0
0
FFR front spindle install question.
After 7 months I finally received my front spindles for my coupe kit and I am having trouble with the install. When I attempt to screw on the castle nut for the upper ball joint, the ball joint just spins with the nut and it doesn't go any further up the threads. The manual say to torque to 75 ft-lbs. I have no idea how will get to that torque spec when the ball joint spins so freely just trying to get the nut on. I am using the Howe racing ball joints instead of the FFR provided ones. Is there a set screw or something that is supposed to be used to hold the ball joint in place while torqueing to spec?
Thanks in advance.
V/R
Shakey
Did you put loctite on the BJ threads and torque it down tightly?
Sounds like you may be describing the tapered ball joint stud is turning in the spindle? (If not, ignore the rest of my post...) The Howe ball joints are relatively free-turning compared to OE style ball joints. It's necessary to get the spindle tightly wedged onto the ball joint stud to keep the stud from turning. But I personally haven't found that to be difficult. The castle nut should turn on the threads easy enough. Once it starts tightening, the stud is wedged in enough that it doesn't turn. Is it possible you're running out of threads before the stud is tight in the spindle? I found it necessary to add a hardened washer under the castle nut. Seen in this picture. These are the Howe ball joints.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Not a waxer
You need to get the tapered ball joint stud to seat or wedge into the tapered hole in the spindle so that it resists spinning. Easiest way to do this is with a whack from above.
EDIT TO PAUL: Once again we’re typing at the same time
Originally Posted by
Jeff Kleiner
I left out the whack part, but agree sometimes that's needed too.
Build Thread and
Video.
Build Thread and
Video
Thanks everyone for the comments. Got it solved. Looks like to upper ball joint was not fully seated in the spindle. That plus the grease I added made it really easy for the ball joint stud to just spin. I cleaned off the grease and made sure the tapered studd was fully seated with a little force and the nut went on just fine. I did use the washer with the castle nut that came with the Howe ball joint.
Thanks again,
V/r
Shakey
