# 1115 resurrection
A few weeks ago I put the word out that I was looking for an unfinished Factory Five Racing 33 Hot Rod kit. I got 3 responses, a Gen 2 Stage 1 kit in Missouri, A Gen 1 Stage 1 kit in the Carolinas and a Gen 2 Stage 2 kit in New Hampshire. The guy in Missouri turned out to be a complete flake, the one in the Carolinas was nice but a Gen 1, I really wanted a Gen 2. After a few e-mails and phone calls I made an offer on the one in New Hampshire and we made a deal. I offered to send a deposit and was told that wasn't necessary. He agreed to hold the car until Thanksgiving weekend and if I didn't show up he would move on to the next guy. Made me a little nervous only having a verbal agreement but he was a man of his word. Since I was driving to New Jersey to spend Thanksgiving with my daughter, a quick trip to New Hampshire would work out perfectly. I made the 14 hour round trip yesterday and picked it up.
Basic info, Build #1115
383 SBC Stroker rated at 425hp, 700r4, 8.8 rear w/3:73 gears. The engine is a new build off of E-bay and has never been run, never fired. The Trans is new from Patriot trans. As you can see, there has been a bunch of assembly but, I'm going to blow it all apart and do it my way .. lol
20221127_094832.jpg20221127_094851.jpg20221127_094904.jpg20221127_094920.jpg20221127_094927.jpg20221127_094949.jpg
Post Thanks / Like - 1 Thanks, 7 Likes
Good Luck, Happy Wrenching & Watch Your Pinkies!
great find. Let the fun and sometimes frustration begin. But we all get through it will a little patience.
Good find, nice to see he had the doors and trunk already trimmed to fit.
I think I had the doors on/off about 10 times before I was happy with the fit.
JimLev
Unfortunately, they're on the there but not adjusted or aligned and not so sure about the gaps.. this should be fun.. lol
What a find! Have fun with it.
Mastertech5
Thanks, I've enjoyed watching your build tread and learning from it.
I have my fits of rage at times. Like with the ECU power up wire if you read that. I spent half a day looking through the harness for it and it was coiled up with the diag. connector and accel. pedal wiring in the left corner on the floor. The instruction said to locate it in the harness and can be brought into the interior with the other two. Can be, to me, means find it and run it in with those if desired not when you run those in it will hit you in the face that that's where it is. Even though I was a Tech for 40 years the manual writers and engineers think everyone has an engineering degree and they'll understand. NOT����
Now that that's over with I'm glad you can learn from my build. If you have questions feel free to ask me here or on the sub-threads under 33 Hot Rod pertaining to your subject, which I've noticed you have done. Great group of people here willing to help.
Reason: Correct autofill errors
First thing was to pull the intake and see if it is a Hyd roller or not, and it's not. Ordering a Howards Roller Cam and Lifters, Advertised Duration 278/284, Lift .500/.510 and all the associated gaskets. So far i've purchased seat adjuster tracts, a Mike Everson fan shroud, a complete A/C kit and a 33 replacement grill. Spoke to Dan Ruth about some other misc goodies. He's winding down and not producing things like he used to so i'll have to source some things elsewhere. Need to get the body off and see what needs to be addressed. It's going to be slow process
I can't tell from your pictures. EFI or carb?
Mastertech5
Right now it's carb. I'm running a Holley Stealth Term-X on my Camaro and leaning towards that or an 8 stack multiport system like the Borla unit.
The eight stack looks so cool! My preference though. Old time Hot Rod look.
Parts are rolling in
Cam & Lifters
timing cover
Fuel Pump
Fan Shroud
seat tracks
Electric steering
A/C kit
Got the new grill from 33pizzaguy and it's nice. mocked it up and laid the hood on there. I love the 33 look so much better than the 32 grill.
Post Thanks / Like - 0 Thanks, 3 Likes
Radiator arrived today, mocked up the shroud and fan. Looks much better with the shroud and i'm sure helps the cooling.
20221226_211801 by F G, on Flickr
20221226_211741 by F G, on Flickr
Pulled the cam & lifters out and prepping for the new Hyd Roller set up
20221226_174352 by F G, on Flickr
You know about the bushing or bearing that needs to go on the front of the cam when converting to roller lifters, I hope. Keeps the cam from walking so the cam lobes stay in position on the lifters. I'd hate to see your engine get ruined.
Mastertech5
Yep, cam button and need to set to around 0.005-0.010 inch end play. Thanks, never hurts to have a reminder
Got the cam and lifters installed last night, measured and ordered new push rods. Set the camshaft end play only to find that the new fancy aluminum timing cover won't clear the short water pump. So now I need to re-do the end play with the stamped steel cover.
I'm worried about this engine, it seems very dirty inside for an engine that has never been run. Not sure if it's from sitting around in a very dusty, dirty area wherever it was sitting the past few years or if it's the typical e-bay engine deal. The entire car is covered in dirt so i'm hoping that's all it is. Going to wash it out with some cheap thin oil and a small brush and drain it... As many times as it takes until I feel better about it.
Was it a crate engine that was bought and shelved? By dirty, do you make rust scale, gunky oil build up, debris, what is the definition of dirty?
If it was supposedly a new crate engine, you take an engine builder line BluePrint Engines and they run an orange dye in coolant passages and I think blue dye in the oil to check for leaks while doing their initial start up / dyno test, then drain it and crate it like that, they never flush them. The orange is misleading cause it makes the initial water orange / rusty looking and there would be a bluish haze in the oil passages & valleys.
