Thanks Thanks:  15
Likes Likes:  60
Results 1 to 40 of 79
Thread: Colorado Cobra build - Engine pictures--Little bit of eye candy
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Link to last post.
    I ordered my kit last year and it should be delivered around the first week in May. The community helped me a lot with my build planning and I just pulled the trigger on my brakes. Here is my current BOM and I will finalize it shortly.
    COSMETIC/Interior
    16613 - Powder coated chassis – Black, includes powder coated driver’s side roll bar
    12070 - Body with cut-outs of side pipes, body mounts, lighting accessories, gas cap, roll-bars, windshield posts, and side louver openings
    16004 - Vintage Factory Five/Smiths Style GPS Gauges (mph)
    12469 - Brake Duct Wire Mesh, preformed
    15635 - Center Dash Support
    15760 - The 14” Leather Steering Wheel Upgrade
    16808 - Trunk Gas Strut Kit
    17138 - Dash Components
    Stoneleigh Intatrim seats https://intatrim.co.uk/products/stoneleigh/
    Breeze Roll Bar Parts Kit, 1-3/4", Carbon Steel × 2
    FFMetal Firewall Forward Kit
    FFMetal Fat Tire F-Panel
    i.e. 427 Drop Trunk
    i.e. 427 Turn Signal Modification
    Hardtop
    Clutch:
    34158 - Hydraulic Clutch Master Cylinder Kit (requires customer supplied slave cylinder and hydraulic throw-out bearing)
    Front Suspension/Power Steering
    16799 - Power steering kit (requires pump and bracket)
    12066 - Standard Width Tubular Front Lower Control Arms
    16116 - Front Swaybar
    Brakes:
    Wilwood AERO6 Big Brake Front Brake Kit - Red Powder Coat Caliper - GT Slotted Rotor Levy Racing
    Wilwood AERO4-MC4 Big Brake Rear Parking Brake Kit - Red Powder Coat Caliper - GT Slotted Rotor Levy Racing
    Rear:
    16668 - 2018 Mustang IRS 3.55 Center Section, Spindles, and Hubs
    17120 - 2015 Mustang-based Independent Rear Suspension Kit with KONI coil-overs, tubular control arms, and CV axles
    15945 - 2015-2017 Mustang IRS Manual Driveshaft Adapter
    Engine/DriveTrain:
    13083 - 302/351W Mounts
    16038 - A 31 spline driveshaft for 302/351W with Tremec TKX/TKO transmission and 2015 IRS
    Metco Driveshaft Safety Loop, Factory Five Mk III & Mk IV Roadster
    Transmission:
    * Tremec TKX 5-speed transmission
    * Ram clutch kit
    * Ram flywheel
    * Quick Time bellhousing
    * Summit Racing™ clutch fork
    * ARP flywheel bolts
    * ARP pressure plate bolts
    * Ford Racing pilot bushing
    https://www.summitracing.com/parts/SUM-CSUMFFC07
    Engine:
    351 Windsor (427 CI) @ ~550HP
    Ford Motorsports block
    Block kit
    Scat or Eagle forged rotating assembly
    Custom hydraulic roller cam kit
    AFR Heads
    Roller rockers
    Custom push rods
    Valve cover
    MSD ignition [Dist, coil,wires, 6AL box]
    8 Stack EFI weber from Jim Inglese
    Headers/Pipes
    Gas-N Pipes Factory 5 Stainless Steel Side Pipes, Black Ceramic Coating / Touring - Quietest Sound
    351 Long Tube Stainless Steel Headers Factory 5 - 1-3/4" / Black Ceramic Coating / Adjustable Double Collector
    Wheels:
    18x11 Matte Black Wheel Konig Hypergram 5x4.5 15
    18x9.5 Matte Black Wheel Konig Hypergram 5x4.5 25
    Tires:
    Falken Azenis RT660 Tires
    Rear:
    Tires, Azenis RT660, 315/30R18, Radial, Blackwall, UTQG 200
    Front:
    Tires, Azenis RT660, 255/35R18, Radial, Blackwall, UTQG 200
    Keyless Start
    Likely going to just do what 465USMC did
    Mk4 complete kit arrived 10 May 23
    Current BOM
  2. Likes CaptB, zarnold liked this post
    Dec 2021
    Flower Mound TX
    Very nice! Love the SBF. Welcome to the fun!
    Are you planning on taking it to the track? Just curious about the sway bars.
    Jan 2019
    Mead Colorado
    I think so, but, not a lot
    Current BOM
    Jan 2019
    Mead Colorado
    Ordered an 8 stack EFI system from Jim Inglese.
