website says 1994-2004 front spindles are necessary for front to fit? I believe mine are from an 89 mustang donor. Trying to swap out current 15x9 and 15x10 torq thrust 2s for the 17s. And I’ve seen a lot of roadsters on here have the fr500s.
    Thank you for any thoughts!
    Senior Member svassh's Avatar
    Apr 2021
    Highland Village, TX
    I'm running these on my MK2: https://www.factoryfiveparts.com/bla...-wheels-tires/
    I believe a PO may have modifed my rear wheel wells though.
    MK2 Roadster - 347 - Boss 302 Crate 4x2 Weber 44 IDFs
    Feb 2014
    Wow, those look great! Yes, definitely thought those could not would not fit on a mk2.
    Jun 2019
    CT
    You’ll need to modify the sheet metal and shock mount for 10.5” rims to clear on a MKII. Not too complex, but it’s been a long time, so can’t remember the specifics! I’m sure there’s threads on the other forum that can provide some specifics. Definitely worth it!
    FFR4462 - Taxed out of Connecticut
    If you live in CT, you need to read these threads on registration & taxation BEFORE purchasing a replica:
    https://thefactoryfiveforum.com/show...247#post442247
    https://thefactoryfiveforum.com/show...-Tax-Increases!
    Feb 2014
    Ok thank you, I’ll do a search on the rear mod.
    Search tor “315 mod” on both forums. It will explain the changes to the tubing and aluminum that are necessary to fit the wider wheel and 315/35-17 tires. In front you can use mid 1980s 5 lug Lincoln Mk rotors. They work with your existing Fox spindles, bearings and calipers.
    Feb 2014
    Thank you Jeff! I did a search earlier without luck. I’ll search 315 Mod, thanks for the help!
    Apr 2021
    This is a link I had saved, looks like what was done to my car. I assume this is what Jeff was referencing.
    http://www.norcal-cobras.com/project...e-clearancing/
    Sep 2020
    York, SC
    I have an mk3, I used the lincoln rotors. Only issue was the center caps. all else was perfect fit. I painted the grease covers and put a little cobra sticker on them. I really like the look. Also Im running 9" wide 17's up front with 245s. Back I understand the mk 3 is different that the 2 but I have the 10.5 17s with 315s. All on the black FR500's. I dont know if this helps at all but I am rooting for you. I did a ton of research prior to putting this package together. Oh changed the rear axles and got the 5 lugs back there. Easy job all the way around.
    Aug 2021
    Moyock, NC (OBX/Hampton Roads)
    And if you want some nice center caps...
    https://www.ebay.com/itm/184101179993
    MK4 Complete Kit #10315 / Coyote G3 / TKX / 427 HardTop
    Build Thread Production Date: 2/26/22, Registered 5/19/22, Graduated 3/1/2023
    Feb 2014
    Thanks for all the info! Probably going to hold off on doing the Black Friday buy until I decide on doing the 315 mod. As always, this forum is very helpful!
