I have posted a few threads about my dash upgrade and things not fitting very well. I had a precut dash and when I went to test fit I noticed that I could see the 3/4 tube above dash. If I shove up high enough to cover this it is very apparent the dash is running up hill on the passenger side. I have the under dash filler panel and it appears to be parallel to the 2x2 tube and in the threads I've searched this 2x2 tube should be parallel to the dash when installed. I even purchased a new dash from FFR and its the same so It has to be my car.
The radius at the cowl is uniform across so this leads me to believe the body may be high on the passenger side. The car is a MK3 and can someone tell me how wide the cowl lip is? Maybe its trimmed to short. The drivers side covers no problem. When installing body bolts should the holes fall directly over the chassis holes in the relaxed position? I considered removing them to see if this was the case.
With the dash installed and if you stand behind the car and look you can see that the dash is running uphill on the passenger side.
I never noticed this with the old dash and it may have been the same. I suspect the dash was running uphill and with the covering it just hid the 3/4 tube.
Is the anywhere to get some good measurements to verify? I know the body sits on the firewall bulb seal and the passenger extension bulb seal. Looking inside the car the seal appears to be compressed a good bit and maybe the body is held up on this side.
Open to suggestions.
