Had to blow the dust off
Sounds Wicked E!
__________________________
Now that is one beautiful truck! Good job Erik!
Sounds sooo nasty!
hood scoop 2.0
here are some Hood 2.0 pics... The Air Scoop seems to drive people away... so... if you pull it off I went ahead and found a "hood scoop" that be bolted "pinched" on the hood to allow for two different looks on the same truck..takes about 20 minutes to swap it out.
Eric, what did you use for your running board protection strips, and how did you attach them.
Your truck is my inspiration.
Thanks, Ralph
they are stainless steel half round bars that we tig welded studs to.
Beautiful build, congrats. If you don't mind me asking, in the end, how does the truck ride with the 4 link? I'm looking to run wider wheels similar to what you have and already have a '94 rear end I can use. I don't mind doing the fab work but I am wondering how the ride would be with a narrowed SN95 3 link versus your setup. Have you had the opportunity to ride in each type?
It rode great. No issues
Looks great ! excellent job !
Erik
Just wondering did you change to 4 Link for tire clearance or was there another reason. Planning on building a 35 and planning on Tubbing it Maybe