    Current BOM
  6. Thanks KayzDad thanked for this post
  7. #5
    Dec 2021
    Flower Mound TX
    Quote Originally Posted by danmas View Post
    ordered an 8 stack EFI system from Jim Inglese.
    Very nice! Jim will take good care of you.
  8. #6
    Jan 2019
    Mead Colorado
    Engine:
    Dart or Ford Motorsports block
    Block kit
    AFR Heads
    Roller rockers
    Custom push rods
    Valve cover
    Current BOM
  9. Likes CaptB, zarnold liked this post
  10. #7
    Jan 2019
    Mead Colorado
    I am considering these wheels to go with my build. I haven't made up my mind yet, but, thought I would check with you all.
    Fronts: 18x9.5
    Volk Racing CE28 Club Racer II Black Edition Wheel 18x9.5 5x114.3 22mm Diamond Dark Gunmetal
    I don't know if a +22 offset is too close?
    Rear: 18x10.5
    Volk Racing CE28 Club Racer II Black Edition Wheel 18x10.5 5x114.3 15mm Diamond Dark Gunmetal
    15mm offset. I have heard/read that 18x11 is the preferred choice for the rear, which seems reasonable, but, Gordon Levy point me towards these wheels. Thoughts?
    Current BOM
  11. #8
    Congrats, Dan! Hope to see you on the road when you get it done. Give me a shout if you need a hand.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  12. Likes danmas liked this post
  13. #9
    Member KayzDad's Avatar
    Jan 2018
    Pentwater MI and Chicago, IL
    My kit should arrive in mid-April, and is configured similar to yours. Looking forward to following your progress!
  14. Likes danmas liked this post
  15. #10
    Jan 2019
    Mead Colorado
    I will take you up on your offer! Never dropped an engine in a car before, so, lot of firsts for me..... Thanks for your advice on the engine and EFI!
    Current BOM
  16. #11
    Jan 2019
    Mead Colorado
    Decided on these after working with Gordon for a few days. Need them because of the massive brakes.
    Wheels:
    Also think I purchased the hardtop to go with the roadster that @madfor67 was selling. Going to be a fun build!
    And I had to order different rollbars.
    Current BOM
  17. #12
    Apr 2021
    Park Ridge, IL
    Engine:
    Block kit
    AFR Heads
    Roller rockers
    Custom push rods
    Valve cover
    Are you planning on building the engine yourself ?
  18. #13
    Jan 2019
    Mead Colorado
    Quote Originally Posted by zarnold View Post
    Not this time around. I don't have the skill. I am having it built by a shop that Jim Inglese uses. In the future I have ambitions of getting to that level of detail. Right now its all about getting my first car together.
    Dan
    Current BOM
  19. Likes zarnold liked this post
  20. #14
    Member jvfitz's Avatar
    Aug 2022
    AnotherColoradoKit
    Not this time around. I don't have the skill. I am having it built by a shop that Jim Inglese use. In the future I have ambitions of getting to that level of detail. Right now its all about getting my first car together.
    Dan
    Dan, I live in "Parker" and my kit is to be picked up by Stewart April 15th. I am waiting to hear from Stewart for a delivery date. It sounds like we will be building at the same time. I will keep watching your thread. By the way I went and got the full tour at Papa Dave's garage. It was worth the time. I appreciate all the knowledge he has and shared with my son and I. We are building together.
  21. Likes Papa, danmas liked this post
  22. #15
    Jan 2019
    Mead Colorado
    Quote Originally Posted by jvfitz View Post
    He has been advising me for a couple years now. I redid my entire engine build based on his advice. I haven't made it down yet to see his kit. I actually am incredibly grateful to this community so far. I have spent the last 7 months or so thinking about the building and learning a bit every time I come here. Nights that I can't sleep I typically check in here.
    I think yours is coming before mine. I am building with my three daughters. Love to hear how your build goes. I think my next task is to build body buck and so forth.
    What does your config look like? Post your build thread? As an aside Junbug is here as well and ahead of us. He found a pretty awesome powder coating shop.
    Current BOM
  23. Likes Papa liked this post
  24. #16
    Jan 2019
    Mead Colorado
    Just got my call from Factory Five and solidified the order. Stewart transportation has me on the books and sometime in early May I will be a brand new cobra dad.
    Yay!
    Dan
    Current BOM
  25. Likes Papa liked this post
  26. #17
    Aug 2020
    Hi Dan,
    Congratulations!
    I have a frame dolly that I am finished using it is yours if you want it. I'm in Firestone.
