Likes Likes:  3
Results 1 to 5 of 5
Thread: Sunday conversation on rear end width
    Dec 2017
    Southern Ontario/Cape Coral FL
    Now I know Fox body width or 94-98 with Fox body axles are where it is at, but I also see some coupe builds that end up using 3/4 to 1 inch wheel spacers. My questions are...
    Have some guys used the 94-98 rear end(stock width) in a roadster with success?
    Did you make up the 1 1/2" with rim offset or tire size?
    If taking the car to track days is not in the plans, is tire rub a concern?
    Like I said in the title, just a coversation starter.
    Higgy
    MK4#? Ordered 11/30/24
    MK4 #11012 picked up 04/16/24
    Senior Member skidd's Avatar
    Jan 2016
    SA-TX
    If I follow your question correctly..
    I'm currently running an SN95 rear end with SN95 axles and disks. 315/35/17 tires on FR500 LMR 10" wheels. 3-point rear end mounting. With no rubbing at all. The tires are close. But, have never rubbed.
  3. Likes Higgybulin liked this post
    Jan 2016
    SA-TX
    A photo for an idea of the clearance.
  5. Likes Higgybulin liked this post
  6. #4
    Dec 2017
    Quote Originally Posted by skidd View Post
    That helps!!! So I looked at the Factory Five Halibrand replicas in 17" and the back space is a little differnt than your wheels. I suppose as long as the backspace is in that range, your good either way.
    And your build looks great!!
  7. #5
    I have also seen some variation in BS specs. I think different manufacturers use a slight different procedure.
    If they measure to the red vs blue arrow that could vary the spec 1/4".
  8. Likes Higgybulin liked this post
