New video posted. Fixed leaking speedo cable, found that the trans fill plug is stripped and came up with a work-around, changed trans fluid, cleaned and installed rear wheels, and continued wiring cleanup on the right front corner. Enjoy!
FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
New video posted. The beast is back on the road. Finished up the front end wiring clean up, replaced missing trans bolt, set ride height in front, cleaned and installed wheels, and went for test drives after setting tire pressures at 23 psi. Enjoy!
New video posted. Found some issues on test drives and installed front and rear Cobra badges. Enjoy!
New video posted. First attempt at correcting the ride height and sealed the leaking rear diff girdle studs. Enjoy!
New video posted. Fixed the prior owners’ fubared hack-job timing and added insulation. Car drives SO much better. Enjoy!
New video posted. Finalized the ride height, included a long cold start for those who wanted to hear it run, and gave a preview of the next upgrades.
New video posted. I centered the steering wheel to the steering rack and then set the front toe. Enjoy!
Great videos. I am working on updating a MK 1 as well and I was curious about the part number for the steering shaft grommet you are using. Thanks!
Thanks for the feedback.
Grommet that I found as being the best option is Help/Dorman part number 42344. Hoping to have it installed for the next video.
https://www.amazon.com/dp/B000C5I49C...roduct_details
New video posted. Finishing up the alignment stuff, relocating some wires, fixing the speedo cable, looking at options for sealing the steering shaft, and a few tips regarding the steering wheel center piece and the wheel centers. Enjoy!
New video posted. I installed the Maximum Motorsports clutch pedal height adjuster and firewall cable adjuster.
New video posted. Checked and tightened the wheel bearings and started adding gauges. Enjoy!
New video posted. The 5 center gauges are all installed and working. I installed Auto Meter Cobra gauges - mechanical oil temp, mechanical water temp, clock, fuel gauge, and voltmeter. I used the oil level sensor bung with an adapter for the oil temp sensor. Also changed the oil and filter.
New video posted. Found a gas cap that fits under the filler cap. Installed Herb’s door panels. Also polished up some bright work. Enjoy!
Been a while since I have updated anything. The weather turned on us here and the car is now put away for the winter. I will be posting some videos this winter as I do have projects/work in the pipeline, but have been side-tracked with my other project car trying to complete an engine swap with it. More to come.
Yesterday was the one year anniversary of this car being dropped off at my house. Crazy how time files. Still working on my MR2 engine swap project, once done, Cobra work will resume. A lot on the to do list.
Memories, quick video of my first drive (coming home).
https://youtu.be/B7gBPDiCPK4
On another note, ordered Edelbrock Pro Flo 4 setup yesterday so there is going to be a lot of change coming to this car over the next few months.
Enjoy!
Posted a video with an update on changes that are in the works for this year including installing an Edelbrock Pro Flow 4 setup.
https://youtu.be/l_O8kxbJwyQ
Back to work on my car. Pulled out the Ford EFI and started the install of my new Edelbrock Pro Flow 4 setup.
https://youtu.be/Tt4azabqk8E
Put together an update. Many new parts received/on order:
https://youtu.be/yJeracZ2A2k
Let the fun begin. Attempting to install reproduction 427 S/C dash in my FFR MK2 Cobra.
https://youtu.be/ZB5G7VnAi8o
Getting back to work. De-loomed and started dieting the factory Mustang wiring that has been in this car for over 20 years. Lots of progress made, more to come. Then comes time to get the Edelbrock Pro Flo 4 up and running.
https://youtu.be/QlCtH_sN5do
More de-looming work on the harness. Crazy how much I can remove.
https://youtu.be/4oYn1_q29a8
Finally finish removing all the I can from the main harness. Time to start reinstalling.
https://youtu.be/b4vOF3slsYg
Finished re-looming and reinstalling the rear harness. Now on to the Edelbrock Pro Flo 4 EFI install.
https://youtu.be/j3kbtHTcijw
New video posted, had to find a more permanent mount for the Herb's panels, started wiring in the Pro Flo 4, and new parts have arrived for the car.
https://youtu.be/itdKRoGSnoM
New video posted, started installing the reproduction 427 S/C dash from cobra performance.
https://youtu.be/CTFlNNoT-6k
New video posted. Started installing the throttle setup on my Edelbrock Pro Flo 4 using Forte linkage and Thompson pedal.
https://youtu.be/wFTHlF9_2NM
Finished the install of the mechanical throttle linkage and throttle pedal. Happy with the results.
https://youtu.be/8Sm5-MhVXOk
Back to wiring on my MK2. Almost ready to start installing the S/C dash and gauges.
https://youtu.be/F8v3M7C9trk
Now that the wiring is wrapped up, I completed the final customization to install the 427 S/C dash and installed the new dash cover.
https://youtu.be/pHTm4QkcTjE
Bouncing between putting the dash together and getting back to work on the engine prep/cleanup.
https://youtu.be/7QKskEDd64Q
Fun task of notching/customizing the turkey pan to fit the large diameter distributor. See what I did here.
https://youtu.be/tlKSEoPxLAg
One step forward, two steps back. Fixing stripped bolt holes, water pump issues/differences, and nord locks on the exhaust manifold bolts.
https://youtu.be/7fMo0jIfzh0
If it’s not one thing, it’s another. Ford water pump variances bites me with my water pump replacement.
https://youtu.be/JLmGt9JpdFk?si=js8Hr2PwopivRFO6
Progress and planning on my Cobra project. Dash is done and I put together a game plan for the remaining engine bay items.
https://youtu.be/zzLfUK92zfI?si=hOw8IWROXkL15vm2
Planning and buying parts for multiple systems on my Cobra project. Slowly, but surely making progress.
https://youtu.be/1aJWwjP5Mfk?si=hMsOSLsfoOb5w3Yq
More progress - fuel system, ignition coil, finally a belt that fits, and wiring in the fuel pump relay.
https://youtu.be/ntx7Gw0kvNQ?si=QezBX2LgH9NCiQX0
More progress on my Cobra project. Fuel system is done, on to the cooling system. Unfortunately came across a few roadblocks.
https://youtu.be/9vNzbX2YIWY?si=tCpwS3lo6AedZE4v
Progress on the Cobra, it now has a FE surge tank and looks so right.
https://youtu.be/hSKEjThxAwQ?si=7MJ9M5JVp4CAtH7u