  27. Thanks danmas thanked for this post
  28. #18
    Jan 2019
    Mead Colorado
    Yes!~ PM Sent
    Current BOM
  29. Thanks speedfreak1211 thanked for this post
  30. #19
    Jan 2019
    Mead Colorado
    Hardtop shipping from Texas!
    Got these picture for the hardtop I got from @Madfor67. It is possibly going to be the very first thing I get for the car (which seems backwards I suppose). None the less I am pretty excited!
    Current BOM
  31. Likes zarnold, Papa, 460.465USMC liked this post
  32. #20
    Senior Member Junbug's Avatar
    Apr 2022
    Lafayette, CO
    Fronts: 18x9.5
    Rear: 18x10.5
    Dan,
    If you haven’t completely made up your mind on your wheels. I recommend looking into Forgestar. I just gave them the FFR offset and backspacing specs for the wheels and they custom build them for what I thought was a reasonable price. And they offered free shipping when I ordered. Either way you go I’m sure they’ll look good!
    Please reach out if you have any questions. My kit was delivered in Jan!
    -Bryan
    -Bryan
    Mk4 Roadster w/ IRS, Forte Gen 3 Coyote/TKX, Wilwood Brakes
    Build thread https://thefactoryfiveforum.com/show...oyote-TKX-EFI)
    Ordered: 6/27/22, Delivered: 1/20/23, First Start 10/16/2023, Go-Cart 3/30/2024
  33. #21
    Jan 2019
    Mead Colorado
    Quote Originally Posted by Junbug View Post
    Dan,
    -Bryan
    Thanks! I ordered a set of Konigs and they showed up today actually. Sick looking wheel. I think these will work.
    Current BOM
  34. Likes Junbug liked this post
  35. #22
    Jan 2019
    Mead Colorado
    Tires:
    Nitto NT555 Gen 2
    2 x 255/45/18 diameter 26.7 for 18 x 8.5 / 9/ 9.5 inch wheel.
    2 x 315/40/18 diameter 27.91 for 18 x 11 /12 inch wheel.
    Current BOM
  36. #23
    Apr 2021
    Colorado
    I can't wait to see your wheels. I was bummed to hear about the leave time on the Volks... I hadn't seen those till your post and my are the good looking! I have been going to Forgestar's site a lot and looking at their offerings but couldn't find anything in the proper size. I'm glad to hear Junbug got some help when interacting with them directly and I'll likely do the same. Now looking at his build I'm afraid I might end up picking the same set! I'm not a complete copy cat I swear.
    CO front range is funny. I grew up in Del Camino right next to JV1953's Firestone. Because of that I went to Mead all through elementary and middle school. Before now living in Frederick (about three miles from the house I grew up in) I lived in Lafayette near Wanaka lake. I have a little bit of family in Mead and I know a number of people out there.
    MK4 #10255 project: "Mako"
    Coyote Gen 3, TKX, IRS, Wilwood brakes, power steering
    Order date: 6/24/21, Received date: 1/12/22, First Gocart date: TBD, Registration date: TBD
    Build thread
  37. #24
    Jan 2019
    Mead Colorado
    Wheels!
    Current BOM
  38. #25
    Jan 2019
    Mead Colorado
    Talked to i.e.427Garage and scored an unused RT drop trunk and old style trunk lid that will fit my hard top. Got my FFMetal Firewall Forward and fat tire wheel wells. Parts are starting to come in.
    Current BOM
  39. #26
    Tires:
    Nitto NT555 Gen 2
    You might want to give some thought to those tire sizes; the 255/45-18 is approximately 1.7" larger in diameter than the usual 255/35-18 or 255/40-17 which are both 25.0". In the rear the 315/40-18 is over 2" larger in diameter than the usual 315/30-18 (25.5") or 315/35-17 (25.7"). Unless you run an unusually high ride height I'm afraid you may find that you have conflict, especially if the rim's offsets move the tires farther outward than the FFR wheels.
    Jan 2019
    Mead Colorado
    Ugh. Guess I will see. This is what Gordon suggested (255-265 fronts and 305-315 rears) so this is what I got. I didnt even think to check if it would fit in the wheel wells. If its wrong I am sure it won't be the first mistake I make. Thanks for the heads up.
