It’s really not that big of an installation, especially if you already have the sensors run for ABS.
Basically, you just tap into the sensor wires, and wire the module between the ECU and coil drivers. Of course, you’d need Forscan or something comparable to disable coil diagnostics—but that’s not much of a challenge.
For the ABS, I’m in a holding pattern until I can get my hands on a Forscan profile for a 2005-2009 Mustang. If all else fails, I’ll go “test drive” one so I can plug in and get the profile I need!
