Thanks Thanks:  4
Likes Likes:  4
Results 1 to 6 of 6
Thread: Novice bodywork question
    Apr 2022
    Hey guys I’m starting on the bodywork on the ‘33 and as I’m sanding down the seams on the roof I’m finding what I can only describe as a soft clay like substance encapsulated in the seems. I assume it’s a bonding agent of some kind that FF uses to adhere the panels. I assume you guys are going to tell me that I need to get all that crap out before I apply a filler. My question is can I expose this unknown substance and let it sit for a while (days/weeks) and hope it dries, can I fill over it (sealing it under the filler) or do I spend god knows how many hours cleaning it out by whatever means necessary? I’m a novice when it comes to fiberglass work and some advice would be appreciated. ThanksIMG_7502.jpgIMG_7503.jpg
    It is clay which is used to plug voids in the mold parting lines and must be removed.
    Apr 2022
    Thank you sir. I’ll grab the Dremel a wire brush and get to work.
    Since you are doing your own bodywork, hopefully these videos may help.
    Parting Line Removal:
    https://youtu.be/_3sLamdkIFg
    Parting Line Smoothing:
    https://youtu.be/meBYeI96_A8
    The Bodywork Begins:
    https://youtu.be/6QXWP5H8mT0
    The Bodywork Continues:
    https://youtu.be/6UK6K2jcwTU
    The Bodywork Is Done:
    https://youtu.be/po1Bb2_XDDk
    Undercoat / Raptor Bed Liner:
    https://youtu.be/FVMCA4_UZHU
    Reassembly:
    https://youtu.be/ELFJDOVKb4g
    Graduation, Minus Wiper Install:
    https://youtu.be/9WEe6-wdNtA
    1. My big takeaway is knowing when I had run out of talent and needed to bring in professional help.
    2. My 2nd big takeaway was putting on way more filler than I needed and sanding it back in an X-Pattern.
    3. My final takeaway was to listen to Jeff Kleiner & take his advice because he really, really, really knows his stuff.
    Good Luck!
  5. Thanks JimStone, Just 1 More thanked for this post
    Likes JimLev, Just 1 More liked this post
    Placitas, NM
    And before you get any paint on the roof make sure the front and rear glass fit the openings.
    I had to enlarge both of mine to get the glass to fit.
  7. Thanks KippRacing, Mastertech5 thanked for this post
    Likes Just 1 More, Mastertech5 liked this post
  8. #6
    Jun 2020
    SoDak
    I actually really enjoyed working with fiberglass and learning the process. I found it a lot more forgiving then doing metal work, meaning if you screw up just mix up some resin, lay some glass, let it cure and sand / finish. It's definitely a lot messier than metal (lots of dust) but that would be the only negative comment I have about it.
    I still like metal work too, but I'm glad the 33 build gave me the experience on fiberglass. I've done a few fiberglass projects since then (built a fiberglass glove box for my 55 F100, did a fountain repair for my wife's flower garden, repaired a bumper on my son's Mitsubishi Lancer, etc.).
    Jim