One way to tell if it was ever ran would be to remove the head and see if you have wear on the cylinder wall or a carbon ring build up at the top of the cylinder.
Ebay buys make me leary, I've gotten lucky and burned on eBay.
Jim
33fromSD
Jim
This wasn't "my" purchase, it was the original buyer/builder that I bought the kit from and came with the car. I knew it was a risk but I felt for the price of the kit, I could make it right if I need to. As far as dirty, I feel and see grit in the lifter valley. Put a magnet on the grit and it's not metallic, more like actual dirt. I was able to run it between my fingers and it kind of dissolved or broke down in to a mud, if that makes any sense.
Well Jim, In my infinite stupidity, It dawned on me tonight while cleaning the intake gaskets off the heads and thinking, dang, there's a lot of dusty dirty on the edge of these gaskets... I didn't clean around the intake when I removed it and all the dirt that was along the edges fell in to the lifter valley..
I gave the lifter valley a good bath and scrubbing with 10w-30 and i'll drain the pan tomorrow.
Just 1 More
Happens to all of us.
Jim
Flaming River Elec assist steering installed
20230102_150049 by F G, on Flickr
20230102_155818 by F G, on Flickr
I placed my order for a 33 hot rod last week. I just got my confirmation letter today. Can you tell me how to post a question to all 33 hot rod members? So far I figured out how to reply to a link, but do not see any tab to post a question. Thanks.
DanQ
You should see a "Post New Thread" blue button at the main 33 forum, but perhaps not yet because you're new. David (the admin) will likely have to push a button - DM him
FFR33 #997 (Gen1 chassis, Gen2 body), license plate DRIVE IT says it all!
build thread
DanQ
Dan congrats on ordering a hotrod. When you can post you will see this.
Frustration has set in... I knew I was going to have to redo some stuff and now that i'm in to it, I find myself getting very frustrated with the rabbit hole that's opening up in front of me, finding more of what I suspected and kind of expected but, that doesn't make me feel any better. The guy who started this project slapped it together halfazzed and skipped stuff like insulation and sound deadening in the floor aluminum panels.. Oh and the wiring that's just hanging or balled up under the dash. It started with, the cam replacement, which went good, then installing a March Serpentine drive with A/C & Alt so I can fire the engine... crank pulley wouldn't fit. Found out that FFR has a revision on the engine mounts and that moves the engine back a little, but not far enough for me, we're talking 1/8 - 3/16 more needed. I've got the engine back as far as it will go, the trans pan hitting the welded in crossmember that you cant get to because all the aluminium floor panels and trans tunnel have already been riveted in.. so start drilling out rivets,, but wait, there's a series of rivets that are behind the engine along the firewall.. Have to pull the engine to get to them.. grrrrr.. let's go to plan B, leave the engine where it is and break out the mini belt sander and take some off the steering rack mount bushing, That worked, but only gives me 1/8-3/16" clearance and you have to pull the crank pulley to remove or install the belt, I can deal with that. Now to weld up the re-fabd engine mounts. BUT, I really need to get those damn rivets out so I can pull the trans tunnel to get to all the wiring and fuel lines.. rant over for now..... to be continued
Just 1 More
I've been there - it can be done! I've used a couple of methods: a flexible drill extension and a right angle air drill - the latter is my favorite for tight spaces and I've ended up using it quite a lot.
build thread
Post Thanks / Like - 0 Thanks, 4 Likes
Post Thanks / Like - 0 Thanks, 7 Likes
Looks great! I have the same pulley system on my SBF
Gen 1 '33 Hot Rod #1104
Any chance you could post measured distance from front of balancer to back of rack. I'm hoping for 3.75 or more. I'm making plans for a truck with a 350 Chevy and from what I've been told 33 and 35 are the same firewall forward
Thank you
THUNDERSTRUCK
Thank you
I'm right at 3.75 to the rack mount on the passenger side, that I sanded down, almost 4 to the actual rack body.
Just 1 More
Thank You
Sounds like it will be close but will work. Have you moved engine back at all
THUNDERSTRUCK
Thank You
As far back as I could move it. Trans pan is now bumping the crossmember
Got the uppers in today, now waiting on the lowers
Looks like you'll have to remove those from the frame mounts to adjust. The ones I got have a double ended stud sleeve with 2 locknuts, similar to the front lower control arm rear, on each each of the sleeve so removal is not necessary. I also have bushings for the diff housing that look like the front ones on those arms. No binding. Are you getting adjustable lowers too. I was told by Mark Reynolds at Breeze that you shouldn't use those that he sells on a 4 link. You need the stability and give of poly or rubber bushings on a triangulated 4 link. I'm glad I got the uppers though because I adjusted them to the kit arm length before installing them and my pinion angle is too excessive so I need to make them longer to raise the pinion higher.
Mastertech5
These use the Ridetech "R" joint which have a cushion of sorts so it's not as brutal as a solid spherical heims joint.
BMR makes a replacement bushing for the 8.8 housing that uses a spherical insert. It eliminates the binding of the bushing.
The lowers will also be Ridetech "R" joints on both ends. Not sure why he suggested not using them on a triangulated 4 link. My 68 Camaro has a complete Ridetech triangulated 4 link with "R" joints on every rod end and it's fantastic.
I asked him if I used a panhard bar to keep things straight would be ok and he said no. Only use one on parallel 4 bar links. I can always change them out later.
