33fromSD, The tabs on the top rear of the side covers that you are suppose to screw/bolt to the body under the hood sides are way too thick to fit under the hood and the hood at those areas are 1/4" thick. There is no way the hood is going to fit over them. It hits the body now in those areas as I have to push it down to get the hood to sit on the cowel. Did you have that problem too? Street Rod Jim cut the tabs off and had brackets made to attach it on the back side to what I'm not sure.
