![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
Coupe fastener pack where used list
I purchased a FFR Daytona Coupe complete kit with upgrades. I received my kit before the inventory software changeover. I am in the process of listing my full inventory at https://thefactoryfiveforum.com/show...ory-parts-list. I understand, from other posts, that the fasteners are now all grouped together on one list which makes it challenging to know where each fastener is to be used. BJBLOCK recently posted a list of the coupe fastener pack. I took this list and crossed referenced it to my inventory list and came up with the below "where used list".
Please note:
1) I do not know if the list posted was a complete list.
2) I do not know if it was for a complete kit or a doner.
3) I did not compare quantities of each part number.
4) I do want to note that my inventory has a number of fasteners that were not listed on BJBLOCKs list. Most of them metric.
5) I did not do this to point out any errors or omissions on the part of FFR! Nor to start a discussion about such. I did this to give others help in understanding where different fasteners are required.
Inv # Where used
12156 Coupe nose fasteners
A/C condenser components
10635 License plate light
Cooling system radiator mounts
10995 Inertia cut-off switch
Dash electrical components
A/C components
12768 Tail light components
Nose fasteners
80837 Cooling system
Nose fasteners
80414 Pedal box components
10851 Wiring harness mounting hardware
10984 Wiring harness mounting hardware
Fuel line components
Brake line components
Rear view mirrors
Driving light parts
Electrical completion components (horn mounting)
Radiator mount components
16857 Interior door handle components (listed as part # 60801 on my list)
12962 Heater control components
Interior trim
Secondary body fasteners
12780 Headlamp covers/fasteners
Rear quarter side windows
A/C duct components
10983 Interior trim
13979 Wiring harness mounting hardware
14627 Coolant overflow tank
A/C components
14464 License light bracket
14465 License light bracket
13325 Rear glass hatch components
E-brake handle fastener pack
13976 Seat harness fastener pack
IFS components
Steering system hardware
Alternate drive pully components
10834 IRS sway bar components
Transmission mount components
IRS shock mounting components
IFS components
12218 IFS components
Front sway bar components
10833 Polyurethane transmission/engine mounts
15138 IFS components
10842 IFS components
12386 IFS components
12332 IRS shock mounting components
25590 Transmission mount components
12337 Nose fasteners
10802 Battery tray components
Cooling system
Fuel tank components
Hydraulic clutch master cylinder kit
Brake reservoir components
11088 Battery tray components
16486 Speedometer sending unit
80539 A/C components
33524 Door latch/hinge components
15638 Pedal box components
12336 E-brake handle fastener pack
33696 Battery tray components
33688 A/C condenser components
15166 E-brake handle fastener pack
60519 Battery tray components
60520 Battery tray components
25461 A/C condenser components
15337 Interior door handle components
16779 Cooling system
13564 Door latch/hinge components
14725 Nose fasteners
13964 IRS sway bar components
A/C compressor assembly
10520 Steering system hardware
16665 Not on my inventory list
60343 Door latch/hinge components
11040 IRS sway bar components
11020 Not on my inventory list
60503 Fuel strap fastener
60381 Fuel strap fastener
Nose fasteners
12908 Radiator mount components
11005 Door latch/hinge components
Stainless Steel side exhaust
Steering bearing hardware
Seat mounting hardware
13963 Seat mounting hardware
IRS brake line parts
302/351W A/C kit
Nose fasteners
60589 Stainless Steel side exhaust
11024 Pedal box components
Nose fasteners
12776 Door latch/hinge components
15391 Seat mounting hardware
25562 Door latch/hinge components
60518 E-brake handle
11212 Accelerator cable components
12383 Nose fasteners
12382 Nose fasteners
12909 Door latch/hinge components
13965 IRS sway bar components
12338 Steering wheel hardware
12339 Steering wheel hardware
![Replica Parts](https://www.factoryfive.com/wp-content/uploads/2015/04/replicaparts.gif)
