Test fitting the 289 body
Getting ready to test fit my 289 body on rolling chassis/go kart. Do the 289 bodies have the same fitment issues as the 427 MK4’s? Such as trimming the dash and rear cockpit rolls, needing to trim the fire wall or rear aluminum? Are there any 289-only issues? Did you test fit with or without bulb seal? Thanks…
