Thanks Thanks:  2
Results 1 to 3 of 3
Thread: Cut inner door edge that sticks up
    Jul 2020
    Spencer, MA
    This edge that they left at the top inner edge of the door I assume you grind down to make the top of the door flat. Am I correct in saying that?
    Then round it off and add filler as needed.
    Yes.
  3. Thanks Mastertech5 thanked for this post
    Jun 2020
    SoDak
    FFR like any other business must keep on rotating / replacing employees in the fiberglass portion of their business. The inconsistency of panels out of the factory is somewhat surprising. My Gen2 kit I got in Sept of 2020 had that edge removed. Odd some do and some don't.
    Jim
  5. Thanks Mastertech5 thanked for this post
