Thanks Thanks:  3
Likes Likes:  2
Results 1 to 18 of 18
Thread: Move the E-brake lever
    Senior Member MB750's Avatar
    Feb 2022
    Tampa, FL
    Anyone have any suggestions where and how to move it closer to the driver? I've seen enough pictures and heard enough accounts that the passenger side of the trans tunnel is not practical enough to use while belted in.
    Matt
    My build thread here
    Mines a totally different car - hot rod - but I went through the same thing. I modified my trans tunnel - here just for inspiration.
    https://thefactoryfiveforum.com/show...l=1#post428205
    Most seems to fit an e-stopp (?)
    On my own car as well as some that I've built for customers I've used a Mustang handle located here:
    Just a couple of simple 90 degree brackets bolted to the trans tunnel tube to secure the handle and then a piece of flat steel made up to attach the cables towards the rear on the driver's side.
    I use the FFR boot and make a bezel from 1/8" flat aluminum.
    Hope that helps!
  4. Thanks cc2Arider, MB750 thanked for this post
    Likes RoadRacer liked this post
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    Similar to Jeff's.
    I used Miata handle. But on the passenger side of the shifter.
    https://thefactoryfiveforum.com/show...-Parking-Brake
    facultyofmusic's Avatar
    Feb 2021
    Sunnyvale, CA
    I relocated it to the top of the trans tunnel on the driver sid e reusing the FFR handle. I used Wildwood cables tho. Here's the post: https://thefactoryfiveforum.com/show...l=1#post482320
    Mk4 Roadster: Gen 3 Coyote, IRS, T56 Magnum. Build thread here.
    Feb 2022
    Tampa, FL
    Thanks everyone. This is exactly the inspiration I need to DIY something on my end.
    Matt
    Senior Member Rdone585's Avatar
    Jul 2020
    Near Milwaukee, WI
    I used a Fierro brake lever to the left of the driver seat. It was a mod talked about a lot in 2003 with MKII builds. Sorry I didn't take any pictures of the build worth sharing. I did recently get a new custom boot for it, the original was in real bad shape.
    MkII: 408 Dart block dry sump, 750cfm carb, G-Force T-5, 8.8 rear with 3.55 gears, 3-link, Kirkey seats, black ceramic coated twister mufflers with shields and adjustable turn down tips, passenger roll bar, front and rear roll bars. 2020 GT500 Magnetic metallic, with white and lime green stripes.
    Senior Member Nigel Allen's Avatar
    South Australia
    It might be possible to move the handbrake to the left-hand side of the tunnel. I have a right hand drive car and having the handbrake next to me has never been a problem. It is an easy reach.
    Still, it is a bit of work to accomplish.
    Nigel
    Gen1 Coyote / TKO600 / IRS
  10. #9
    Feb 2022
    Tampa, FL
    Ideally I want it on the top, left side of the tunnel, exactly where Jeff has his. I've seen the Fiero lever, which is a neat idea, but I'm right-handed and would feel more comfortable having the lever to my right. On the outside chance I actually have to use it in an emergency, I'd like it in a familiar place where I can quickly reef on it.
    Matt
  11. Thanks Nigel Allen thanked for this post
  12. #10
    Dublin, OH
    I considered this but Fiero parts are impossible to find as well these days from my readings.
  13. #11
    Lobar EHB-7000F if you can’t find suitable Mustang or Fiero part.
    Lokar..
    358 SBC, Winters QC, Sweet mfg, Coleman, AP Racing, ARS, TKO 600, Fuel Safe
  14. #12
    Jan 2021
    Fort Lauderdale, FL
    I cut my E-brake brackets off and converted to Wilwood electric parking brake.
  15. #13
    Feb 2022
    Tampa, FL
    Quote Originally Posted by runamuk View Post
    That was my original plan, but then I realized I'm playing a bit too much with "house money" building this Cobra and need to reel in the extravagances a little. If I ever want to convert, I know it's possible.
    Matt
  16. #14
    Senior Member Scott L's Avatar
    Peoples Republic of Massachusetts
    I mounted mine on top to the right. Wanted to be able to reach it when I was belted in. I used a Lokar handle from Forte.
    FFR 5385 MKIII. 302, 3-Link. All legal in MA 1/7/2012.
  17. #15
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    What he said.
    Forte's Axle
  18. #16
    Nov 2021
    Texas!
    Quote Originally Posted by Rdone585 View Post
    "928" style, eh?.
    Rob Windsor
  19. #17
    Nov 2019
    Charlotte, NC
    I guess I have long arms, but I've never found it cumbersome to reach the e-brake at the standard location.
  20. #18
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    I mounted a Lokar handle to the right of the shifter on top of the tunnel. What I found was that with this lever I can't seem to generate enough leverage to securely set the brake. Definitely will not hold at all on any kind of slope, so with the trans removal and repair, I think it's going to be eliminated, and replaced with the E-Stopp. "C:\Users\rick\OneDrive\Pictures\20201208_171929.j pg" Sorry, that didn't work to install the picture. I'll try again. 20201208_171929 by Rick Paul, on Flickr
    Rick
  21. Likes theidlemind liked this post
