Mike Everson fan shroud mounting ?
I've got the fan attached to the shroud but now the inner nuts to hold the shroud to the radiator are not accessible because the fan is in the way. Anyone using this shroud, how did you do it? I can only think of putting 10-32 rivnuts on the shroud through a washer on the crush side.
Either nutserts or just 3/16 rivets. One in each spot.
Nutserts it is. All done, thanks guys! Backed up thin shroud with 18 gauge aluminum squares and JB Weld on the nutserts. I spaced it up from the rad using cereal box thick cardboard to keep it from rubbing on the rad from vibration. So I'm anal. I try to prevent future problems when I can.
