Results 1 to 3 of 3
Thread: Chassis Wiring Question
    Morgantown, WV
    I have a quick wiring question and I'm looking for some confirmation of what I plan to do. I have a coyote and the Ford performance install kit (wiring harness, computer etc).
    With respect to the alternator/starter branches on the chassis wiring, are they redundant and can be remove since they are repeated on the Ford performance harness?
    Not in any rush to cut wires, but want to make sure they are the right ones to cut.
    Thanks for any help.
    Prescott, AZ
    Other than the feed back to the battery, not really any redundancy. The FP engine harness takes care of the alternator connector. All you need to do is run your charging output to connect to the Power Distribution Box and eventually back to the battery. The Ford ECM will manage the alternator function.
    Morgantown, WV
    Thanks Alan.
