Likes Likes:  4
Results 1 to 15 of 15
Thread: Trans Cooler, what did you do?
    Sep 2022
    Huntington, IN
    Automatic 700R4, what did you guys do for a trans cooler? Anyone use a remote cooler with a fan? Where did you mount it and how?
    May 2018
    Chaska, Minnesota
    I plan to use the internal cooler in the radiator, as it maintains the perfect 200 degree operating temperature. External coolers and fans just seem to add complexity, and they actually can over cool the ATF on less than hot days.
    Jul 2020
    Spencer, MA
    Just use the built in cooler in the radiator. Remote coolers are generally only needed for towing, racing or heavy duty use.
    Placitas, NM
    If you live in the Southwest or other hot locations you may want one.
    I picked up a tranny cooler off a Suburban at the local junkyard for $7.
    It’s mounted to the frame rail with a switch so I can turn the fan on when it’s needed.
    It’s plumbed in after the radiator cooling loop.
    Junior Member proeagles's Avatar
    Covington, LA
    While I agree with using the radiator, Bowler transmission requires an external oil cooler for my 700R4 I'm installing in my 57 Chevy for warranty purposes. Just a thought.
    Sep 2022
    Huntington, IN
    Quote Originally Posted by proeagles View Post
    Same here, I was told to by my trans builder to definitely add an external cooler.
  7. Likes JimLev liked this post
    Jul 2020
    Spencer, MA
    If it's a warranty issue then add an external. Peace of mind in a good thing.
  9. Likes Just 1 More liked this post
  10. #8
    Truck build here, so not 100% applicable. But I found it was impossible to have both an A/C condenser and the radiator cooler in the grille area for my Gearstar/GM 4L65E. I installed a Derale Cooling Products 13950 powered unit under the bed in the back. It's not that big and suspect something like that would work with the hot rod if necessary. Important to decide early in the build because it obviously affects routing of the cooling lines, among other things.
  11. #9
    Sep 2022
    Huntington, IN
    I looked at a bunch of those and if I go that route i'll do the Perma Cool 13211 for it's lower profile. https://www.amazon.com/Perma-Cool-13.../dp/B07BTPWSPM
  12. #10
    Falmouth, MA
    If you are using the 32 radiator and shell the radiator does not provide for a transmission cooler connection (at least mine didn't). I purchased a small transmission cooler and mounted underneath near the rear end in the airstream. Never had any heat problems.
  13. #11
    Sep 2022
    Huntington, IN
    Update on this, I used a Derale 13401 and plumbed it in line with the radiator trans cooler.
  14. #12
    Jul 2020
    Spencer, MA
    Nice job!
  15. Likes Just 1 More liked this post
  16. #13
    Kingsland, TX
    Very nice install!
  17. Likes Just 1 More liked this post
  18. #14
    May 2013
    OH,KY,WV tri-state area
    Check out one of these https://www.summitracing.com/parts/sum-331000?rrec=true they are made specifically for use in small spaces
  19. #15
    Sep 2022
    Huntington, IN
    Quote Originally Posted by Ford & Jeep Fan View Post
    Tried one of those, didn't work for what I wanted.
