Thanks Thanks:  4
Likes Likes:  11
Results 1 to 20 of 20
Thread: Increasing Coupe headroom---and more surprises!
    My buddy Chris (AKA Gumby) sought more headroom and easier entry & exit for his Coupe:
  2. Likes mach'er, Higgybulin, John4337 liked this post
    Senior Member mach'er's Avatar
    Monroe, MI
    Wow, that's commitment to wanting improved access. And, a clean looking 'after' shot. Nice work! Will there also be a Gurney Bubble in this coupe's future?
    Roadster #9146. Complete Kit, 363 w/Jim Inglese Weber Carbs, Forte TKO600 w/Hydraulic Clutch, IRS, Wilwood Brakes, F & R Sway Bars, 17" Halibrands, Power Steering, Breeze Front Battery Kit, Herb's Door Panels, and who knows what else left to be added.
    Ordered 5/19/17. Delivered 8/18/17. Slowly Building.
    I hate where those top-side bars are on my Coupe- why can't they be moved up an inch or so along the radius of the front and rear hoops?
    Good to see that the tubes are thick-wall- ready to 'brain' me in a side-impact accident.
    Gen III #17
    18,250 miles
    Dublin, OH
    nice work.
    can you really call yourself gumby if you can't contort to fit inside though ?
  6. Thanks i.e.427, gumby thanked for this post
    Likes John Dol liked this post
  7. #5
    Falmouth, MA
    Wish I thought of that back when I built my coupe. I wrapped the bar with some padding but still bumped it with my head. Any chance the doors will be modified to wrap into the roof giving even more entry area? I know modifying the doors/roof takes away from the originallity of the body, but for the average street driver it would sure make getting in and out easier.
  8. #6
    Quote Originally Posted by cob427sc View Post
    ...takes away from the originality...
    I was going to keep this under wraps for a while longer but since you used the "O" word---When I say that "originality" has a whole other meaning in Gumby's shop you don't know the half of it
  9. Likes Gbeck liked this post
  10. #7
    Folsom, CA
    that last pic looks pretty badass if you ask me, something straight out of Mad Max
    Todd
  11. #8
    May 2021
    Fort Worth, Texas
    Is that a stock 4.0 six from Aussie land?
  12. Thanks gumby thanked for this post
  13. #9
    Nov 2021
    Texas!
    Quote Originally Posted by Skuzzy View Post
    Given the other work, "stock" may be not the right word.
    But yeah, certainly looks like a Barra I6 from down under.
    Rob Windsor
  14. #10
    Quote Originally Posted by Windsor View Post
    Gumby doesn’t know “stock”. This will be operating under more than one atmosphere.
  15. Likes Windsor, Gbeck liked this post
  16. #11
    Pittsburgh, PA
    Quote Originally Posted by Dave Tabor View Post
    On my Gen II the halo bars were welded so high that the body hit the curve in the bars before the body fully seated itself on the door sill area. I had to cut them at the main hoop, pull them down an inch with oxy-acetylene and a come along, and reweld them so that they would not either wear a hole in the roof, crack the body or both. Not sure how much clearance the Gen IIIs have, but mine and I am told other Gen IIs had to be moved down, not up! The halo bar location is the scariest part of the car and at 5'10.5" tall I should probably wear a helmet to drive it.
    Is that the car that was owned by "Kit Car Rob" and crashed many years ago?
  17. #12
    May 2023
    Jeff said he posted some pics of my build; figured I better get in here before he starts telling cockamamie stories about how I autoX a truck, and tow with a car.
    So, anyway.....
    Quote Originally Posted by Jacob McCrea View Post
    This is that car.
  18. Likes Geoff H, Gbeck liked this post
  19. #13
    Ah, look who showed up! We can use more Gumby thinking and bad decision making around here
    Quote Originally Posted by gumby View Post
    ...figured I better get in here before he starts telling cockamamie stories about how I autoX a truck, and tow with a car.
    If there are any cockamamie stories to be told they'll include the one about how THESE:
    BECAME:
    AND FINALLY THIS:
    Which became the victor in the Grassroots Motorsports Challenge
    https://grassrootsmotorsports.com/ne...TzU4gGRWG_bxmc
    https://grassrootsmotorsports.com/fo.../177534/page1/
  20. Likes gumby, Gbeck liked this post
  21. #14
    May 2021
    Fort Worth, Texas
    I like the way you think gumby.
  22. Thanks gumby thanked for this post
  23. #15
    mburger's Avatar
    Punta Gorda FL
    And his skills.
    Mark
  24. #16
    May 2021
    Fort Worth, Texas
    Quote Originally Posted by mburger View Post
    And his skills.
    Oh, absolutely.
  25. #17
    Senior Member Gbeck's Avatar
    Jan 2013
    South central PA
    In my Gen 2 car I replaced the fore/aft tubes with an "X" configuration. Here's a picture of it in progress.
    All New Pieces In Place by Team Limer, on Flickr
    Gen 2 Type 65 Coupe. Gen 2 Coyote. T-bird IRS. 3.55 Torsen diff.
    Find me at "Team Limer" on Facebook
    https://www.flickr.com/photos/750619...7668366966791/
    Rally North America "Team Limer"
    https://www.classy.org/team/464751
  26. #18
    May 2023
    The madness continues...
  27. #19
    Senior Member q4stix's Avatar
    Seattle, WA
    I'm a big fan of madness and fun to see the Barra. Keep it up!
    Gen 3 Type 65 Coupe builder
  28. #20
    May 2021
    Fort Worth, Texas
    I am curious about this one as well.
