Battery Location289
Build is going along great!
The kit indicates that the battery is mounted in the rear, I have also seen some in the front.
Those with 289s .. what location did you use ... and are you happy with it?
To me it looks like the rear mounted battery might be a PITA to work on .. but that is just a guess.
Have a great Easter!
Mine is in the trunk, haven't had to do anything to it since it was installed. I might consider moving it to the front someday.
FFR #8833 289 FIA 3-link
http://thefactoryfiveforum.com/showt...FIA-build-8833
I plan to mount my battery in the front of my 289, easier access, shorter cables and frees up some space in the trunk.
289 FIA Complete Kit, ordered September 2021, received February 2022
My plan is to build a tribute to CSX2345 as it raced in Europe in 1964 (with a few personal touches). Follow along as I fulfill a lifetime dream.
Follow my build #10295
https://www.instagram.com/ffr289fia/
I installed the Breeze front battery mount. Excellent quality, convenient, and easy to install.
https://breezeautomotive.com/shop/en...-1-4-roadster/
Mounted mine in front. Running a Coyote and space is tight. Breeze product is excellent as John289 mentioned. Should be able to access cables and remove battery for maintenance but will involve removing intake tubes & air filter.
Lars
Novice Build: 289 USRRC Complete Kit #10524, 3rd Gen Coyote, TKX, IRS, 17" Halibrands, Wilwood Brakes, Power Steering
I seriously thought about mounting up front, but I am going for a really clean look in my engine bay and I thought that just clustered things up a bit. Depending on your motor choice, could be a challenge getting to it (Coyote). I also wanted more space in the trunk. So, like several have in the past, I made extra room in my trunk with the Russ Thompson drop box. Because I have IRS, I went ahead and manipulated the drop box and added extra room right behind the center section. This gave me enough room for the battery and a small tool box area.
I will add a wall separating the battery and the tool area as well as a custom cover for this area. Very simple to get to the battery and it's tucked out of the way. I even have a light in there.
#10333 Complete Kit, Carbed 427w, TKX, IRS and many other upgrades
- Order Date: September 11, 2021 - 20th Anniversary of 9/11
- Delivery Day: April 1, 2022 - April Fool's Day
- First Start and Go-Kart: January 20th, 2023
- Graduation Date: July 4th, 2023 - Independence Day!!
- Legal Registration Date: October 4, 2023 - My Birthday!!
Visit my MKIV Build Thread (#10333)
I’m using the Breeze front mount battery kit on my 289.
“Privateer”
289 USRRC Chassis #9188 p/u 9/11/2017 Go kart 3/18/2018, road legal 6/16/2018
Ford full roller 306 built by my son and me Holley Sniper EFI
TKO600 2015 IRS 3:55. 17” FFR Hallibrand replicas, Power steering
FFR Vintage instruments, Wipers and Heat/defrost
Lots of parts and advice from Mike Forte & Mark Reynolds (Breeze Automotive)
Ted G
Looking good! and tidy!
I like the looked at the breeze kit ... additionals parts list just got bigger by one, for today anyways.
Thanks guys!!
