Thanks Thanks:  11
Likes Likes:  72
Page 9 of 11 FirstFirst ... 7891011 LastLast
Results 321 to 360 of 415
Thread: Street Rod Jim's 33 Hot Rod V2 #1143 Build - The Journey Begins
  1. #321
    Arizona
    Body Work Update #1 - Factory Five 33 Hot Rod V2
    33 Hot Rod V2 Coupe, Extra Clearance Hood, Bike Fenders, Rear Exhaust, LS Engine
  2. #322
    Arizona
    Body Work Update #2 - Factory Five 33 Hot Rod V2
  3. #323
    Arizona
    Body Work Update #3 - Factory Five 33 Hot Rod V2
  4. #324
    Arizona
    How to create a show car paint job - Factory Five 33 Hot Rod V2
  5. #325
    Apr 2019
    Jim,
    Glad you’re back! I enjoy your videos.
    Respectfully,
    Jeremie
  6. #326
    May 2018
    Pinckney, MI
    Hi Jim
    Been following along since I am at a similar stage as you are. I have done all the build primer and blocking and am having a local painter handle the seal, base, and clear.
    Watching your painter friend, I was surprised not to see you folks using gloves, respirator, and at some points eye protection. These paints are some nasty things.
    I like the Blue, should look really cool. I’m also hoping to get mine ‘completed’ over the winter.
    Keep up the good work!
    - Peterh226 #1134
  7. #327
    Sep 2019
    Quote Originally Posted by Street Rod Jim View Post
    [FONT="]Adding after market inserts to form the curvature of the 33 Hot Rod Trunk[/FONT]
    [FONT="]
    [/FONT]
    Hi Jim,
    What aftermarket inserts are you using to correct the curvature of the trunk?
    Andy
    33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
  8. #328
    Jun 2018
    North Vancouver, BC, Canada
    Quote Originally Posted by e36m3 View Post
    Hi Jim,
    Andy
    The "standard" for this is made my Tim Whittaker - Kootenai Valley customs https://kootenaivalleycustoms.com/ his web site doesn't seem to have the various products anymore but give him a call or email....
    Gen 1 '33 Hot Rod #1104
  9. Thanks e36m3 thanked for this post
  10. #329
    Arizona
    Hi Peter,
    I can only speak for myself, but it is a wind tunnel and I am up stream....with a respirator.
  11. #330
    Arizona
    Paint booth primer...
  12. #331
    Arizona
    Paint Booth - Color - Protonic Blue
  13. Likes Salty Chief 35 liked this post
  14. #332
    Arizona
    33 Hot Rod V2 Door Disassembly
  15. #333
    Arizona
    33 Hot Rod V2 - Taking the Body Off
  16. #334
    Arizona
    33 Hot Rod V2 - Show Car Sanding
  17. #335
    Arizona
    Clean and tighten up for final build
  18. #336
    Arizona
    33 Hot Rod V2 - Lizard Skin Firewall
  19. #337
    Arizona
    33 Hot Rod V2 - 33 Hot Rod V2 - Firewall insulation
  20. #338
    Arizona
    33 Hot Rod V2 - Interior Assembly Panels
  21. #339
    Arizona
    Factory Five 33 Hot Rod V2 - Interior Assembly - Weatherstripping & Seat Belts
  22. #340
    Arizona
    Rewiring the Dash Part 1
  23. #341
    Arizona
    Rewiring the Dash Part 2
  24. #342
    Arizona
    Transmission Tunnel Fitment
  25. Likes Salty Chief 35 liked this post
  26. #343
    Arizona
    Rewiring the 33 Hot Rod V2 Dash Part 3
  27. #344
    Arizona
    Painting Color on the 33 Hot Rod V2
  28. Likes Salty Chief 35 liked this post
  29. #345
    Arizona
    Rewiring the 33 Hot Rod V2 Part 4
  30. #346
    Arizona
    33 Hot Rod V2 Rewire Testing & Starting
  31. Likes Salty Chief 35 liked this post
  32. #347
    Arizona
    Factory Five 33 Hot Rod V2 - Fit and Finish - HVAC - Door Bushings - Steering Rack Limiter
  33. #348
    Arizona
    Factory Five 33 Hot Rod V2 - HVAC
  34. Likes Mrallsport32 liked this post
  35. #349
    Sep 2022
    Huntington, IN
    Can you tell me more about the bushings you used for you door hinges? Why the change and Where do you get them?
  36. #350
    Simi Valley, CA
    I don't know if Jim used the same parts, but I got Delrin door bushings from Tim Whittaker (http://www.kootenaivalleycustoms.com...i=316641034576). I saw somewhere that Tim was retiring, so you might want to call him before ordering.
    Keith HR #894
  37. #351
    Jun 2018
    SRJ rarely responds to stuff so I'll chime in - it's likely Kootenai Valley customs, Tim Whittaker. He has many parts to help make a build more robust and functional including trunk supports and other items. Some are more appropriate for gen 1, others more universal. https://kootenaivalleycustoms.com/ Web site has been a bit non functional as of late but has contact info
  38. #352
    Sep 2022
    Huntington, IN
    Keith HR #894
    Yeah, I talked to Tim back on Dec 19th and he told me then that he was pretty much done. He said he would see if he could put together a trunk kit for me and then I never heard from him again. I haven't tried calling him again either.
  39. #353
    Placitas, NM
    Best to call Tim.
    I bought his bump steering kit about a year ago. Very well made.
  40. Likes Just 1 More liked this post
  41. #354
    Sep 2022
    Huntington, IN
    Best to call Tim.
    Just got off the phone with him. Great guy to talk to. Unfortunately, He's done. Going to see if he can get me that trunk kit and door bushings, and maybe one or 2 little things he might still have in a box somewhere. He did say it definitely wouldn't be anytime soon though.
  42. Likes FF33rod liked this post
  43. #355
    Simi Valley, CA
    If Tim really is done, he may share the bushing dimensions with the Forum community. IIRC, Delrin rods are available from McMaster-Carr and a machine shop could turn the ID and OD and cut them to the proper length.
    And I agree that Tim is a great guy to talk to. He's very knowledgeable about FFR cars and freely dispenses build tips and techniques - especially if you are going to try something experimental. He once gave me a comprehensive hour long dissertation on how to build fiberglass parts, including detailed recommendations on materials, tools and techniques. Another time I got a similar tutorial on how to mount and align the body on the chassis.
    Keith HR #894
  44. Likes Just 1 More liked this post
  45. #356
    Arizona
    SRJ rarely responds to stuff so I'll chime in.
    Actually, I respond to everything that I see. I never got notification on this, but got the same question on the other forum and responded. And I also respond to actionable comments on the youtube channel where most of the questions come from.
  46. #357
    Arizona
    Factory Five 33 Hot Rod V2 - Permanent Installation - Tunnel & Panels
  47. #358
    Arizona
    Factory Five 33 Hot Rod V2 - Interior Insulation & Carpet
  48. #359
    Sep 2022
    Huntington, IN
    Keith HR #894
    Comparing the bushings to my Camaro, they look identical. I'll break out the mic and see what I come up with but they look like a standard GM door bushing
  49. #360
    Sep 2022
    Huntington, IN
    Found this on line for the GM bushings .380 in X .494 in X .363 in and .420 in X .532 in X .369 in
