I've got #333 with Moser rear axle option and 3 link rear suspension. Using the supplied Koni coilover, the 3rd member of the rear axle hits the diagonal member of the 3 link mount. And not just a little; it fails to clear by about 1.5" I've talked to Koni and Moser--no luck. FF techs say not to worry about it, it will clear under load. That's not acceptable to me--it won't always be under load. Has anybody else with this combo encountered this problem? How did you fix it? This is holding me up; I've got most of the go-cart stage finished and can't get to body work/paint till I get this worked out. Help please.