    Current BOM
  41. #28
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    When ever someone asks about wheel and tire fitment for one of these cars I always steer them to the FactoryFiveParts website. Pick your wheel diameter and scroll down to fitment and recommended tire sizes. https://www.factoryfiveparts.com/158...eplica-wheels/
  42. Likes zarnold liked this post
  43. #29
    Jan 2019
    Mead Colorado
    I have this thing where I consistently order the wrong thing. I am not certain why, but, given half a chance to pick the wrong size I do it 90% of the time. Anyway, returning and getting the right set. Probably Michelin Pilot Sport
    Rears:
    Michelin 09883 - Michelin Pilot Sport PS2 Tires
    Tire, Pilot Sport PS2, 315/30-18, Radial, Y Speed Rated, 98 Load Range, Blackwall
    Fronts:
    Michelin 27579 - Michelin Pilot Sport 4 S Tires
    Tires, Pilot Sport 4 S, 255/35-18, Radial, Blackwall, Y Speed Rating, 94 Load Index
    Before I pull the trigger on these is there anything I am missing?
    I also picked up a pair of pipes and headers from George over at Gas-N.
    Current BOM
  44. #30
    Rears:
    Fronts:
    Dan,
    The Michelin PS2 and PS4S are similar tread designs, but different compounds. I'm not sure it makes any difference for street use, but will defer to others that may have more technical info to share.
    Legal: 1/30/2020
  45. Thanks danmas thanked for this post
  46. #31
    Rears:
    Fronts:
    I'm not a fan of mismatched tires front to rear in any case (unless you're talking snow tires on an old 2WD pickup truck that hauls firewood ). Those Michelin that you spec have a harder compound for the front than the rear---with the factory spring rates these cars understeer to begin with and using a tire with less traction in the front will just exacerbate that condition. If it were me I'd just put Falken RT660s all around. But you're not me... With that said I'll say one more thing; unless you're planning a really quick build I wouldn't buy any tires yet. They're just going to sit, age and get hard. Wait until you have a running gocart to mount up fresh tires and in the meantime spend a hundred bucks on a set of junkyard wheels and "skins" to roll it around.
  47. Likes Bart Carter liked this post
  48. #32
    Jan 2019
    Mead Colorado
    ...I'd just put Falken RT660s all around. But you're not me... With that said I'll say one more thing; unless you're planning a really quick build I wouldn't buy any tires yet. They're just going to sit, age and get hard. Wait until you have a running gocart to mount up fresh tires and in the meantime spend a hundred bucks on a set of junkyard wheels and "skins" to roll it around.
    This is great advice and exactly what I will do in terms of getting crufty wheels and skins to roll around on. Thanks for the pointer on the rt660s, this is the kind of expert advice I need. Thank you...
    Current BOM
  49. #33
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    Kleiner and I agree on this point. Most tires on these cars age out before they wear out. Save the expensive tires until you're ready for them. Until then, find a cheap set of Mustang wheels & tires to push it around in the shop. 17" so they clear even the Wilwood calipers.
  50. Thanks danmas thanked for this post
  51. #34
    Jan 2019
    Mead Colorado
    Done. These are on my to order list:
    Rear:
    Front:
    Looking for crufty tires to roll the chassis around until I need them. Thanks Frank and Jeff.
    Current BOM
  52. #35
    Rear:
    Front:
    Something like this? https://cosprings.craigslist.org/wto...603414961.html
    Legal: 1/30/2020
  53. Likes danmas liked this post
  54. #36
    Jan 2019
    Mead Colorado
    Just got my inventory sheet and Parts on Order List (POL) today. Only 15 items back ordered. Serial #1010663. Stewart transportation should drop off on Wednesday or Thursday!
    Brakes and shocks coming from Gordon Levy.
    Engine and transmission being built.
    Quiet pipes on order (maybe another 8 weeks or so I am guessing).
    I am fairly excited to get started!
    Current BOM
  55. Likes JV1953, zarnold liked this post
  56. #37
    Jan 2019
    Mead Colorado
    Kelly with Stewart Transportation showed up at 8AM or so this morning. Took about 30 minutes to unload and that involved some paperwork issues (Blue sign on nose wasn't my blue sign. Chassis ID is correct tho!). My daughter got to take the first ride.
    And so it begins. Inventory this weekend.
    Current BOM
  57. Likes Papa liked this post
  58. #38
    Aug 2020
    Congratulations!!! Enjoy!
  59. Likes danmas liked this post
  60. #39
    Aug 2022
    Congratulations! Let the fun begin. By the way the car looks good on her....
  61. #40
    Jan 2019
    Mead Colorado
    Inventory complete. About 6 small items missing. 15 or so items on back order. Body removed. Have it hanging in the garage for a day or two while I get it over to my buddies storage shed. And so it begins!
    Current BOM
  62. Likes Papa liked this post
