Thanks Thanks:  9
Likes Likes:  2
Results 1 to 18 of 18
Thread: Gen 3 Coyote Engine hoist mounting
    Senior Member Junbug's Avatar
    Apr 2022
    Lafayette, CO
    Below are pics of the current location of the engine hoist mounts as my engine came from Mike Forte. I believe there are better locations as these are both on the back of the engine (closest to the transmission). I understand its best to have one on the front and one on the back side of the engine, but I'm curious where the best lift points are? I believe for the PS they are one of the two holes immediately above the left most exhaust/header port? And on the DS potentially one of the holes right above the transmission (facing back toward the left in this photo. I appreciate any advice and experience. I'm a few weeks away from putting the engine in, so I'm starting to make sure I get the best advice!
    -Bryan
    Mk4 Roadster w/ IRS, Forte Gen 3 Coyote/TKX, Wilwood Brakes
    Build thread https://thefactoryfiveforum.com/show...oyote-TKX-EFI)
    Ordered: 6/27/22, Delivered: 1/20/23, First Start 10/16/2023, Go-Cart 3/30/2024
    Senior Member mmklaxer's Avatar
    Kennebunk, ME
    Mike's hoist points are great for moving the engine around, but they will not allow you to get the engine in/out of the car. They're just WAY too wide. You need any of the aftermarket lifting set ups that pick up fromt he M14 points right/aft and left front.
  3. Thanks Junbug thanked for this post
    Prescott, AZ
    I am using the lift brackets from TD Motion. They mount to the left front and right rear corners of the block. I am not using them on a Factory Five but I have had no issues with them. The right rear is a bit tight on room when removing the bracket.
    https://tdmotion.com/product/coyote-...lift-brackets/
  5. Thanks Junbug thanked for this post
  6. #4
    Folsom, CA
    I used one at the front driver side and rear passenger side, really helped to tilt the motor down into the cavity
    https://thefactoryfiveforum.com/show...l=1#post510561
    Todd
  7. Thanks Junbug thanked for this post
  8. #5
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Aside from being very bulky, Mike's lift brackets will not allow you to install the DS header while the engine is still hanging on the lift, which is slightly easier then installing it after it's sitting on the engine mounts.
  9. Thanks Junbug thanked for this post
  10. #6
    Apr 2022
    Lafayette, CO
    Quote Originally Posted by toadster View Post
    Toadster,
    From those lift points, Were you able to get the headers on while the engine was still hanging from the hoist (a few inches above the engine mounts)? I hear it’s somewhat easier to install/tighten the headers while it’s in the air. Also what type of lift point brackets did you use?
    -Bryan
    -Bryan
  11. #7
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    Find someone who has a leftover set of the Factory 5 engine lift brackets. I've used them for every Coyote build we've done and they worked out perfect. We install headers after the engine is in place (with locking hardware from Stage 8) and have never not been able to get the headers installed.
    20 minute, solo engine install.
  12. Thanks Junbug thanked for this post
    Likes Andrew Davis liked this post
  13. #8
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    Having the right style engine hoist helps a lot too.
  14. Thanks Junbug thanked for this post
  15. #9
    Apr 2022
    Lafayette, CO
    You sure make dropping that engine in look easy Frank!
    -Bryan
    -Bryan
  16. #10
    Folsom, CA
    Quote Originally Posted by Junbug View Post
    Toadster,
    -Bryan
    while I didn't do the header install in the air, it could be done, the mount spots are away from the headers - wouldn't be an issue IMHO
    Todd
  17. #11
    Dec 2021
    SE Arkansas
    This is what I used.
    https://tomsoffroad.com/parts/coyote...iABEgLA8vD_BwE
    Connected them to the Driver side front, and passenger rear. Installed the headers with the engine 2-3 inches above the mounts (don't remember exactly)
    Ken
    MK4 #10476, complete kit, Gen 3 Coyote, TKX with 0.68 overdrive, PS with cooler, IRS, 18" rims, dual rollbar, Carbon fiber dash,
    Ordered 12/18/2021, Deliverd 9/24/2022, First Start 6/24/2023
  18. #12
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Here's my revised opinion on header installation on a coyote, having had the "pleasure" of doing it multiple times now. At the time I installed the engine I followed the recommendation to install the DS header with the engine dangling slightly above its final resting place. I agree that this is perhaps slightly easier than trying to install it with the engine on its mounts and the car on the ground. But stuffing yourself under a car with the engine hanging on the hoist is, well.... a little sketchy to say the least and not something I would repeat.
    Later I had to remove the original headers and replace them with new headers (with Stage8 locking fasteners), which I was able to do on my lift. Access to the DS header with the car on the lift is infinitely better than with the car on the ground, and DS header removal/installation, while tight, was definitely doable. The benefit of doing it this way is that you don't have hundreds of pounds hanging over you, suspended by a janky Harbor Freight leveler, ready to kill you. So if you have a lift I would say to save the hassle of trying to install the DS header with the engine hanging on the hoist and just do it after engine install on the lift. If you don't have a lift and will have to do the header install with the car on the ground or on jack stands then it might be slightly easier to install the DS header with the engine hanging on the hoist.
  19. Thanks Junbug thanked for this post
    Likes toadster liked this post
  20. #13
    Folsom, CA
    honestly the driver side bolts weren't as hard as expected, used the Stage 8 (8914) 1.25" Thread Pitch Bolt Kit for Ford Coyote 5.0 like JohnK did as well
    once you're under the car with the engine on the mounts, you get creative with several wrenches and they go in really nicely
    Todd
  21. Thanks Junbug thanked for this post
  22. #14
    Apr 2022
    Lafayette, CO
    JohnK and Toadster,
    Thanks for sharing your experience and tips. I don't have a lift, so it looks like I'll be wrestling the DS header while under the car/hoist/engine... Regarding the Stage 8 locking bolt kits, my searching has led me to two different type, 10MM x 1.25" and 10MM x 1.50". It appears Toadster used the 10mm x 1.25" based on the link above, did you install a Gen3 Coyote? JohnK I know your engine is a Gen2 Coyote, did you use the 1.25" or 1.50" kit?
    -Bryan
    -Bryan
  23. #15
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    The Gen2 coyotes used both M10 x 1.25" and 1.5" over the course of their life. Mine was 1.25". I have no idea what's on the gen3's. You should definitely verify using one of the factory exhaust studs on your engine.
  24. Thanks Junbug thanked for this post
  25. #16
    Folsom, CA
    yes mine is a Gen3 with the 1.25 thread pitch, they're on sale now for $49 which is a great deal - once you mount them, run a few heat cycles then put the clips on and they won't back out
    they have great customer service as well
    Todd
  26. #17
    Member M22_COBRA's Avatar
    Aug 2023
    Suttons Bay, MI.
    Are the clips a PITA to remove once they set in? Just in the event you crack a header. Long term I'm sure its better than having to nut and bolt them every month.
    I have some other work applications this may work for also....Thanks!
  27. #18
    Folsom, CA
    haven't heard of any cracked coyote headers, but they're removable
    Todd
