This appears to be a good place to install the water temp sensor for my dash gauge. Can someone confirm?
Jack
289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with EFI and close ratio TKX. First start 7/20/2023. First Movement 9/24/2023. First go-kart 9/25/2023.
Build thread - https://thefactoryfiveforum.com/show...rida-289-Build
That's a great spot. Unless you have a sniper then the sensor that feeds that needs to go there.
MK4 #10008 - Ordered 10/06/20, Delivered 03/03/21, First Start 7/22/21, First Go Kart 7/24/21
Paint by Metal Morphous 5/14/22, Legally registered 6/8/22, Graduated 7/20/22
Build Thread https://thefactoryfiveforum.com/show...been-delivered
Complete Kit, Ford 306, Sniper/Dual Sync, T5, Hydraulic clutch
Thanks. I am using a Sniper, but there appears to be another water temp sensor in the intake manifold on the other side of the distributor by the thermostat housing with the same type of 2-pin connector as the FFR sensor harness. I'm assuming the other sensor is the one BPE hooked the Sniper water temp harness to when it was dyno'd.
And, sorry, I didn't mean to put this in the Build section.
Jack
You will also need a place for a fan switch to go into the coolant flow. Correct me if I'm wrong but with a Sniper you need 3 locations - Fan Switch, Dash Gauge, and sniper or run a "Tee" to get 2 into one opening.
2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
I had the. Same question here just the sides reversed https://thefactoryfiveforum.com/show...-fitting-ideas
Sniper EFI has a wire to control the fan, so you only need two sensors
Yep, that is correct, you only need two sensors, with the Sniper controlling the fan. I just went through this ... and am using the two locations you have identified. I ended up with the Sniper sensor on the DS side, and the gauge sensor just behind the thermostat housing on the PS side. I was thinking they should have been reversed, but in talking with my engine builder and a very experienced mechanic, it seems it won't make much difference.
But with two identical two-pin connectors, make sure you don't get the sensors confused, because they don't have the same response curve. Ask me how I know.
