0
0
25th Anniversary #9772
my mistakes = your benefit, fog/driving light buttons from billetautomotive buttons
I have two of these, both a little different - they're new but I've attached spade connectors and labels
1st one 22mm,the hole that you cut out is 22mm, has "DRIVING LIGHTS" laser etched
face/head size 25mm
blue backlit
5A: Nickel plated shell, LED back-lit etching. (only the etching on the center of the button is back-lit) 5 amp rated SPST switch
$30 shipped
2nd one is 19mm, the hole you cut out is 19mm, has "FOG LIGHTS" laser etched
face/head size 22mm
white backlit
16A: Nickel plated shell, LED back-lit etching. (only the etching on the center of the button is back-lit) 16 amp rated SPST switch
$25 shipped
I changed my mind on my setup, so save about 20% on costs including shipping
bump adjusted prices and showing amperage per switch as well
bump for more views - anyone interested?
bump - make an offer
How do they operate? Push on/push off?
bump still available
